News
330 GTC Air Conditioning Parts
Discussion in 'Vintage (thru 365 GTC4)' started by svprice810, Sep 19, 2008.
  1. svprice810
    svprice810 Rookie
    May 4, 2008
    32
    california
    victor preisler
    Hello,
    I am looking for a complete air conditioning system for a 330 GTC. So far I have located a compressor but I need to find out if it is correct. If someone would be willing to send me a picture of the compressor showing the part number etc., I sure would appreciate it. If anyone knows where I can find a system or parts of it, that would be nice too :).
    Have a great day,
    Vic
  2. svprice810
    svprice810 Rookie
    May 4, 2008
    32
    california
    victor preisler
  3. Fontana
    Fontana Karting
    Dec 30, 2006
    176
    Vermont
    Steve Markowski
    I have made a few A/C systems for GTC. The easy stuff is the compressor and condenser but it is difficult to locate the correct hose ends and evaporator. I can provide you a complete system that looks original (except for the hose ends, slightly different) with an evaporator that is "bolt in". I had an original evaporator and made a copy of it and located a core to work inside the housing.
    You will never find the vent/switches, i am thinking of re-making them soon as they are often broken on A/C equipped cars anyway. On the last car i set up, the switches were located under the dash.
  4. SCantera
    SCantera Formula 3
    1,365
    Naples
    Steve,
    I have heard many good things about your shop and quality of work. In fact when I was rebuilding the engine and other systems in my car my local shop conversed with you - I believe more than once.
    One of the systems I modified was the a/c system. Although I know how many feel about originality I used a Sanden rotary compressor, a larger GMAC condensing unit [matching the width of the radiator] and an MB E-class vent fan motor for more velocity. The fan motor is an easy swap out of the Lucas unit. Since it is in the dash no one will know the difference. The others required some bracket work. And naturally I kept all of the original components in the event I ever part w/ the car [not likely].
    I did all of these mods since I my car is a driver and not a show car. And I live in FL where airconditioning is crucial to extend the driving season.
    To the OP.......you should consider contacting Steve at RPM for parts and help. They are a class operation for Ferrari and other restoration work.
  5. synchro
    synchro F1 Veteran
    Feb 14, 2005
    8,687
    CHNDLR
    Scott
    #5 synchro, Dec 17, 2010
    The York compressor's used in these A/C systems were not made by Ferrari but sourced from off-the-shelf items by York, hence their universal mount makes them easy to confirm the fit. When I installed it in my Maserati Bora, it attached with 9 bolts across all three axis (overkill IMHO) but each bolt lined up with the brackets and mounts perfectly. What you'll need to know is if you want the suction on the Right or the Left.
    I've purchased three for my cars, installed one in my Maserati Bora, one in my Dino and the third was supposed to go for a friend who sold his car before installing it, so I have a spare extra. It is new, in box, production date June of 2009, never mounted or used, only taken out of the box for this photo. $350 + shipping. Comparably, a friend paid $550 for rebuilding his original York.
    Its far improved from the original, heavy duty rotolock dessign producing 40% higher cfm, uses improved viton seals, and is compatible with R-12, R-22, R-134a and others. Contact me offline if interested
  6. leadingedge
    leadingedge Rookie
    Jun 16, 2015
    3
    Hi there, I know this thread is quite old, but wanted to see if it was still possible to have an A/C system made for a '67 330 GTC?
    Thanks!
  7. westextifosi
    westextifosi Karting
    193
    Lubbock, TX
    Tex Timberlake
    See #3 above. Steve Markowski has just completely reworked the a/c in my Daytona to my complete satisfaction.
