So yesterday the clutch spring popped off,......is it a big deal? Clutch works perfectly well without it. I assume it’s a clutch assist spring?
what you understand under clutch spring? and where is it located? alone the clutch disc has several springs
It looks like the spring that helps the clutch pedal. It’s about 5” long, tight wound spring, 1/2” diameter......has a j shaped hook on both ends
ok cool,.....yeah it functions totally fine without it lol. Just wanted to confirm Bob...... Thank you very much
