News
330 GTC headlight and fog light switches and circuits
Discussion in 'Vintage (thru 365 GTC4)' started by 330GCC, Apr 2, 2019.
  1. 330GCC
    330GCC Rookie
    Aug 22, 2006
    7
    Hi all,
    Hope you can help me. I recently had some upholstery rehab done on my 1967 330 GTC that required removal of the center console and toggle switches. When I got the care back, headlights were not working but tail lights and license plates lights were. Turn signals and brake lights working. Defrosters were also not working. We’ve started to sort out the problem and I am finding a number of weird wiring setups. We’ve pulled the light toggle switch on the left side of the console and with some experimentation, can get the the toggle to turn the fog lights/engine compartment light on-off and not related to the light toggle, can get the steering column wand to power the headlights off-low-high: the dash toggle switch has no effect on the headlights. In this configuration, now the tail lights/license lights do not work.
    My initial questions are how does the light toggle interact with the column lever switch. Are they connected somehow as a multi-way switch or are they separate circuits. I seem to remember that to turn the headlights on, I needed to turn the toggle on and then use the steering column wand to chose off-low-high. Also, wondering how many terminals the light toggle switch should have? The one I pulled has 4 terminals. I also found a push/pull switch on the left side of the steering column and wonder what this is.
    Thanks you for any advice.
    Graham
  2. Motob
    Motob Formula 3
    Nov 11, 2003
    2,149
    Berkeley, CA
    Brian Brown
    It sounds like there is some really messed up wiring in your car. The left toggle switch (for the lights) should have a black plastic housing with six spade connectors. all of the other dash toggle switches have four terminals with white plastic housings. All of the toggle switches were made by Lucas. Only five of the six spade connectors are used on the light switch. In the on position this switch sends power to a 4-pole black plastic junction block, located at the upper left hand corner of your fuse box plate in the engine compartment. This junction block will have three or four small black wires on one pole, a green wire, red/black wire, a violet wire and a white wire at the other poles. All of these poles should be connected together and powered when the dash toggle is on. This block will power up the parking lights, taillights, license lights and dash lights (through the rheostat). Some of power to these lights is routed back through the fusebox. You will have to look at the labels on the fusebox cover and in the owners manual. The other wires from the dash toggle switch send power to the steering column switch. Some will power the high-beam flash contacts in the column switch when the toggle is in the off position, and the others will power the headlights through the column switch when the toggle is in the on position. The column switch then sends power for the low beam headlights back to the fuse box (via yellow wire) and to the high-beam headlight via the red wire.
    The later 330gtc incorporated a large black plastic CEAM relay for headlight power, if your car has it, it will be attached to the right side metal support for the steering column under the dash and have three wires to it (two blacks and one red/black wire).
    These cars never came from the factory with foglights. The wiring would be there for the lights, but no switch. On the 330GTS, the second from the right toggle switch marked "X" would be used for the foglight switch, but on the GTC this switch is marked "R" and is for the rear window defroster. The connectors/wiring for the foglights just hangs loose under the dash, and the power wire to the foglights end in the wiring harness midway along the RF fender.
    There was never a push-pull switch on a 330gtc from the factory.
    For normal light use, you would turn the dash toggle on and get park/tail/licence/dashlights with the column switch in the upper position. Then move the column switch to the middle position for low beams, and finally to the lower position for high beams.
    Anytime the toggle switch is on, you should get a green "lights" or "luci" indicator light at the middle bottom of the speedometer. With the high beams on, you will get a blue warning light "Fari" or Projec" at the middle bottom of the tach.
    Finding the correct toggle switch for the lights is going to be difficult as they have be unavailable for years. It they are in good shape, I restore them by taking them apart and cleaning the contacts.
    SCantera and TTR like this.
  3. 330GCC
    330GCC Rookie
    Aug 22, 2006
    7
    Brian, Thank you for your very thorough and helpful info. Graham
  4. suleyman
    suleyman Rookie
    36
    PNW
    Motob,
    Thanks for such detail. On my gtc, the engine bay lights do not work unless the console "L" switch is flipped. Is that the factory correct setting? The interior lights and trunk light work without having the switch turned on.
    Thanks for any "light" you can shed on this!
    Suleyman
  5. Lowell
    Lowell Formula Junior
    Silver Subscribed Owner
    Apr 17, 2005
    904
    Santa Fe, NM
    Lowell Brown
    That's how it is for my 330GT 2+2.
  6. Motob
    Motob Formula 3
    Nov 11, 2003
    2,149
    Berkeley, CA
    Brian Brown
    That is correct. There is power to the engine lights only when the "L" switch is on. They are one of the small wires (Violet) that is connected to the 4 pole black rubber junction block on the fusebox panel. There should be a push switch that contacts the hood that will only let the lights work when the hood is open at the RR . corner of the hood.
    suleyman likes this.
  7. SCantera
    SCantera Formula 3
    1,948
    Living Falls NC
    Brian....thank you for the detailed information on how the lighting system is wired in the GTC. As you mentioned the toggle switch for the lights is different than the other toggles on the console. Not only does it have a 6 spade connector but it is also a heavier spring action than the other 4 spade switches. About 40 years ago I was driving my first GTC on a dark road only to have the light switch toggle fail. It just flopped and the lights went out. Luckily I kept an extra 4 spade switch in the glovebox and was able to "jury-rig" it in to get back on the road.
    My guess is that on the OP's car the upholstery contractor didn't mark the wiring and draw a diagram when he disassembled the console and removed the switches. As long as all the pieces are there it can be put back together properly.
    What I never heard was that foglights were ever an option whether the GTC or GTS. My dad had a GTS and as you said the second from the right toggle was marked "X". My GTC was "R" to activate the rear window defroster. I don't think Ferrari offered the foglight option. Always willing to learn something new.
    Somewhere I have a wiring diagram for my GTC. I had a completely new harness made when I had a end to end mechanical restoration performed on my car a few years back.
  8. suleyman
    suleyman Rookie
    36
    PNW
    Much appreciated!
  9. Wheels1
    Wheels1 F1 Rookie
    2,678
    Grant
    Re 330 head lights.
    Please can anyone tell me if they should be Carello as I have seen some with H7 lens ?
