Buy
330 GTC shock replacement
Discussion in 'Technical Q&A' started by jselevan, Mar 4, 2004.
  1. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,870
    I am helping with the replacement of the 4 Koni's on a 330GTC. Help is appreciated. There is insufficient clearance on the rear to remove the lower shock bolt without splitting the upper A-frame. Is this the correct procedure? Your experience is greatly appreciated.
    Jim S.
  3. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    Jim S.
    The easiest way is to remove the upper outer wishbone bolt that goes through the rear hub assembley, this will then allow the hub to be moved away enough to enable removal of the bolt
    MW
