330GT carpet | FerrariChat
330GT carpet
Discussion in 'Vintage (thru 365 GTC4)' started by DBR328&330, Oct 2, 2013.
  1. DBR328&330
    DBR328&330 Formula Junior
    May 31, 2001
    605
    Winchester, VA
    Daniel Reese
    Hi. My Series 2 1966 330GT needs a new drivers side footwell carpet. The one I have now is a piece of junk replacement piece. Can someone post a picture of how it should look? Does it have a heel pad and if so is it rubber or carpet? The car has chocolate brown carpets.
    Thanks!
  2. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,685
    NJ
    Peter
    Dan -- the original carpet does have a footpad and it is rubber. From memory, the rubber has lines going through it that are parallel with the length of the car. I will try to snap a photo, but probably won't be for a couple days.
  3. DBR328&330
    May 31, 2001
    605
    Winchester, VA
    Daniel Reese
    Peter,
    Thanks. I look forward to the photo.
    Dan
  4. John B
    John B Formula 3
    May 27, 2003
    1,564
    NJ
  5. sam231
    sam231 Formula Junior
    Aug 5, 2004
    569
    RI
    DAn, you might check with Kerry Chesbro or Tom Yang too.
  6. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,685
    NJ
    Peter
    #6 peterp, Oct 5, 2013
  7. DBR328&330
    May 31, 2001
    605
    Winchester, VA
    Daniel Reese
    Peter,
    That is most awesome and VERY helpful. Thank you so much!
    Dan
