PPI Question | FerrariChat
PPI Question
Discussion in 'Mondial' started by westyguy, Oct 19, 2011.
  1. westyguy
    westyguy Formula Junior
    Apr 27, 2009
    252
    Huntsville, TX
    Steve
    What sort of cost and time in shop should one expect on a QV?
    Thanks,
    Steve
  2. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    Here's a write up that I found to be helpful:
    The PPI
    Buying a performance car can be a little different to buying a 'daily driver'. The process is essentially the same but the key point is the stakes are a great deal higher. Get into a car that has problems and you'll need deep pockets. The Pre-Purchase Inspection is a key safeguard against this.
    What makes a good PPI, and who does it?
    You should be getting someone independent to carry out a PPI for you. The cost can be around £250 or $400 US Dollars for an afternoon's work but the expense is well worthwhile. Many people look upon having to walk away from a car that fails a PPI as a negative experience, but in reality the opposite is the case. You've not got yourself a car but you've avoided a whole bunch of grief and you've done the right thing.
    Most often, PPI's are carried out by Ferrari specialists or Ferrari Main Dealers. It is not normal to have a non-Ferrari garage carry out a PPI because they may not have the experience that is required to distinguish a bad car from a good one.
    PPI Checklist
    As an example, the PPI on my own vehicle covered the following checks:
    Side lights
    Headlights dip
    Headlings main
    Foglights
    Brake Lights
    Hazard lights
    Indicators
    Panel Lights
    Reverse Lights
    Interior Lights
    Door Lights
    Aerial
    Stereo System (and whether CD fitted)
    Wipers
    Screen Washers
    Horns
    Window Operation
    Cigar Lighter
    Air Conditioning
    Heater Controls
    Instruments
    Petrol Cap (these sometimes stick)
    Boot Light
    Engine (includes a compression check)
    Gearbox
    Final Drive / Axle
    Clutch
    Steering
    Suspension
    Brakes
    Handbrake
    Cooling Fans
    Coolant Leaks
    Engine Oil Leaks
    Exhaust System (including bypass valve)
    Exhaust Emissions
    Door Locks
    Door Seals
    Window Channels
    Seats
    Seatbelts
    Interior Trim
    Roof (Sipder / GTS)
    Exterior Finish
    Tyre Tread
    Wheels
    Underbody
    Chassis
    It is normal for a compression check to be offered as an optional part of a PPI. It is important that you get this as it gives key information about the state of the engine. You should get 8 readings from the compression check; one for each cylinder. Expect a good set of values to be around the 180-190 PSI mark. Anything much below 170 means the engine is beginning to wear a little too much. You are also looking for good balance across all cylinders. If one is low and the others are all roughly equivalent and much higher, there is clearly something wrong.
    Don't forget also to consider having an HPI check carried out to determine whether the car has any finance outstanding. This is especially key if you are buying privately.
    At the end of a well done PPI you should get a written report on the vehicle, with any recommendations as to work that should be carried out. This can in turn be used as a bargaining tool if the main mechanicals check out. As well as performing static checks they should also have driven the vehicle and should be able to tell you how it feels - whether it drives well or not in comparison to the other vehicles they have tested or driven.
  3. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,101
    PB County, Florida
    Jerry
    As a point of reference, I spent $500 at a very well known south Florida Ferrari specialist when I looked at a t coupe the end of last year. Included a reasonably detailed written report as well as a phone conversation for mental impressions.
    Well worth the expense IMHO.
    Regards,
    Jerry
  4. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,101
    PB County, Florida
    Jerry
    duplicate post
  5. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    I spent almost that much back in 2008 on a black t Coupe in Jupiter; hope yours was a different and better car.
  6. jjmalez
    jjmalez F1 Veteran
    6,690
    Northern Illinois
    Joseph
    PM sent
    Joe
  7. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,101
    PB County, Florida
    Jerry
    Thanks. Although black/tan has always been a favorite combo, this was not.
    The car drove well according the Ferrari specialist who checked it out, but it needed some current maintenance (even though some had been done within the last 2 years) and a fair amount of "not now, but the next time you open her up for a real major" type of stuff.
    On balance this was not the right one for me, so I passed. I believe the car sold some time ago and the seller was a straight shooter too. Hopefully, the new owner is enjoying the car, as there are not too many t coupes around......
    Regards,
    Jerry
  8. Akram
    Akram Formula Junior
    Aug 17, 2009
    352
    Clive, Iowa
    Ray Salloum
    Looking at a 1992 Mondial for about $30K with as many miles. Never had a timing belt or clutch job. Can anyone tell me the price on the clutch and belts jobs.
  9. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    Being that its a 92 t, it will need an engine out ($2k), @ 30k miles, its due for a major service (see thread above for details ~$3500) + new clutch $2k. I would say you are looking at somewhere in the neighborhood of $7500 at a specialty shop + what ever else they will find as they look closer at hoses, water pumps, etc. Now at a full fledged Ferrari dealer, cross your chest and say your Hail Mary cause its gonna be $10k or more. I'm actually learning how to do my own maintenance because the cost is scary and I enjoy tinkering with stuff. Good luck!
  10. F1wannabe
    F1wannabe Karting
    Sep 27, 2011
    143
    I am flying to Miami next week to take a look at a 1989 Mondial T. Would you recommend the "well known South Florida Ferrari specialist" mentioned in your post? Name? Any other recommendations from others on FChat for a Miami area PPI? thx
  11. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #11 Wade, Oct 26, 2011
    Don't know who's referenced in the above but Numero Uno is Tim Stanford in Ft. Lauderdale - 954.764.7824
  12. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,101
    PB County, Florida
    Jerry
    Yup, that's the one!!! Top notch and a pleasure to deal with. While he did provide a written report, the phone conversation was even better!
    Regards,
    Jerry
