328 auxillary air valve | FerrariChat
Discussion in '308/328' started by PT 328, Nov 5, 2011.
  1. PT 328
    PT 328 F1 Rookie
    4,019
    #1 PT 328, Nov 5, 2011
    I have had some recent cold start problems with the engine stumbling and wanting to die until it is warmed up. After it is warmed up it runs fairly well. This morning I pulled the AAV and put it in the freezer for 15 minutes and the opening is as noted in the pictures below. I then placed it in the oven for 15 minutes at 225 degrees and the door only sightly closed from the position noted in the pictures. I am fairly certain this is my cold start problem.
    Edit: The test and pictures were performed/taken after the AAV was cleaned and lubricated.
    Questions:
    1) Do the pictures indicate a correctly positioned AAV door position when cold? I am assuming it should be fully opened.
    2) If not, where do I find a replacement or can Larry Fletcher rebuild these as well?
  2. Constance
    Constance Karting
    Apr 10, 2009
    213
    Kembs - France
    Constance
    Hi,
    Check the electrical resistance of the heating element in the valve, and if you get power on the connector when you start the engine.
    You can also connect the valve to the battery with two wires and check if the valve moves after few a few minutes
  3. jcinflorida
    jcinflorida Formula Junior
    Oct 24, 2009
    331
    Melbourne Florida
    I recently replaced the AAV in my 308 QV for similar reasons. My cold idle was steadiy decreasing over a period of months until it was down around 500 rpm. My AAV when removed from the freezer was only about 15% open. I ordered a replacement from
    Rock Auto and that did the trick. It was about 35% open when in the freezer if that helps.
    Not sure about the 328's AAV positions. Generally though it
  4. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,370
    Mine is more open than the one pictured from the freezer & it closes completely in the oven.
  5. Steve Magnusson
    27,021
    #5 Steve Magnusson, Nov 5, 2011
    No, I don't think that that's a requirement/goal of the design. It is important that it is fully closed when warm so yours seems NG (and, if your car was warm idling well with the AAV stuck open, you'll probably need to do some tweaking when you correct the situation).
    They aren't as complicated/expensive as a FD or WUR -- just try searching using the 10 digit Bosch PN at www.importeccatalog.com, www.rockauto.com, www.autohausaz.com, www.pelicanparts.com, etc..
  6. PT 328
    PT 328 F1 Rookie
    4,019
    Thanks for the replies. I will check the current coming to the aav to be sure.
    Steve, unfortunately the sites you noted are not finding the part number. I wonder if there is a cross reference number. I may have to check with Bosch directly.
    Looks like the car won't leave the garage for some time.
  7. Steve Magnusson
    27,021
    #7 Steve Magnusson, Nov 5, 2011
    My bad for trivializing finding one -- I'm now recalling that the 328/3.2 Mondial AAV 0280140229 was expensive unobtanium a few years ago.
    Can you post a picture of how your AAV mounts? Is it a super odd-ball thing to help transfer the coolant tank heat into the body of the AAV?
  8. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    #8 pippo, Nov 5, 2011
    Dan,
    If you get into a jam finding one (as in - you CANT find one), let me know, as Ive made a home made one for an L-Jet Bosch fuel injection system (not sure if thats what you have), out of a water heater valve and bicycle cable (I dont have a 328, though, but Bosch L jet is the same, I believe). Yes, its "manual", meaning you will have to "choke" the cold engine on every start, but big deal, right? Thats what all of us did before automatic chokes years ago.
    Mine woorks every time, period, and no depending on resistivity/etc to operate it.
  9. PT 328
    PT 328 F1 Rookie
    4,019
    #9 PT 328, Nov 5, 2011
    Steve the AAV mounts to the underside of the expansion tank via two bolts. You can see the two holes for the bolts in the pictures below. Who would have thought this would be this big of a nightmare to find.
    The second picture indicates the bottom of the AAV that sits flush against the underside of the expansion tank.
  10. PT 328
    PT 328 F1 Rookie
    4,019
    Thanks Pippo, I might be hitting you up for your design.
  11. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    Any time, Bro!
  12. Steve Magnusson
    27,021
    #12 Steve Magnusson, Nov 5, 2011
  13. fletch62
    fletch62 Formula Junior
    Mar 8, 2004
    333
    Fairhope, AL
    Larry Fletcher
    Contacting Bosch? This is like contacting the CIA, if you don't know someone or the structure of the Co. you will first get the runaround and then a load of BS and if you are lucky they will give you to tech support where they will give you my phone number. I will be talking to the head of the dept. that is in charge of older car parts on monday the 7th. This is at the HQ in Karlsruhe, Germany. I will find out what is a good replacement or if they will make a run of these for us.
    Larry Fletcher
    www.cisflowtech.com
    251-929-3771
  14. PT 328
    PT 328 F1 Rookie
    4,019
    Steve, thank you very much for spending the time to try and source this. I will poke around tomorrow morning and see what I can come up with in addition to your find. I may end up being a guinea pig on this part.
  15. PT 328
    PT 328 F1 Rookie
    4,019
    #15 PT 328, Nov 5, 2011
    Larry, I received your PM. I will sit tight until the 7th and give you a call shortly after. Thank you in advance.
  16. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Anyone opened one of these up by drilling out the rivets? Maybe just needs a cleanout inside?
  17. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    Im sure someone here has and l seem to recall seeing pics as well.
  18. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,370
    AFAIK its just a bimetalic strip in there so either its clogged up as you suggest or its just got fatigued & broken. My bet would be the latter on this one but no harm squirting a load of WD40 in there to see if anything comes out. I did that with mine when I took it off & its suffered no ill effects from it.
    ISTR the other test is to connect a meter on the electrical connection & make sure that there is a circuit there - if its open circuit then ISTR Rifledriver saying it was toast & wouldn't work properly. I guess there must be some kind of heater element in there maybe?
    Brooklands likes this.
  19. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Larry, see if they will do a run on WURs too. It was posted here that German law requires parts be supported for 30 years, might ask them about this?
  20. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    It is a simple bimetallic strip so it closes to lower engine speed as it gets warm. That;s why these are typically mounted somewhere where they get warm and have a big mounting bracket for a good heat transfer. You'll find them mounted to the block or head or water tank depending on the car. There is a small heater to warm the bimetallic strip so that they close with running even in very cold weather, etc.
    This device's part number may be special to your car, but he AAV is not. There are 10 million+ AAVs out there and they are all remarkably similar. The only real differences are tube diameter and mounting foot. If I couldn't find exactly the right part number I'd grab one off of a Porsche, Jaguar, Mercedes, Volkswagen, etc and hook it up. I'd do that before making a cable operated version.
  21. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Yes, I bench tested mine a while ago and it goes from completely open to completely closed with 12 volts applied in a couple of minutes.
  22. PT 328
    PT 328 F1 Rookie
    4,019
    For s**** and giggles I cleaned the unit and sprayed some WD40, cleaned and tested the connections, put it back in and experienced the same problem. I also spent 3 hours of my life this morning trying to locate the part on the internet or at least a cross reference number. Thank god we fell back an hour last night so I conceivable only wasted 2 hours. I found some that may work but I want to speak with Mr. Fletcher first regarding his replacement.
    Once I have a new one installed and working appropriately I will crack open the new one and post what I find.
  23. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    FWIW, as far as Ive been told in years past, theres no way to "repair" a L jet (or other "jet") AAV's bi metallic strip. You have to throw it out/make a new one/get a new one.
  24. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    If it does not perform with the "freezer" test, its no good.
  25. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I don't think there is any black magic with bi-metallic strips they can be found in lots of devices. I think the problem with restoring may be with the heating elemants. IMHO.
