Weber accel pump cam / Air cleaners yet again / Ansa resonators | FerrariChat
Discussion in '308/328' started by snj5, Oct 11, 2004.
  1. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    More esoteric Weber and airbox airflow stuff
    While wondering why I've always had the rather large blue puff when rapidly opening the throttle, I talked to Steve at Pierce Manifolds. Apparantly the 40 DCNF-12s have a huge gorilla accel pump cam length of 10.3mm when compared to the rest of Weberdom where the max is usually 3.5 mm or so. That would explain the dump in my A/F to < 10 on tip-in as well. Steve's looking for the original Ferrari specs on the pump cam. My bleed-back and pump jet are already about the same. Anybody have that spec or can measure?
    Also have a sl chunky rich area in the mid range, so will be going from F-24s to F-36 emulsion tubes.
    Despite intensive psychotherapy, I'm still obsessed with my 20hp+ loss on the dyno due to the airbox and K&N when compared to open air horns. Even with the cool air factor, my last stand is going to be to try larger seperate filters for the Webers, which Steve thinks will make a big difference. It's already been shown by another thread that the overpressure due to ram is negligible. He said to point the cool air duct toward the carbs to minimize the ambient heat. As far as surface area, the stock fiter is about 11.5 X 14 X 1.5, yielding an approximate filter area of 76.5 square inches. Each of the 4 separate air cleaners is 4.5 X 7 X 2.5, yielding an individual surface area of about 55 sq. inches, or a total of about 220 square inches. I do realize there are flow differences due to aggregate steady verses pulsed separate vacuum, but it's worth a shot at about $100 for the four filters, even if I recover half of the lost hp. If this works, the numbers may be applicable to my 308 carb buds. It will certainly make servicing easier in any event.
    Any personal experiences, qualitative or preferably quantitative , happily solicited.
    And on a final note, installed quad Ansa resonated tips on the end of the Dynomax muffler and the tone smoothed out immensely - very nice at cruise and whompin' when you open the throttle.
    best
    rt
  2. thecarreaper
    thecarreaper F1 World Champ
    18,165
    Savannah
    i am going with these seperate airboxes from Pierce Manifolds with K&N filters and a better ignition system, if i ever find the right GTB. the seat of your pants feel and the sounds the carbs make through these are worth it!
  3. BigTex
    79,420
    Houston, Texas
    Bubba
    Well, maybe...but what about the loss due to hot underhood make up air vs. cool outside air from the RH door scoop??
    Discounting any 'ram' effect, as negligible.......
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Exactly right - this is the rub that I've been struggling with.
    Even calculating resulting loss from a 40+ degree increase in ambient air temp, the increased flow should more than overcome - certainly wouldn't be losing 20 hp in any event. Will be blowing the air from the scoop at the new filters as well. At speed, I do not think the temps are going to be that different as the engine bay is so wide open to below (this is a Mondial) since the removal of the FI and the new exhaust is more open.
    In addition, I think there is some reversion wave pressure thing going on, but can't be sure, and I may be all wet.
    Will install this weekend and dyno thereafter. All opinions welcome.
    best
    rt
  5. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Exactly what am I measuring as less than 10mm?
    The lift of the cam, or the ramp length or ?
    I've been fond of the idea of making a ram that connects to the side scoop then seats in an assembly that would be attached to the hood. That would then seat on an airbox base with, obviously, long, soft gaskets (I'm thinking of rubber sideskirts you can (or used to be able to) buy from JC Whitney that were similar to those used on late 80's Shelby Daytonas). That way you'd have an airbox of maximum height, that opened up when you opened the rear bonnet so you could see your sweet carbs, and would give you cool air, and maybe even maintain your ram effect.
  6. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    10mm of lift acting on the lever arm of the accel pump.
    Similar to your idea, I was thinking of a shroud like the original 4 cam Carreras.
    best
    rt
  7. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Russ
    If I would have seen this yesterday I would have measured them when I had the air box off (putting in F24s...).
    BTW, my wideband is showing idle at 14.4:1. Doesn't burn the eyes either. I'll find out this week how it runs (it was fine at WOT, stumbling at intermediate with F36s).
    After 2 hours of balancing the carbs/reconnecting all the linkages, it was interesting to see the impact of turning in the mixture screws in or turning them out showed richening of the mixture on the WB.
    Two explanations possible. I favor #2,
    (i) the WB isn't providing me with a good signal [always a chance] or
    (ii), fattening up the mixture would [obviously] cause a rich condition, but turning in the mix screw causes the motor to slow, decreasing the airflow as the motor slows and richens the mixture as a result...
    Strange but true?
    Philip
  8. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    If I followed correctly, you're saying that going in or out both showed the mixture getting richer?
    What kind of WRO2 to you have, and where's it mounted? How does it see both banks?
  9. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Don
    I adjusted #5. The (TechEdge) UEGO WBO2 was reading the front bank (5 - 8). You have the correct interpretation of the reading.
    I have a separate bung in the connection pipes into the Tubi (just post collector) for 1 - 4 and 5 - 8. Moving it involves pulling the sensor out, installing a plug, removing the plug in the other bank and installing the sensor etc.
    Philip
  10. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    The difference between spot on and too much was 1/4 turn of the (euro tapered) mixture screw...
    One of the reasons it may be so sensitive on my car is the lack of vacuum (typ 2 - 3 inches) at idle from the lumpy cams.
    Philip
  11. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I installed the 'Ferrari' accel pump cams today recommended by Pierce to fix my blue smoke on throttle application and momentary very rich mixture (A/F<10) at tip in. The 'Ferrari' cams only go up a third of the way as the stock DCNF-12s (3mm vs about 10) that I used in the retro-fit to the 3.2.
    Well, not even close.
    Took off the carbs and put the 'Ferrari' accell cams in and guess what - it still blew blue on throttle application from idle but now went totally dead coming through about 3000 rpm starving for fuel.
    Soooooooo...back off come the carbs again (taking 1/3 the time of the first change)and the old cams go back on and we are back to where we started.
    I did install the separate air boxes replacing the stock 308 airbox. and while I do not yet know if it helps, it does look great and makes it 100% easier to get around and work on. I'll send a photo to anyone that wants to see what they look like. It is rather impressive - and did I mention the sound?
    See - I even report what doesn't work!
    Tomorrow will install a Holley Red fuel pump and regulator and rear 11 mm wheel spacers from Hill engineering.
    Waiting on the F36 emulsion tubes.
    Have decided to go to 50 idles from 55.
    Will install temp wideband A/F in car to watch as I drive next weekend as well.
    Have a set of chrome wire meshed 2.5" 40DCNF velocity stacks, as new from Superformance, if anyone is interested. Best for track use.
    more later
    rt
  12. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Hey Russ,
    I asked Mike about the richness on the overrun I am experiencing. His thought was the GAM plug air bleed may be too small.
    Back to the books!
    Philip
