348 - 348/355/360 wheel offset | Page 3 | FerrariChat
348 348/355/360 wheel offset
Discussion in '348/355' started by Ferrarium, May 19, 2019.
  1. 72GMC
    72GMC Karting
    Aug 15, 2006
    157
    Calgary, AB, Canada
    Paul
    I found the answer, lots of threads to read.
    Presuming the 360 Starfish hasn't been machined before, it should be using 52mm bolts.
    7mm shave = 45mm bolts
    12mm shave = 40mm bolts
    17mm shave = 35mm bolts
    I found a set of Titanium bolts on Kijiji, Montreal, asking $250 CAN ($195 USD)
    Used, quantity 20x
    I phoned them up, fellow said it's a 52mm shank.
  2. ChoonHound
    ChoonHound Formula 3
    2,275
    Saint Michaels, MD
    Lucas
    I find this really really hard to believe assuming you had factory diameter tires and the car wasn’t lowered.
  3. m.stojanovic
    m.stojanovic F1 Rookie
    3,331
    Serbia - Niš
    Miroljub Stojanovic
    I had standard wheels, tyres and ride height. Driving out of my condo, I have to go over a speed bump while turning rather sharp left. The left wheel goes over the bump first and, even though I went very slowly, that was when it rubbed (happened twice although I tried to change the angle at which I was "attacking" the bump). Before, and after I removed, the 15 mm spacers, I had no problem going over the same bump in exactly the same way.
    Another member's car with 15 mm spacers at front:
  4. ChoonHound
    2,275
    Saint Michaels, MD
    Lucas
    This car, and others like it, have an 8.5 et36 front wheel (the equivalent of the factory 7.5 on a 26mm! spacer)and, iirc, 355 spec tires.
    This car is lowered on H&R springs, no fender rolling, and 8.5” front wheels with an et of 40 — essentially the factory wheel on a 22mm spacer. Tires are 235/40-18
