348 ABS Computer Clarification | Page 2 | FerrariChat
Discussion in '348/355' started by pnicholasen, Mar 29, 2018.
  1. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    bjwhite, you're my hero. I just got an ABS Computer for the Milano off eBay for cheap. Price so good, nice to have for a spare.
    Sent from my VS990 using FerrariChat.com mobile app
  2. m.stojanovic
    m.stojanovic F1 Rookie
    3,332
    Serbia - Niš
    Miroljub Stojanovic
    Further clarification regarding the "|" marked ("not used") pins. I had a look at these pins on the Lincoln ABS computer - I could see where about half of the "|" ones go and can confirm that they are actually connected to the circuitry; the other half, the connection of which is not possible to see, are probably also connected. So, it seems that the indication "|" on the sticker is to show what pins are not used by the particular car and does not mean that the computer does not have functionality for them. So, it appears that Lincoln, Alfa and 348 ABS computers can be interchanged as far as pin functions are concerned. Jaguar XJS has exactly the same usage of the ABS computer pins as the 348 so it is certainly interchangeable. What differences they have in the programming of the Intel processors is not known but I don't think they are major.
  3. m.stojanovic
    3,332
    Serbia - Niš
    Miroljub Stojanovic
    Prices of alternative new ones:
    Lincoln $145 (Ebay)
    Jaguar XJS $1,100 (SNG Barratt); even this is not too bad compared with the Ferrari prices
  4. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    I scored an Alfa one for $40.00. We'll see if it works.
    Although the Lincoln ABS computer seemed to work fine, the guts inside certainly looked very different. It will be interesting to see what the insides of the Alfa unit look like. I'll report back.
  5. m.stojanovic
    3,332
    Serbia - Niš
    Miroljub Stojanovic
    I know you are happy because it says "Centralina". You don't want on your Ferrari one which says "Steuergerät für ABS" like the one on the picture. VW Golf MKII, Jetta ABS computer is another interchange possibility as these cars also had Theves Mark II ABS system. I have attached the diagram as pdf.
  6. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    No worries...just assume it was made for the Italian market up near the border with Switzerland. They probably speak a little German there. Close enough.
  7. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    Great thread!!!!
  8. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    SoCal LA/OC/New Mexico
    Tim Dee
    Yes these are life cycle 1 abs units. I do know this is the later versions of cycle 1. I know speed / weight were very important inputs
    Newer units are insanely complex, when the engineers read the data they go behind locked doors giving me no privy to whats involved.
    I can tell you with the latest cycle abs even turning on the windshield wipers chances the algorithm quite a bit.
    Thats why I love these cars 348/355 so much we get to stooge them with rubberbands and paperclips and get 90+% correct
    xo
  9. seabass23
    seabass23 Karting
    Nov 6, 2016
    158
    St Albert, Alberta
    Matt
    Where are these units installed in the Lincoln, Jag, and Jetta? I hit the Pick 'n Pull every once in a while and I'd like to grab one of these. Are they under the dash?
    Sent from my Pixel XL using Tapatalk
  10. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,808
    Seattle, WA
    Brian White
    In the Alfa Milano, it’s in the left hand side of the trunk behind a trim panel. Just in case you happen across any Milanos, doubtful, but still.
    The Verde and the Platinums got ABS. The Silver and Golds did not.
  11. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Looks like in the Jag the ABS Computer is next to the left rear wheel well behind an acess panel in the trunk.
  12. m.stojanovic
    3,332
    Serbia - Niš
    Miroljub Stojanovic
    Yes, here it is (original strap replaced with much longer lasting zip-ties):
  13. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,275
    MA
    Is there a market for the correct Ferrari part? Had the 348/355 ATE unit on eBay for $200 and the 328 version for $150. Appeared to be no interest!
  14. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    That seems hilariously cheap, but I guess it's a question of timing. If you try to sell it when someone desperately needs one, you're golden, but if no one needs one, then no one is perusing the ads, so it won't sell.
  15. m.stojanovic
    3,332
    Serbia - Niš
    Miroljub Stojanovic
    Just received the Jag ABS ECU that I bought. Its internals are very similar to those of the 348 except that Jag's unit has two extra small microchips where the 348's PC board has empty holes and links for these microchips and, instead, has some jumpers between the microchip holes. The Jag's ECU is probably just an improved version? (the 348's ECU on the picture is manufactured in 1986 and the Jag's in 1989). Or it could be to do with the "not used" ECU pins (which are exactly the same on the 348 and Jag ECU-s) and for the 348 ATE did not include the two chips as there is no use for them but for the Jag, ATE did not bother omitting them. The numbers on the Intel chips are very close: 348 - 10.0990-9524.1 Jag - 10.0990-9521.1.
    Qavion, boxcarracer and SoCal1 like this.
  16. m.stojanovic
    3,332
    Serbia - Niš
    Miroljub Stojanovic
    One correction: the 348 ECU is 1993 (I saw, on the round year chop, "86" looking at the not so clear picture).
  17. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,808
    Seattle, WA
    Brian White
    So in the Alfa world, it is commonly noted that while Alfa used the same Teves ABS system, they did not elect to implement the on board diagnostics system that was optional on the Teves controller.
    I wonder if neither Alfa nor Ferrari took up this option, but that Jaguar did—meaning that you could do diagnostics to the ABS controller from the car’s dashboard displays or other computers. Hence the extra chips.
  18. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    So, here's the outside and guts of what is supposed to be an Alfa Milano ABS Computer. Exterior looks pretty good, but internals different. Looks like the Jag unit comes the closest by far to matching up with the official 348 unit. I'm guessing the Alfa unit probably works ok like the Lincoln unit did, but the Jag unit would definitely be the preferred alternative. Image Unavailable, Please Login Image Unavailable, Please Login
  19. m.stojanovic
    3,332
    Serbia - Niš
    Miroljub Stojanovic
    According to the wiring diagrams, the 348 and Jag have exactly the same used (and not used) pins of the ABS unit and Jag also has similar diagnostics socket as the 348. So it appears that Jag does not have any on board diagnostics but same way of diagnostics as what the 348 has. The Jag ABS unit is earlier production than the 348 so it is possible that ATE omitted the two chips (cost saving) in the later 348 production as these chips are either not used or ATE found a way to do without them.
  20. m.stojanovic
    3,332
    Serbia - Niš
    Miroljub Stojanovic
  21. m.stojanovic
    3,332
    Serbia - Niš
    Miroljub Stojanovic
    These are the Intel chip numbers:
    348 10.0990-9524.1
    Jag 10.0990-9521.1
    Golf 10.0990-9523.1
    Alfa 10.xxxx-xxxx.x (Paul, can you read and insert the Intel chip number of the Alfa unit)
    Ford 10.0990-9601.1
  22. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    348 10.0990-9524.1
    Jag 10.0990-9521.1
    Golf 10.0990-9523.1
    Alfa 10.0990-9508.1
    Ford 10.0990-9601.1
  23. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Here's a close up of the Alfa sticker with the pin diagram. Don't know if it's of value or not
  24. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
  25. m.stojanovic
    3,332
    Serbia - Niš
    Miroljub Stojanovic
    Alfa and Ford units have exactly the same used and not used pins (as shown on their stickers) as well as practically identical arrangement of the internals. I can see that the two chips, to the left of the two long Intels, in the Alfa unit have different numbers than those in the Ford unit but probably have the same functions. The other chips, as far as I can see, carry the same numbers.
    Anyhow, different PC board arrangements and components do not mean that the functions (the functions of the connector pins) of the five ABS units are different - they are the same based on their ABS system wiring diagrams. The Golf MK2 unit has one large chip where the Jag unit has three small ones. Probably the functions of the three separate chips are integrated into one chip in the case of Golf.
    I am not, for the time being, going to plug in the Jag ABS unit that I have just to test it in my 348 as my original "Centralina" is fine. If anyone who is already using a non-original ABS computer decides to buy and try a Jag XJS unit (~$50-60), please inform on the results.
