hi someone know where to get body measurment for 348?
no i didin t find what i m looking for need Professional officiel measurment on body under the car in each corner ,front, rear ,top front in X ect ect
If Ferrari don't publish it and you need 'professional officiel measurment' then you need to specify what level of accuracy and what approval authority and what locations exactly Clearly asking here someone just to advise it will not be accurate enough
I know what you're after, Denis. For a "normal car" it would be available through a body repair facility with a frame alignment machine such as this: http://www.blackhawkcr.com/frame-measuring-vehicle-dimension-data.asp But I kinda doubt any of the frame alignment companies will have any data on the 348, although if you can't find it elsewhere it might be worth at least checking with the various frame alignment companies. Unfortunately, I can't help any more than that but would be very interested if you find anything.
Only Ferrari approved repairers will have factory jig brackets (Carbench). You'd need to contact your nearest approved repairer, there's not may of them !
