348 Brake light | FerrariChat
348 Brake light
Discussion in 'Technical Q&A' started by airbarton, Nov 17, 2003.
  1. airbarton
    airbarton Formula 3
    Nov 11, 2002
    1,462
    Kennesaw, Ga.
    Chuck Barton
    The brake failure light is comming on in my 1990 348ts when I step on the pedal. I have already checked the fluid level and inspected the brakes, the pads and rotors are fine. The brakes feel normal so I do not were to start. The manual says the light comes on when fluid level is low or when the pressure to the booster is low. The light does not come on all the time and it does not stay on after I release the pedal. I can't find anything in the archives on this either. Any suggestions?
  2. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,127
    Bay Area Calif.
    Dave
    Make sure the float in the brake fluid reservoir has not sunk. Try it with the wires disconnected to find out.
  3. Mule
    Mule F1 Rookie
    3,744
    Alaska
    Mule
    I had the same problem on my 1989 328. It is on the old site, but the solution was to overfill the resevoir, and let the excess flow out after a long drive. Others who voiced recommendations said that even though the resevoir reads full, the sending unit in the resevoir needs to be completely submerged.
    Not a sure fire fix, but it worked for me. I filled the resevoir as much as I could, then after an hour long drive, it left about a half a pint on the ground from the overflow hose.
  4. FAD2BLK
    FAD2BLK Karting
    Nov 5, 2003
    54
    Pacific Northwest
    Dave
    Just an idea.....
    I recently had new brake pads installed on my 348 Spider. They informed me that a brake sensor wire housing at a front wheel was cracked and that a grounding wire was broken. When I would brake hard the light would come on in the dash. Problem is now fixed.
    Possibly a place to start looking...
    Dave
