348 CAM Cover re-paint | FerrariChat
Discussion in 'Technical Q&A' started by jkuk, Feb 20, 2004.
  1. jkuk
    jkuk Formula Junior
    Nov 3, 2003
    259
    Wirral, UK
    John K
    Hi everyone
    My 348 is about to go in for an 18K service/belt change, and I suspect a renew of the cam seals.
    My question is , as the cam covers need a refresh of red paint, should I collect them from the garage whilst servicing the car, or can the covers be removed later, with the engine fitted, when I have more time to do it.
  2. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    No better time than now. Roughen up the casting a bit so this coat of wrinkle paint sticks. The 348's were painted over the smooth pressure castings and that is why the paint is pealing. If the original paint is in good shape, a light spray with Krylon Banner red over the wrinkle paint gives nice results.
    Dave
  3. Ksullender
    Ksullender Formula Junior
    Sep 3, 2003
    887
    Post pictures of the result before and after if you decide to do this. I'd love to see them.
  4. sindo308qv
    sindo308qv F1 Rookie
    Nov 1, 2003
    3,575
    miami.fl.
    sindo
    Ken, I did it to my 308 a month ago when I had it serviced, came out gorgeous. A place in Ft. Lauderdale called Rhino Tech, they've done several for Tim Stanford.
  5. ricrain
    ricrain Karting
    Nov 1, 2003
    213
    Dallas Area
    Ric
    It's certainly easier to do with the engine out, but the cam covers can be removed in the car.
    I just had my 348 cam covers powder coated. The power is wrinkle-red from a supplier named "Tiger". Here are some shots of the covers.
  6. jkuk
    jkuk Formula Junior
    Nov 3, 2003
    259
    Wirral, UK
    John K
    RicRain.
    I must say that your engine looks fabulous.
    Powder coating looks like the way to go.
  7. ricrain
    ricrain Karting
    Nov 1, 2003
    213
    Dallas Area
    Ric
    Thanks for the comments.
    I received a few PMs, for more pictures and/or info. This is a '91 348 ts motor with 45K miles on it. The valve seats were clogged with carbon and had to be "refreshed". As it turns out, I needed five new valves (slightly bent).
    Here's a list of what's been done:
    Heads rebuilt: 5 new valves, refeshed all valve seats, adjusted valves (thinnest shim is 3.75mm and typical is 3.90, so valve seat cutting was minimal).
    New outer CV joints: both outer joints showed too much wear for my comfort so I replaced them and repacked the inner joints. 4 New CV boots.
    Sent the injectors out to be checked and rebuilt. Two were leaking and two more had poor spray patterns.
    Replaced ALL paper gaskets, all copper gasksts, o-rings, oil seals, exhaust gaskets, etc.
    Replaced the oil-chain tensioner (it was partially broken!).
    Replaced front timing cover bearings.
    Disassembled and rebuilt the transmission: 2 new bearings, one new syncro, replaced all "detent" springs.
    Disassmbled the differential and "flipped" the friction surfaces.
    Replated various parts, including suspension hardware.
    Powder coated the cam covers.
    Powder coated the transmission bracket.
    Replaced cam belts and "degree" cam'd the motor.
    Replaced accessory belts.
    Had the compressor rebuilt.
    Replaced the emissions check valves on the exhuast (4).
    Cleaned and repainted the subframe.
    Disassembled and repacked the flywheel.
    Replaced various hoses (coolant & vapor hoses).
    ...all this because my compressor had a ticking bearing in the clutch! :)
  8. ricrain
    ricrain Karting
    Nov 1, 2003
    213
    Dallas Area
    Ric
    A few more pix:
  9. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,263
    MA
    Ric, very interesting. I am in the midst of a major service and transaxle rebuild on my 348 spider. Transaxle roller bearing that supports the input shaft failed. Replaced all the bearings, 2 synchros etc. The dreaded "while I am there" disease reared it's ugly head and I did a leakdown test. Unacceptable numbers, leaking from the exhaust system. Pulled heads, excess carbon build up as you describe. Not surprising when you look at the porous castings! Waiting for the "keeper" removal tool on back order from Snap On to remove the valve train etc. Thanks for posting the pictures and details of your 348 service.
  10. billh
    billh Karting
    May 2, 2002
    208
    central mass
    Bill Henderson
    wow. Ric. those pics are like porn!!! got any more??
    How did you get the cad plating back on the hardware? did you clean up the block with something like Scotchbrite?
  11. PeterS
    PeterS Four Time F1 World Champ
    46,681
    85395
    PeterS
    I'll have to get my mechanic to post pictures of my valve and cam belt covers that have been red powder coated9Still in the shop). I flat-filed all of the raised lines, numbers and the Ferrari lettering. These covers look drop-dead gorgeous!
  12. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    Wow that looks great. If I didn't have red plug wires I would have painted mine red too.
  13. MarkCollins
    MarkCollins F1 Rookie
    Jul 2, 2002
    3,202
    South England
    Mark Collins
    Mark
    they don't look too bad with the Red Caps
