348 Cam drive update? | FerrariChat
Discussion in 'Technical Q&A' started by Bob308GTS, Nov 22, 2003.
  1. Bob308GTS
    Bob308GTS Formula 3
    Sep 26, 2001
    1,148
    Aurora,IL
    Bob Campen
    Got a buddy looking at a 91 348, on the invoice copies he sent me, lists a timing chain update done along with timing belt and top end overhaul. It lists they found the center pulley broken as the cause for the valve damage.
    I had not seen anything reguarding a T-chain update before, what was
    changed with the " update "
    BTW total bill was $11,700
  2. ferrarioldman
    ferrarioldman Formula 3
    Jun 19, 2002
    1,029
    Summerfield, NC
    Tom Jones
    The bearing for the cam belt drive pulley, Guides and tensioner for the chain are the updated parts. I have heard of a broken drive pulley but have never seen one.
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,544
    Commifornia
    The Bad Guy
    Yes the factory updated the timing chain bearing in late 1990, I think. The old bearings weren't up to par. Byron just had his fixxed at FX performance, along with the timing belt and all that other good stuff. There is a cover behind the cam drive cogged pully, and the pully for the a/c and alternator. The chain is behind that cover running to the crank. What baffles me is, if they were gonna use a chain to drive the pully for the cam belt, why not just use a chain all the way? I guess sometimes that Italian passion over rules their comon sence. Knuckleheads.
  4. dapper
    dapper Formula Junior
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    Ernie,
    ...what and miss out on all that lovely cambelt change service revenue for years to come?
  5. Bmyth-FDC
    Bmyth-FDC F1 Rookie
    Oct 4, 2002
    2,742
    Southern California
    Byron
    Yes... my cam bearing failed while I was on the Buttonwillow track. It caused a large knocking sound in the entire front of the engine... this was an update that was supposed to be done in 1990-1991. In addition to this, my oil pump was not working properly due to a sticky oil pump chain - I think there was an update for this as well. I had my cam bearing and oil pump chain replaced, along with a full 30k engine out service - all done by FX Performance.
    -Byron
