348 Clutch design problem | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by ferrarifixer, Jan 6, 2006.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    Blasphemy!!!! Blasphemy you blaspheming heritic.
    Hahahahaaa. :p
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  3. Ricambi America
    Sponsor Owner
    The old cast iron ones right? Yes, I've not heard of them blowing their butts out either. The new ones? Yes! I think Peter and I discussed one on Friday too. Thankfully for folks who run the new aluminum TO bearing, there is a Hill Engineering alternative that is far superior (and less money) than the Ferrari junk.
    http://ricambiamerica.com/product_info.php?cPath=600_531&products_id=261280
    For reference, the OEM one costs $610.00
    -d
  4. fatbillybob
    Aug 10, 2002
    29,403
    socal
    Cool...I'll remember that next time I need one.
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Yeah, but where's the 348 5 speed version?!
  6. ronr
    ronr Formula Junior
    Oct 30, 2002
    813
    DFW, TX
    Ron
    #31 ronr, Jan 10, 2006
    Here is a better angle on the single disk clutch so you can see the part number. This is from my 91 model that "Sue" mentioned. This was the upgrade from the dual disk model. The previous owner put many hard track miles on the car and it did fine. I'm not sure if this is the same clutch he used, due to him having done a recent rebuild, but I think it is the same.
  7. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Man, update your profile from the 308!
  8. ronr
    ronr Formula Junior
    Oct 30, 2002
    813
    DFW, TX
    Ron
    Done. jeez! :D
  9. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Any update available on a potential 348 master cyl or clutch pedal stop improvement??
  10. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    Sorry, but I still havent recovered from your physics tutorial on oil pressure and filter problems, to take you seriously yet.
    I need more time, it's a great healer.
  11. gidge348
    gidge348 Formula Junior
    Dec 12, 2008
    343
    Perth West Australia
    Ian Wood
    Sorry to resurrect an old thread, but very interested in what "Ferrarfixer" had to say about the overthrowing of the 348 clutch, has anything more come to light?
    If not, just to save me pulling my slave and master cylinder to bits I was wondering if you can recall dimensions of these and how much you and your engineer calculate/estimate the overthrow to be?
    Been thinking of a few options if an "off the shelf" master cylinder is not available.
    1. Change the mounting position for the push shaft on the clutch pedal.
    2. Have an over sized stainless repair sleeve fitted to the cylinder and reduce rubbers etc to suit.
    3. Fit a larger bump stop in the base of the master cylinder if one is fitted, or if not put one in.
    4. Some type of mechanical stop on the pedal itself.
    Items 1&2 should increase the smoothness and control over clutch take up; items 3&4 would just be a safety measure.
    Not sure if any of these measures are practical or possible.
    But just because something is impossible, is not a good reason not to do it……
  12. Rifledriver
    37,340
    That theory was really only supported by one person and he is no longer here.
    I would not modify a car to cure a nonexitant problem.
  13. PAP 348
    Dec 10, 2005
    100,249
    Mount Isa, Australia
    Pap
    I can give you his phone number if you like so you can talk to him about it? :):)
    I talked to him about years ago and I wasnt really convinced either. Overthrowing the clutch was what was breaking clutch pressure plate fingers I think he said. :):)
    I have the complete service record for my car from brand new. My car has had major services every 3 years at Ferrari dealers, and they replaced both clutch plates EVERY major service.
    Soooooo..........my car had many clutch plates, but I didnt see anywhere in the paperwork where it said they replaced the pressure plate or slave body/throwout bearing. I think my pressure plate was original (16 yrs old) when it broke pressure plate fingers. So I put it down to wear and tear/fatigue over 16 yrs, not an overthrown clutch. :D:D
    New race clutch and pressure plate in there now. Hopefully the pressure plate lasts another 16 yrs! ;);)
  14. gidge348
    Dec 12, 2008
    343
    Ian Wood
    thanks guys, if it has been found to not be a "non-unanimous" problem I wont worry about it.
    I have plenty of other things at the moment that "are" problems to work on...... Thanks again.
  15. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    It is quite easy to reduce the volume of the MC by simply getting it sleeved to the desired diameter, but one would have to determine first if there is indeed too much travel on the system.
    Get the specs from the manufacturer of the clutch, the volumes of master and slave and do the sum.
    Somehow I doubt very much that the designers got it wrong and the fault comes to light 17 years after, it may have more to do with the way the clutch is used?
