348 Clutch Grease RePack Question | Page 3 | FerrariChat
Discussion in '348/355' started by POLO35, Dec 13, 2021.
  1. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,641
    Elliott Caras
  2. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    794
    Treasure Coast Florida
    MATT
    Interesting.....looks like yours, but one set of the small spring keepers backwards. Brown plates facing left?
  3. POLO35
    Feb 21, 2005
    794
    MATT
    MAD, look like yours and the other one you posted show the brown plates with the fat on the anti clockwise side, which by default would make the tops the same ....no other way. Strangely I watched MD video again and he has his one clockwise and the other anti clockwise.....nuts!!!! Made my decision I'm going to slap it together like yours! Thank you!
  4. POLO35
    Feb 21, 2005
    794
    MATT
    #54 POLO35, Dec 21, 2021
    Correction, MD guy has BOTH with the fat on the right of clockwise with the corresponding tops matching. Sorry for the error......so his are in fact opposite of both photos:(( Very hard to see but if you zoom you can....I could really see it on a 50in tv!
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    You are trying to split hair. Put it back the same way you took it out, good enough.
  6. POLO35
    Feb 21, 2005
    794
    MATT
    Yep....Just gonna slap it together and get it back on the road....it's driving season!
  7. m.stojanovic
    m.stojanovic F1 Rookie
    3,309
    Serbia - Niš
    Miroljub Stojanovic
  8. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    It’s not
  9. POLO35
    Feb 21, 2005
    794
    MATT
    #60 POLO35, Dec 24, 2021
    Oh wow....Thank you. I wound up following MADs pix regarding the spacers and the small apring keepers orientation. I went with MD clutches video orientation of the brown friction plates however which are opposite of MADs and yours. Took yelcabs advice that I was way over thinking it... it's all put back together and working beautifully! Hot start problem solved I can't believe I put up with it for so long. On a side note I just couldn't bring myself to spend a $150 on the kluber (not the money, just principle and didn't want to wait for shipping from Germany) so I did a little research and I came across this: Super Lube silicone based exactly like kluber with a practical operating temperature from -45f to 450f, NLGI 2 and a 400g tub.....$10.51 From Amazon. Slightly higher than Klubers 180c/356f. I weighed out 200 g on a gram scale and it was not quite enough. I needed like an extra 100 g to pack all the holes nicely but again this car is working beautifully! Thanks too all!
    Peter, steved033 and 348Jeff like this.
  10. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,551
    Jeff
    #61 348Jeff, Dec 24, 2021
    Peter likes this.
  11. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    Providing that Superlube has the same temperature ratings as Kluber grease, you have contributed greatly to the Stooge catalog.
    Peter and Targatime like this.
  12. fatbillybob
    Aug 10, 2002
    29,359
    socal
    Matt,
    I use a similar grease with success in the old days. It has been so long I can't remember but it is probably on these pages somewhere in the earliest archives of Fchat. Kluber used to be cheap so I went back to using it but have not cracked open a flywheel in decade. $150!!!! NFW....lets see how long the super lube works. Note the date and mileage and give us a report in a year. My memory is that 280g was the number so 300 is fine. It is not an exact thing. We need to fill to stop the rattle.
    Peter likes this.
  13. POLO35
    Feb 21, 2005
    794
    MATT
    #64 POLO35, Dec 24, 2021
    Yeah, I have a tendency to overthink things. I actually took the 4 springs and packed them in the Palm of my hand old school as if I was packing a wheel brearng to make sure they were completely packed with grease.
    Peter likes this.
  14. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,551
    Jeff
    It will be interesting to see if this lasts the course - brilliant discovery if that's the case and worth putting in the alternative parts thread. Do update us all with a long term report :)
  15. POLO35
    Feb 21, 2005
    794
    MATT
    For sure.... Forgot to mention the Super Lube grease is even fortified with PTFE you can actually see it in the grease almost like strands of fiberglass which seems to make it very stiff.... Although still rated NLGI 2, Which is the consistency of peanut butter.
  16. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I recall some older posts where someone was using some form of red line grease instead of kluber as well. I think it was actually red as well it's out here somewhere. Then I recall someone else commenting they use the same Grease. So definitely seems like there's options which is great.
    Sent using FerrariChat.com mobile app
  17. POLO35
    Feb 21, 2005
    794
    MATT
    I think in some cases it's foolish to use 30 year old technology in today's world. Certainly today's grease is superior to 30+ years ago....same goes for oil, gear lube, brake fluid, coolant, fuel, led light bulbs, wiper blades,, etc.
  18. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Were you able to tap it out of the pumpkin with a mallet and a socket or did you have to put in in a press to press it out?
  19. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,641
    Elliott Caras
    I have done it without a press, and let me tell you I much prefer doing it with a press.
  20. POLO35
    Feb 21, 2005
    794
    MATT
    I was able to tap it out using a 3 pound hammer and a socket it made me a little uncomfortable... but it did come out steadily with every tap! A press would certainly be the best option. Have also heard you can rig up a bottle Jack and a 2x4 and press it out that way if you have a sturdy structure above. As far as going back in I polished up the shaft end on the voith with Emory paper and put it in the freezer for about an hour and it dropped right in with little or no effort.
  21. Huskymaniac
    Huskymaniac Formula Junior
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    Guys,
    I get a whining noise from the tranny when the clutch pedal is released that goes away when I press the clutch pedal. Any idea what I should do?
  22. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Possibly because my workshop doesn't have heat unless I turn it on, and it hasn't been on for a couple weeks, and it's freezing here in New Jersey, I just shook my pumpkin little and the voith slipped out of the bearing race. [emoji846]
  23. POLO35
    Feb 21, 2005
    794
    MATT
    It's probably your throw out bearing going south, exacerbated by the cold weather.
  24. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Wait... the throw out bearing is on the other end of the pumpkin. I'm referring to bearing that the voith snout is pressed into with that 60 mm ring nut holding it. I recall you saying yours dropped right in when reassembling.
