348 CLUTCH TROUBLE | Page 3 | FerrariChat
348 CLUTCH TROUBLE
Discussion in 'Technical Q&A' started by PAP 348, Dec 13, 2005.
  1. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    I've spent hours looking at this. I wish I had a transmission/clutch on the bench for reference, as Billybob does. My conclusion:
    The spacer #48 (red in my color diagram) is designed to fit in one location only, NOT to be adjustable. It can't go inward any further, it's up against the land on the flywheel. And there is no reason for it to go outward any further - what would be the purpose? It would just be rattling around. No, it appears to me that this "spacer" (that's what it's called in the parts book) could more accurately be called a "plug". The hex screw #57 (yellow in my color diagram) has no apparent function other than to hold the "spacer" in place against the land on the flywheel. Again, no adjusting function at all.
    So why is there a hole in the flywheel land that needs to be plugged? I've come up with two ideas:
    1) The hole is there as part of the machining process for the flywheel hub, probably to center the tool that cuts the threads for the ring nut.
    2) The hole is there to provide a "nose" location for a clutch alignment tool.
    In conclusion, I can't really see why Ferrari bothered to provide either the spacer or the hex screw! Why not leave that hole open and eliminate the threaded hole for the hex screw inside the ring nut? What difference would it make?
    Billybob, I've read your long post several times, and I'm impressed with your explanation! I still have a couple of questions which I will post later.
  2. JoTeC
    JoTeC Formula Junior
    Jan 9, 2004
    796
    Huntersville, NC
    Joe Hullett
    This post is great! It shows me that I don't know Jack! When I ever have clutch problems, I'll get someone to fix it FOR ME! :)
  3. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Paul's diagram in Post 50 is the drawing used to show the setup height for the twin-disc clutch. It appears to show a solid "land" in the flywheel hub, no hole in it, and no spacer. It does show the hex screw, but it isn't doing anything!
  4. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    FBB said "4) endcap and hexscrew can only effect position of flywheel assemly as that is the only thing they are connected to"
    Flywheel position is determined by the fit into the bearing and its housing, the big bolt being fully tightened, and the rear alloy cap being fitted.
    The hex screw ONLY preloads the little spacer, which if left loose would allow the input shaft to float excessivly.
    The Big bolt MUST be done up with the hex screw fully loosened or removed, and then nipped up afterwards.
    The clutch is not adjustable, other than by removing the shims.
  5. fatbillybob
    Aug 10, 2002
    29,376
    socal
    Joe ,
    Don't do that learn to play it is part of the enjoyment. This is a highly technical thread and we really are beating sand into glass.
  6. fatbillybob
    Aug 10, 2002
    29,376
    socal
    I think it is more this than anything else. Just like the grease in the Flywheel you really do not need but that's for another holywar...and I can prove my point on that one too.
  7. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    I agree with you there.
    No grease is better than half full grease. Full grease is ok, but can't be trusted to stay there!
  8. fatbillybob
    Aug 10, 2002
    29,376
    socal
    #58 fatbillybob, Dec 16, 2005
    FerrariFixer I am sorry to roast you on this and prove you wrong. I would not have done it but you “called me out” and you totally diss’ed NoDoubt by putting him down in a harsh way. You carry a lot of weight around here and you are the 800 pound Gorilla and you shut down NoDoubt like a banana. Personally, most of what he posts on FC is correct as I understand it. He is knowledgeable. I respect you and applaud you for sharing your knowledge for free and hope this thread will not keep you from posting and sharing. I have learned things from you and assume I will in the future. No hard feelings... That said here goes... O.K. you’all look at my pictures. Thanks Ernie for the use of your gearbox for demo. I only have a couple nuts and screws left over.
  9. fatbillybob
    Aug 10, 2002
    29,376
    socal
  10. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,629
    The Brickyard
    The Bad Guy
    Glad I could be of service. :D
  11. fatbillybob
    Aug 10, 2002
    29,376
    socal
  12. fatbillybob
    Aug 10, 2002
    29,376
    socal
    #62 fatbillybob, Dec 16, 2005
  13. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    No worries FBB.
    You are correct in pulling me up. I shouldn't have said the input shaft is preloaded, as clearly it is not, but I do maintain that the spacer that controls input shaft float is preloaded. I simply didn't think this small detail was necessary to convey the info.
    I've seen many triple seals leaking, causing premature clutch replacemnt, and more often than not, the hex screw has been incorrectly set promoting the leak.
    Gorilla... ha ha, you haven't met me... I'm built for speed, not comfort.
    I don't beat around the bush, as anyone that knows me will confirm. Anyone peddling wrong info that I can see will be corrected. I've had words with No doubt before somewhere. He's a great enthusiast, but perhaps too keen with advice in some instances. It's mainly a wording thing. He means well for sure.
  14. JoTeC
    Jan 9, 2004
    796
    Huntersville, NC
    Joe Hullett
    #64 JoTeC, Dec 16, 2005
    FBB,
    We have got to talk about your dash... I have just the thing for you! Display, shift lights, alarms, laptimes, and 8 megabytes of memory for logging all these engine and chassis parameters. Below is a picture of what I recommend for you and I know you will love this. It will make your dash look like the rest of your car! It looks great! Who did the cage?
  15. fatbillybob
    Aug 10, 2002
    29,376
    socal
    Ohhh.....Very cool. I like that but may be too lazy to put it in. Can it connect to stock sensors and spedo? And where/how do I get a tach signal from the motronic ecu? I did my own cage. I bought a mandrel tube bender, designed and welded it myself. Cage is welded to car into the suspension and the full containment seat is attached to the cage. I use a 6 point schroth hans 4 shoulder system. If you want ot do one I can post some build pics in another thread.
  16. JoTeC
    Jan 9, 2004
    796
    Huntersville, NC
    Joe Hullett
    The tach is simple, the same wire running your current tach is fine. the speedo signal will also work if it is a hall effect or square waveform. The rest of the sensors can all be used, we just need to calibrate them. This stuff is as easy for me as the clutch issues are easy for you! Let's work on this together...
    I got out of the driver's seat a long time ago when I realized I didn't have the money to pursue the spacer status.
    Spacer= the spacer between the steering wheel and seat... :)
  17. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Does that dash read over 8000rpm ?
  18. JoTeC
    Jan 9, 2004
    796
    Huntersville, NC
    Joe Hullett
    Fully configuable up to 22,000 RPM... In fact, all of the "real estate" on the screen can be assigned to any channel and alarms and messages are as text overrides in the lower portion of the screen... There are different views programmable for the display so you can set it up in any configuration and use them all by a simple button...
    BTW FF, is your location Melboune, FL or Oz?
  19. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Oz. I see by your user name you're aware of MoTeC... how is your dash in comparison with their product.
    Better, cheaper, more functions, ????
  20. JoTeC
    Jan 9, 2004
    796
    Huntersville, NC
    Joe Hullett
    I worked for MoTeC for 12 years. I know all your mates over there, I have been there several times. The AIM dash is geared more towards club level racing and has most of the ADL features at a fraction of the cost. Retail on our product is US $1799.00 with harness, beacon tx and rx, download cable, temp sensor, wheel speed sensor, harness extensions, software and manuals. Believe me, I know their product well. Just ask Phil Morriss... :)
  21. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    I would, if I knew who he was....
  22. JoTeC
    Jan 9, 2004
    796
    Huntersville, NC
    Joe Hullett
    #72 JoTeC, Dec 16, 2005
    Phil is the MoTeC worldwide operations manager. Sorry, I thought you knew them. Do you play with MoTeC or Autronic? Good engine controllers which I interface with both (among many others) making sensor and wiring duplication obsolete in an installation...
    BTW, your V8 Supercar series ROCKS! I loved my trip to Bathurst!
  23. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Only used them a little bit. Use Marelli normally as std equip on Ferrari.
    Whats that data from.. 273 at 6900rpm at conrod is not V8 supercar (or maybe a slow one)....
    I like watching V8, but the cars are technical dinosaurs compared to Ferrari.
  24. JoTeC
    Jan 9, 2004
    796
    Huntersville, NC
    Joe Hullett
    data is from a Falcon EL back in 2000... I have to disagree with you on this... HRT is hardly dinosoar technology...
  25. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    They are all dinosaurs... the cars that is...
    single cam push rod cast iron engines.
    Live axle.
    No differential.
    H pattern gearbox.
    dreadful 17" tyres on a 1400kg 4 door...
    Minimal aero.
    dinosaurs. But fun to watch.
