348 Coolant Leak under Plenum | Page 2 | FerrariChat
Discussion in '348/355' started by AceMaster, Sep 11, 2021.
  1. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    Once you pull out the bolts on the back of the intake you can just set aside the air injection solenoids. Not necessary to unplug it, just set out of the way.
  2. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    Ok, now you're ready to pull the plenum out to see what's going on down there. Double and triple check that everything has been disconnected and is out of the way. In Ernie's case, he had to lift the plenum (but not completely take it out), tip it back to disconnect the vacuum line for the intake compensation valve, then fish the MAF & TB connectors back and out through the intake runners. For some reason mine wasn't wired this way. Either way, when you're slowly lifting your plenum out, have someone look underneath to see if you need to do this the same way Ernie did. In my case, I didn't, I just removed the plenum and it came right out.
  3. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
  4. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
  5. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
  6. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    Water/coolant stains.....turns out the clamp was stripped. The hose/sleeve itself was still in perfect condition. Cost of this is $64 from Ricambi, I ordered it and replaced it regardless since I had it apart anyways. It is # 40 in this drawing. I also ordered replacement clamps (obviously), #41 in the diagram
  7. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    All in all, not a bad job, just takes time and patience (and a strong back HAHAHA).
    Before I put the injectors back in place (attached to the fuel rail line), I cleaned the carbon build up with brake cleaner, and applied a little bit of vaseline around the o-rings.
  8. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    I will add this the 348 DIY thread shortly....
    Qavion likes this.
  9. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    496
    Victoria, B.C, Can.
    John Glen Wesanko
    Hope you inspected p/n 42 in the diagram. Mine was crumbling and leaking. Replaced with Hill Eng stainless steel fitting.
    KevZep likes this.
  10. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    I did not. Is that accessible with the plenum in place? What is that part called and what is its function? Once I found the source of the leak I didn't think to check anywhere else.
  11. m.stojanovic
    m.stojanovic F1 Rookie
    3,332
    Serbia - Niš
    Miroljub Stojanovic
    KevZep and ernie like this.
  12. John Glen
    Dec 30, 2009
    496
    Victoria, B.C, Can.
    John Glen Wesanko
    Nice job Miroljub, mine wasn't corroded as badly but almost. To remove the fitting I put a drill bit that was a close fit inside the tube such that I could clamp some vice grips around it without it crumbling.....Also applied some heat to the manifold casting to aid in removal.
  13. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    ATA boy Mikey! Great job!
  14. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    Thank you Ernie. Thank you for your intake/plenum removal thread. That was the inspiration for me to do this myself
    SeattleM5 and ernie like this.
  15. Ricambi America
    Sponsor Owner
    Mike - It is this: https://www.ricambiamerica.com/106241-union.html
  16. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
  17. itsablurr
    itsablurr Formula 3
    1,016
    Carlisle, MA
    Matt
  18. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    Exactly :D
  19. Manuel.G
    Manuel.G Karting
    Mar 21, 2013
    235
    España - Madrid
    To remove that hose (122219), is it necessary to follow this tutorial and remove everything, or can it be done without removing anything? I see the clamp is difficult to remove.
  20. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    which hose?
  21. Manuel.G
    Manuel.G Karting
    Mar 21, 2013
    235
    España - Madrid
  22. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    I can double check for you in a few days, but to the best of my knowledge you cannot get to that house without removing at least a few things
    Manuel.G likes this.
  23. Manuel.G
    Manuel.G Karting
    Mar 21, 2013
    235
    España - Madrid
  24. Manuel.G
    Manuel.G Karting
    Mar 21, 2013
    235
    España - Madrid
  25. m.stojanovic
    3,332
    Serbia - Niš
    Miroljub Stojanovic
    I bought it in a shop in Kuala Lumpur selling brass fittings, hydraulic fittings, etc. The original fitting is as shown in an earlier post here but, with the amount of corrosion, I didn’t even try to unscrew it. Instead, I cut it, drilled out and cut a new thread matching the brass fitting.
