348 Crank Angle Sensor Resistance | Page 2 | FerrariChat
Discussion in '348/355' started by Brewman, Mar 25, 2015.
  1. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,549
    Jeff
    #26 348Jeff, Mar 29, 2015
    All back together along with a little cleanup. Car starts fine and was purring away nicely. Wont really know until I try it out tomorrow assuming weather improved - very heavy rain here at moment :-(
  2. Brewman
    Brewman Formula Junior
    Apr 3, 2012
    417
    NC Mountains @ Boone
    Joe
    348Jeff,
    Thanks for the update, good news so far. I should start mine tomorrow. Will update you and appreciate one from you as well.
    Brewman
  3. Brewman
    Apr 3, 2012
    417
    Joe
    #28 Brewman, Mar 30, 2015
    Happy to report I started my 348 today with Kia crank position sensors with 860 ohms resistance vs. the original 550. The engine ran smooth, idles good at 1050 RPM, no issues so far. Will go for road test later this week.Very happy as the Kia sensors were $42.00 ea. from the local dealer.
    Thanks to all who responded to my original post regarding the resistance of the Kia sensors compared to the original from Ferrari.
    Brewman
  4. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,549
    Jeff
    Just to add - Ive done a few hundred miles in the car now and it starts and runs just fine :)
  5. Brewman
    Apr 3, 2012
    417
    Joe
    Jeff,
    I also have a hundred or so miles on mine since installing the Kia sensors. No issues at all.
    Brwman
  6. jferrante
    jferrante Formula Junior
    Jul 9, 2016
    498
    Well awarding myself 1 stooge point thanks to this post and a few others. Pulling out of gas station I got a 5-8 CEL and car almost died twice when coming to a light and would hunt for idle upon startup.
    Got under the car and looked at my sensors and sure enough 5-8 looked like it had been through NAM. Kia part number in and no more code she's singing like new.
    I also changed out the crank sensor in the engine bay on banks 1-4 since reading here it seemed like a decent one to proactively change...sure enough the harness on that was cracked as well.
    For less than 125 bucks replaced all that an onward we go.
    The stroke sensor for 5-8 is a pain to get to but I found it easiest to use an actual 5mm Allen key rather than an Allen on a 1/4" drive set. This helped me get it going and then the rest by hand. Overall pretty easy even though I was on my back with jackstands. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Sent from my Pixel 2 XL using Tapatalk
    ernie and Qavion like this.
  7. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,625
    The Brickyard
    The Bad Guy
    Yeah buddy! Way to gitterdun!
    Stooge points for sure.
    jferrante likes this.
  8. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I replaced everything on my car but the single biggest improvement was the cam phase sensor on cam back of passenger cam bank (your picture above) mine looked fine but they DO start to fail, they are not work or fail like some say. It was responsible for a weird idle hunt. But only some times and gets worse over time. It was the last thing I replaced and that was it. No CEL just a weird idle hunt like a vacuum leak type effect that stabilized as it warmed up and only when cold.
    The crank position sensors, you can get to the top one through the passenger wheel well by removing the front fender liner with 1/4 drive socket and a 3 foot extension with a hex head socket on it VERY easily. MUCH easier than from under with the belts in the way etc.
  9. JLF
    JLF Formula 3
    Sep 8, 2009
    1,710
    #34 JLF, Feb 8, 2020
    Are the original Bosch crank sensors no longer available?
  10. m.stojanovic
    m.stojanovic F1 Rookie
    3,303
    Serbia - Niš
    Miroljub Stojanovic
    The crank sensor is just a simple coil of copper wire on a magnetised core so I wouldn't worry about using a non-Bosch one. Bosch seems to be NLA but, if one prefers to have the sensor from a more reputable manufacturer, one can go for Vemo. Probably the same quality as Bosch, if not better - https://www.ebay.co.uk/itm/New-VEM-Crankshaft-Pulse-Sensor-V95-72-0039-Top-German-Quality/202850714783?hash=item2f3ad8449f:g:7mEAAOSwtbhcpmJE
    Or Valeo - https://www.ebay.com/itm/OEM-Crankshaft-Pulse-Sensor-Fits-VOLVO-KIA-LANCIA-FERRARI-PEUGEOT-760-591879/153174918845?epid=18023593570&hash=item23a9efc6bd:g:MPQAAOSwLmBb9YzI
  11. jferrante
    Jul 9, 2016
    498
    plenty of guys here running the kia sensors for multiple years now without issue...17/piece on amazon get it in a day
  12. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I bought and installed the OEM ones 4 months ago. May have to hunt a bit.
  13. m.stojanovic
    3,303
    Serbia - Niš
    Miroljub Stojanovic
    Most certainly, Italian! I have Marelli ignition coils on my 348. However, I wonder why Ferrari did not use Marelli but went for Bosch?
    JLF likes this.
  14. JasonS
    JasonS Karting
    Sep 5, 2019
    68
    Green, OH
    Jason Stropki
    I see the KIa part #s for the crank sensors, but what is the optimal source and part# for the cam phase sensor?
  15. Qavion
    Qavion F1 World Champ
    14,586
    Ian Riddell
  16. m.stojanovic
    3,303
    Serbia - Niš
    Miroljub Stojanovic
    #42 m.stojanovic, Sep 20, 2020
    The sensor only (with three pigtail wires) is Siemens HKZ101, HKZ101E, HKZ101S or HKZ121. It cross references to:
    VOLVO 1346792-3
    HUECO 138152
    FACET 8.2722
    BREMI 16522
    INTERMOTOR 14011
    VEMO V95-72-0038
    There are also Chinese knock-offs like CYHME301 or BBHME301 (https://www.ebay.com/itm/Hall-Effect-Vane-Sensor-BBHME301-replacement-for-HKZ101-HKZ101S-HKZ121-CYHME301/293110052067?hash=item443eb874e3:g:N4gAAOSwT0lc8U~A).
    JasonS likes this.
  17. JasonS
    JasonS Karting
    Sep 5, 2019
    68
    Green, OH
    Jason Stropki
    Thanks, very helpful.
    By the way, I spoke to 2 different KIA dealers regarding the crank sensors, and that part # (0K9AA 18891) has been discontinued with no supercession.
  18. m.stojanovic
    3,303
    Serbia - Niš
    Miroljub Stojanovic
    You can probably still get it on Ebay. Also search for Volvo part# 1367645 (Volvos 700 and 900 series).
    Other cars/part numbers:
    CITROËN & PEUGEOT
    5918 79
    5918 84
    74 01 367 645
    FERRARI 130975
    FIAT
    7616269
    76162690
    IVECO 7616269
    LANCIA 7616269
    RENAULT 74 01 367 645
    VOLVO 136764
  19. JasonS
    JasonS Karting
    Sep 5, 2019
    68
    Green, OH
    Jason Stropki
    yeah, a little more follow up:
    - saw a cross reference to 1998 Mazda Protege 1.5L. Part available at $146
    -saw cross reference to Ford 1996 Escort 1.8L. Part discontinued.
    Local Advanced Autoparts cross referenced KIA part# to a Intermotor, their part #CSS554. $73. I ordered 2, will let you know if they work.
  20. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,682
    San Carlos, CA
    Mitchell Le
    Crank sensors are easy and cheap to find. It's the cam phase sensor that is harder, specific to Ferrari, and expensive for both 348 and 355.
  21. m.stojanovic
    3,303
    Serbia - Niš
    Miroljub Stojanovic
  22. JasonS
    JasonS Karting
    Sep 5, 2019
    68
    Green, OH
    Jason Stropki
    Update- on Advanced Autoparts cross reference....these are not even close...wrong length and wrong plug.
    So I called Ricambi and ordered #130975 (the correct ones!). I should have did that first.
  23. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,549
    Jeff
    Qavion likes this.
  24. Polygaryd
    Polygaryd Karting
    May 8, 2020
    81
    Arizona United States of America
    Paco Ramirez
    I ordered some crank sensors through O'Reilly auto parts. Kia number crosses to a 19-0459. Installed the sensors and i didnt see a shim that fell out from the lower sensor(I think). Car starts but it dies almost instantly, found the shim, installed shim on lower sensor, car does same thing, put shim with other shim on upper sensor just in case it had 2 shims and the lower one had 0, car does the same thing.
    Car ran amazing when I put it in storage, then developed a no statt condition after it sat. I put a new ac pump in it, and probably hit the fragile af crank sensor connectors. Car had no spark on bank 1-4 but did on bank 5-8. I go to put the new lower sensor for bank 1-4 and it breaks the connector for the upper crank sensor just by removing the bracket bolt.
    Smh these are beautiful cars but made with absolute garbe parts. My 87 trans am (using this a reference because its older and cheap gm product) connectors dont crumble into dust when Touching them, the fuel pump doesnt have rubber that is susceptible to gasoline surrounding it so it decays into a sludge and clogs everything. It doesn't need 2 ecus to control 8 cylinders, or 2 fuel pumps or 2 crank sensors. Smh
    Anyway about 1 out of 15 times of starting the car it will fire up to 2k and sound great for like 10 seconds. Then dies. I have fuel pumps coming, fuel filters, and 3 new injectors. I bought 8 brand new delphi injectors from autozone, 3 were previously opened, they could be bad, I want brand new still sealed to replace them with.
    It feels spark related to me. Wonderig if the aftermarket sensors I got were just not as good as oem. Just like when you buy the knock off china injectors and they dont work properly and you have to buy oem. Is this the same type of situation? Can aftermarket crank sensors be used? Does anyone have experience with the aftermarket kia style crank sensors working in their 348? Btw mine is a 94, not sure if that makes a difference between the older 348s and the 94 to 95 348s.
    Super frustrated 348 owner please help!
