348 cutting back...why? | FerrariChat
Discussion in '348/355' started by Juan-Manuel Fantango, Mar 20, 2004.
  1. Juan-Manuel Fantango
    Juan-Manuel Fantango F1 World Champ
    11,218
    Juan
    My new to me 348 Challenge is cutting back, loses power and back fires, stumbles, once I hit 4-5Krpms. I noticed this earlier at much higher rpms, and was told that it was the upgraded chips that act as a rev limiter at 8600 rpms. The problem really seemed to begin in earnests once I filled the tank. I also noticed that air presure had built up in the tank when I unscrewed the fuel cap. What could it be? Once I lift off the loud pedle, it goes back to normal. Air flow meter? Fuel pump? filter? bad fuel? spark plugs? As you can see I need some experienced help. I assure you it will be appreciated.
  3. bigbaddad
    bigbaddad Karting
    Oct 31, 2003
    135
    Arizona
    John Roberts
    I can only comment on the pressure in the gas tank. Mine is the same, so I don't think you have a problem there. I filled up yesterday, and when I unscrewed the cap, the usual hiss of air came out.
    Can't help you on the rest, sorry.
    -John
  4. nzo4re
    nzo4re Karting
    Mar 13, 2003
    197
    San Jose, CA
    Tom Lassen
    Do you get any warning lights like the 1-4 or the 5-8? Do you get a Slow Down light? When's the last ime you had fuel filters replaced?
  5. davey_jones
    davey_jones Formula Junior
    Sep 28, 2002
    781
    wherever it's sunny
    Dave
  6. thecarreaper
    thecarreaper F1 World Champ
    17,394
    Savannah
    not to be a dud but this would garner a better response in the "TECH Q&A" section.
