Guys - I needs some pointers. How do I remove the fog light/daylight flasher assembly in order to change the bulbs. The manual says there shoud be a screw to remove the small black plastic cover, and then I undo further screws to remove the light assembly, but there are no screws that I seem to be able to access from the front bumper. I don't have to remove the pop-up headlight assembly do I to gain access ? Any clues much appreciated - thanks
I believe that the plastic cover snaps into place. So you would need to carefully pry it off. But I would wait for someone to confirm this. I have changed headlights but have not had to deal with the fog lights. If you look at the pic of the light, you can see where there are two points that show snap on locations for the plastic trim. Good luck
Be careful, these light assembly brake easy, advise to put blanket on floor when ever working on them. Ask me how I know
