348 Door Panel Removal Procedure
Discussion in 'Technical Q&A' started by Ksullender, Jan 24, 2004.
  1. Ksullender
    Ksullender Formula Junior
    Sep 3, 2003
    886
    Can anyone provide me with this? I need to remove the door panels from my 348 and would like any advice possible.
  3. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,221
    TN
    I just finished removing and reinstalling mine. It wasn't too bad at all. I will try to write something up for you.
  4. Noelrp
    Noelrp Formula Junior
    Aug 30, 2001
    630
    SSF
    Noel
    Which panels? If you are taking about the slates. The panels are very simple to remove. Remove the (4) allen screws outside of the panels and (2) 10mm bolts inside by the door hinges.
    Note: you might need an extra set of hands to hold the panel while you're removing the screws & bolts.
    Good luck.
