348 ECU codes | Page 2 | FerrariChat
348 ECU codes
Discussion in 'Technical Q&A' started by sdiamond, Sep 10, 2009.
  1. notbostrom
    notbostrom Formula Junior
    May 8, 2006
    957
    Orlando, FL
    Ben
    These are the little gremlins that pop up on cars that sat unused for extended periods as yours did. I think your got 1 or 2 new fuel pumps just before you bought it. Factor in the fact that you got a smoking good deal on it and in short order you'll have it sorted out and in tip top shape. You soon learn a lot of what goes wrong on these cars is not that expensive to repair and even the weekend mechanic can do most of it. When crap goes wrong just take a deep breath and remember how easy it was to fix the last little curve ball your new Italian wife tossed at you and how you fixed it yourself for justa couple bucks.
  2. sdiamond
    sdiamond Formula Junior
    Mar 25, 2009
    304
    Kildeer
    Steve
    Ben, did you know the car before I got it? And yes, both of the fuel pumps were replaced shortly before I got the car.
  3. notbostrom
    May 8, 2006
    957
    Orlando, FL
    Ben
    I spoke to Mr Wolf several times since we both had our cars listed on Cars.com at the same time. He used to be on here once in a while as well. Seems like a nice guy with more toys than he could play with so the car just sat unused. Someone showed up to buy the car before you and it wouldn't start due to the fuels pumps. No big deal but it gave the buyer cold feet as they were not Ferrari literate..worked out well for you since it resulted in another price drop..
  4. sdiamond
    Mar 25, 2009
    304
    Kildeer
    Steve
    Wolfie really is a great guy and we've kept in touch since April. It really was lucky for me
    and yes, it had minor issues after all that time unused but mostly worked out now. I replaced both O2 sensors today and after the ECU reset seems to be running like a champ again. Tomorrow or next week is the FPR's for that nagging hot start issue.
    btw, for the forum, the 1995 348's only have the tubes to the MAF's that unscrew, the four nuts holding down the airbox and the slip off air intake tubes and it's off. Also what worked best for me in changing them from the top was a 20" ratchet extension and the O2 socket. Took about 20 minutes all in all.
  5. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    that is awesome that you keep in touch with the seller.
    also, good job on replacing the O2 sensors...good luck with the FPR install and keep us posted.
  6. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    that is what makes this an even more enjoyable experience, the fact that a lot of the service can be done with the guidance of the membership here.
    good way to look at it....patience is a virtue
  7. sdiamond
    Mar 25, 2009
    304
    Kildeer
    Steve
    First day out after the O2 swap and the car is running great, no warnings, no lights, imagine that :) I agree with a previous poster that some of that might be due to the battery disconnect and ECU reset as well as the sensors. Seems to be running better now than before the warning lights even started. it just gets better and better. As always, thanks to everyone who took the time and interest to respond with such helpful suggestions and encouragement!! FPR's next week and if the hot start issue resolves I won't have anything else to compalin about ;-)
  8. flyguyskt
    flyguyskt Formula Junior
    Sep 22, 2009
    443
    South Dakota
    sean
    going to try to use an old post here instead of making a new one.
    my 94 348 spider blinked a check engine 1/4 light for abolut 2 seconds yesterday...then it did it again a few times this am... light only stays on for 2 or less seconds. what do i do next?
  9. flyguyskt
    Sep 22, 2009
    443
    South Dakota
    sean
    i guess what im wondering is if my next step is to retrieve codes? from ecu's? behind seats from what i read?
  10. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    Yes, retrieve the codes. Move your seats forward, remove the ECU covers, find the little round black (or sometimes red) button beside the ECUs and follow the procedure outlined here: http://www.my348.com/348.html#ECUcodes
    At the end of the procedure write-up is a list of what the codes mean.
  11. flyguyskt
    Sep 22, 2009
    443
    South Dakota
    sean
    so...anyone done the wire splice version of the bosch o2 sensor...? they have 2 in town and they are only 55 bux...are they touchy to the splice? doesnt look to be too tuff for 40 bux each.
  12. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    I don't know of anyone who has gone the splice route, but I have heard it is possible...but don't take what I "heard", wait for someone who actually did to confirm...by the way, did you pull the codes?
  13. tcannon
    tcannon Formula 3
    Feb 18, 2009
    1,763
    Norman, OK
    Todd Cannon
    I did the splice route on both of my O2 sensors. No problems at all. :)
  14. Huskymaniac
    Huskymaniac Formula Junior
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    Does anyone know which order the codes read out? Is the first code that flashes the newest code or the oldest code?
  15. Qavion
    Qavion F1 World Champ
    14,531
    Ian Riddell
    The WSM says "in order of priority".
    ernie likes this.
  16. Huskymaniac
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    Thanks. I wonder if priority was mis-translated or if it really is a priority thing.
    Any idea if a bad or disconnected Cat Temp Sensor module will actually cause the CEL to light up versus just storing a code?
  17. Qavion
    14,531
    Ian Riddell
    @m.stojanovic on the 348/355 forum is the best person to ask about this (I always get it wrong). See this post:
    https://www.ferrarichat.com/forum/posts/149128134/
    but read the whole thread to get some context.
  18. Qavion
    14,531
    Ian Riddell
    I don't understand that, either. I guess all you can do is try it. Miro did specify that his 2.7 car was uncatted, and wasn't sure if that would produce a different result.
    "This is on my factory non-CAT 348"
  19. Huskymaniac
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    Yeah, I unplugged the Cat ECU and cleared the codes. Drive it several times yesterday and the CEL remained off.
    On a different topic, when your car is fully warmed up, what is your oil pressure at idle? Mine got pretty low but was middle-ish on the gauge when cold.
    Qavion likes this.
