348 - 348 ecu error 4121 and ccu delete | Page 2 | FerrariChat
348 348 ecu error 4121 and ccu delete
Discussion in '348/355' started by jlclt348, May 7, 2023.
  1. jlclt348
    jlclt348 Karting
    Jul 7, 2013
    209
    Ridgefield, CT
    Justin
    Hi, all... busy work week, but in garage today. Turns out the cat control unit error is a red herring. Worth following up in, but not causing the 5-8 cel or the engine stumble. I swapped the units and there is no change in engine behavior. Next up I'll test the crank position sensors. Thanks for your help so far!
  2. jlclt348
    jlclt348 Karting
    Jul 7, 2013
    209
    Ridgefield, CT
    Justin
    Can someone please point me to the location of the cam position sensors?
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,697
    San Carlos, CA
    Mitchell Le
    Rear of heads, on the intake cam. Depending on the year, you may have one or two of them.
    ernie likes this.
  4. jlclt348
    jlclt348 Karting
    Jul 7, 2013
    209
    Ridgefield, CT
    Justin
    ernie likes this.
  5. Qavion
    Qavion F1 World Champ
    14,620
    Ian Riddell
    ernie likes this.
  6. yelcab
    Nov 29, 2001
    13,697
    San Carlos, CA
    Mitchell Le
    Yes, that is it. The 94 model has only one cam sensor whose signal is shared with both sides.
  7. jlclt348
    jlclt348 Karting
    Jul 7, 2013
    209
    Ridgefield, CT
    Justin
    Ok, thanks. I was confused why there was only one. My axle boot broke last summer and sprayed axle grease all over the engine. It looks like this sensor was in the line of fire. And the CEL started last summer too. So next up I'll clean up that whole area and the connectors
  8. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    It would be really hard for gears to get into that connection.
  9. yelcab
    Nov 29, 2001
    13,697
    San Carlos, CA
    Mitchell Le
    There is only one Cam position sensor running off bank 1 which ECU1 reads directly. The signal is shared with ECU2 which has to "assume" that you have done cam timing correctly on both banks so that the relative position of bank 2 camshaft can be accurately inferred by using the signal from bank 1 camshaft.
  10. jlclt348
    jlclt348 Karting
    Jul 7, 2013
    209
    Ridgefield, CT
    Justin
    Appreciate the input guys. Is the data from the crank position sensors "shared" the same way?
  11. Qavion
    14,620
    Ian Riddell
    Justin, here are wiring diagram for the 2.5 and 2.7. It shows wires going directly from the Cam Sensor to both ECUs. The cam sensor plug only has 3 wires, but the signal wiring is pigtailed. See bottom right of diagrams:
    2.5 wiring diagram:
    https://www.dropbox.com/t/WzfvT3X2Yv0TZdpq
    2.7 wiring
    https://www.dropbox.com/t/03t7tmxlkzamFsE7
    The Right ECU, however, does provide power to the Cam Sensor.
    Each bank has its own crank sensor. No sharing.
    ernie likes this.
  12. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Crank sensors.
  13. m.stojanovic
    m.stojanovic F1 Rookie
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    It is unlikely that the problem is in the cam position sensor since the CEL appears on one bank only. The crank sensor, maybe.
    Another possibility is the fuel pump pressure. I once had a problem with one of my fuel pumps - at the start from cold, it would provide normal pressure (I have fuel pressure gauges installed, see pic) but, after a few minutes of idling, the pressure would start slowly going down and this caused CEL for that bank when the pressure dropped to about 70-80 % of normal.
  14. jlclt348
    jlclt348 Karting
    Jul 7, 2013
    209
    Ridgefield, CT
    Justin
    Thanks to all your input i finally got out there today and determined it is the crank sensors. Specifically the connectors. The sensors are fine and she runs smoothly now.
    I removed all the protective plates. Everything looks fine in visual inspection (first pic) but the connectors absolutely disintegrated in my fingers when I tried to undo them.
    I put everything back in the temp configuration you can see in the second pic. Shes idles smoothly. No stumble. No CEL.
    Tomorrow I will tape the f**k out of it until I can get new connectors and re-pin everything.
    What are connectors of this type called?
    Thanks again for your guidance. I'm not very experienced but this was a fun one!
    Qavion likes this.
  15. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  16. jlclt348
    jlclt348 Karting
    Jul 7, 2013
    209
    Ridgefield, CT
    Justin
    Declared victory too soon! The CEL came back so I ordered new crank sensors from Ricambi.
    The 1-4 sensor was super easy to swap out.
    But how in the world do you get at the bolt for the 5-8 sensor?
    I don't want to take the belt off, but I don't see any other way to do it.
    Any ideas?
  17. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I remove the passenger wheel tub and get to it through the wheel well with a long extension and a swivel, super easy.
    Sent from my SM-G990U using FerrariChat.com mobile app
  18. jlclt348
    jlclt348 Karting
    Jul 7, 2013
    209
    Ridgefield, CT
    Justin
    Does your car have AC? It looks like the compressor would get in the way of doing what you described.
  19. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Yep I have ac, you can get in there fine I used 1/4 ratchet with long extension and a swivel, need swivel. Have to contort a bit but it's straight forward. Reach is from above the ac going downward.
    I actually have a picture out here somewhere if it.
  20. jlclt348
    jlclt348 Karting
    Jul 7, 2013
    209
    Ridgefield, CT
    Justin
    A pic would be great. I can't see it for myself.
  21. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Not sure where it is actually. My tub is out maybe I'll take a pic tonight.
  22. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I think you missed the part where you have to remove the fiberglass wheel liner/tub.
    The whole engine is visible then including the crank sensors.
  23. jlclt348
    jlclt348 Karting
    Jul 7, 2013
    209
    Ridgefield, CT
    Justin
    Ok wheel and liner off. I can't really see it clearly but I thinks its down there under that coolant line. Def not "easy" to get to. At least not for a rookie
  24. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    2 foot extension, swivel and another small extension. Push it through, go under the car and set socket it on the nut. Once it's on and you have light from above you'll see it, take it on or off with the ratchet.
  25. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Remember you only need to break it loose, you can then remove the bolt with your fingers. When putting it back on use fingers then the same process to simply snug the bolt down where the belts are otherwise in the way.
