348: electrical problem with FUSE / instrumentlights | Page 2 | FerrariChat
Discussion in '348/355' started by henkie, Jun 4, 2006.
  1. Qavion
    Qavion F1 World Champ
    14,639
    Ian Riddell
    Does your car's brake light bulbs have dual elements? i.e. are they used for sidelights and brake lights? If so, try removing these bulbs and put another fuse in. If these bulbs are not seated properly or they are shorted, they might cause fuse 10 to blow.
  2. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    So I did take out the #7 out as well as a few harness and still popped.
    So when I do put a new fuse in, the front trunk light turns on so does all the lights that pop the fuse with in 2 seconds lol. So i know all the instruments lights do work and are still working but something is causing it to short. Tomorrow i can take out the dimmer little black box hooked into the speedo at the back. I have a few things apart. If you have a wiring diagram to show would be good. I may have to call in a friend to help me.
    Weird as it just happened while driving no real reason. I thinking hard and i really appreciate your help
  3. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    I also seen some old posts of you helping others. I wondering if a bad rely would cause this but wouldn't it cause more issues as i seen in other threads.
    Would love a 2 min phone chat if that was possible lol.
  4. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    The break light bulbs are 2 single separate bulbs smaller version of a 1156 or 1157 half that size,
  5. m.stojanovic
    m.stojanovic F1 Rookie
    3,315
    Serbia - Niš
    Miroljub Stojanovic
    I would first unplug the connectors from the tail lights and disconnect the inline connector for the license plate lights.
    Qavion likes this.
  6. Qavion
    14,639
    Ian Riddell
    Ah, so just a single contact on the bulb base.
    @Miro: Does your car have only one lamp on each side of the car for sidelights? That would be contrary to the wiring diagrams.
    https://www.dropbox.com/t/aTThYebjC6xW8pDZ
    Looks like I forgot about the licence plate lights. They are spliced to the right hand side inner sidelights in the Euro wiring diagrams.
    More diagrams:
    https://www.dropbox.com/t/LPxZZVMNkj6locIx
    https://www.dropbox.com/t/mYOjwNqGOmhhZqu1
    Sorry, I'm not so good with impromtu conversations. I need to do some research for every answer I give
  7. Qavion
    14,639
    Ian Riddell
    The relay ("B") supplies power to the fuse. It can stop the lights working, but it wouldn't blow the fuse.
    By the way, Miroljub has a lot of practical experience with 348 electrics. He often goes the problem straight away. It usually takes me some time to get there :p
    Check those licence plate lights (and wiring). Also, the lampholders are probably quite rusty.
  8. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    So each side of the running rear lights have 2 single bulbs and 1 sing break so 3 bublbs per side 2 of the running lights are out as well just noticed now the picture is the rear right of the car (passanger)
  9. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    So each side of the running rear lights have 2 single bulbs and 1 sing break so 3 bulbs per side 2 of the running lights are out as well just noticed now the picture is the rear right of the car (passenger)
  10. Qavion
    14,639
    Ian Riddell
    #35 Qavion, Apr 17, 2023
    (EDIT)
    It looks like yours is different from the Euro lights
    According the Euro diagrams, the bulb on the outside should have a different fuse. The two on the inside should be powered by fuse 10.
  11. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    There is some old threads and some not to long ago do you think i need a Kfuse ?
    BOSCH 0 332 015 001 Relay ?
    if so any recommendation where to buy one
  12. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    It could be different
    the outside light running lights work break lights work but inbetween outside running and break the other running is not working which 100% works with 10 i popped my last fuse trying to see them come on and they do while ignistion is on
  13. Qavion
    14,639
    Ian Riddell
  14. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    Your a genius , ill see if any local stores have do you think its the relay now? starting to think the relay is bad and causing straight fuse popping
  15. Qavion
    14,639
    Ian Riddell
    It's definitely not a relay issue. All the relay does is supply power to the fuse when the lights are turned on. If the relay wasn't working, the fuse wouldn't blow.
  16. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    okay that if it was faulty it would blow the fuse... im stuck
  17. Qavion
    14,639
    Ian Riddell
    Stuck until you get new fuses. Did you disconnect the licence plate lights before you blew your last fuse?
  18. Qavion
    14,639
    Ian Riddell
    Lighting issues are sometimes caused by the marker lights on the side of the car.
    Look for wiring damage and faulty bulbs/bulb holders. You may have to remove wheel arch liners to get to them. Whether they are on the same fuse, I don't know. Maybe someone has a USA wiring diagram?
  19. Qavion
    14,639
    Ian Riddell
    I see the rear lamp arrangement from this online manual page.
    I'm wondering if the side marker lights (I) are linked to the outer rear lights (H) or the inner ones (C).
  20. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    Going to grab more fuses as i cant find resettable fuse unless its on amazon. so for today another box of fuses. Going to pick up some now. Ill try to disconnect the rear plates.
  21. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    Doing this soon sorry i don't know properly how to stay on the same thread and same chat sorry if any confusion.
  22. Qavion
    14,639
    Ian Riddell
    There should be a single connector behind the bumper below the right hand lights
  23. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    What a team you guys are... honestly thank you guys so much. I bulb was burnt right license plate. I was able to do that first and caught it right away !!!
    Thank you both so much greatly appreciate it. Thank for all your amazing help.
    Qavion likes this.
  24. Qavion
    14,639
    Ian Riddell
    So you’re saying that the burnt bulb was shorting… now all is ok?
  25. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    Yes that's correct! All done all put back together.
    It seems license plates, running back and front lights as well as side bumper lights front and back. Cluster bulbs and gas bulbs all work together on that #10 geeez!
    Qavion likes this.
