348 Engine blew 367 days after last major... | Page 9 | FerrariChat
Discussion in '348/355' started by axarunner, Mar 10, 2021.
  1. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,473
    Los Angeles
    This continues to be the all-time most useless thread in this forum's history. I am ashamed to admit I sometimes read OP's updates even though there's zero chance they will contain anything informative.
    BD-Chrono, marknado and ghardt like this.
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    As far as I know he is simply pending the shop to get to the work, its queued up apparently.
    Dan, myself and mr308gtb pulled my engine last weekend. If you have a used one and want to swap it in I'm sure we can help.
  3. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    Engine still blown up 576 days after last major. :p
    Tarek307, IvanRico and ernie like this.
  4. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    Lol
  5. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    axarunner likes this.
  6. axarunner
    axarunner Karting
    Sep 8, 2019
    97
    Glen Ridge, NJ
    Dan Murphy
    Update... ugh (but thanks for checking in). Yes, the engine is back in (as of 2/25) and the car is being test driven several times before "it's ready" The front bumper is being repaired (driveway rash) which is the latest delay... despite my request that it be done while I was waiting for the engine repair to be done.
    Recapping: I was accused by the technician of over-revving the engine which resulted in the valves hitting the pistons in one cylinder. I was advised to purchase a used engine which has been throughly rebuilt. That engine arrived one year ago ($7,500). I've visited the car several times, met with the technician, pleaded with the owner and service advisor to no-avail. I've never experienced such poor customer service in my life. While the repair will be done to perfection, I feel that I was discriminated against because my car is the lowly 348.
    Rory J likes this.
  7. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    Valves hit pistons in one cylinder and they told you you needed a new engine which they then rebuilt? o_O
    Pangea, INTMD8 and Rifledriver like this.
  8. joe1973
    joe1973 Formula Junior
    Nov 12, 2016
    286
    NJ
    Axa.. as posted to you last year, your car in the shop same time as my major- rosso 97 355. I recall your service was basic maintenance like an oil change and not any acutal engine work. So even if you don’t believe you over-revved the engine, you cannot lay any blame on techs for your event. Unless they put sand, what happened to you right after you drove from the shop can’t be blamed on the service. Bad luck really. Happens to all of us at one point. I had a wonderful service experience ar Classic. Meticulous work all captured in photos.
  9. axarunner
    axarunner Karting
    Sep 8, 2019
    97
    Glen Ridge, NJ
    Dan Murphy
    Hi Joe: I’m not blaming the dealership for my engine troubles, I’m merely frustrated that it’s taken so long (really frustrated). My car was originally in the shop for the rebuilding of my steering rack, an oil change and a brake service.
    As for valves hitting pistons requiring an engine replacement, the concern was the crankshaft could have been compromised and I was told it’s best to rebuild a used engine rather than deal with the unknown of a seized engine.
    Yes, the work being done on my 348 is meticulous with all work being captured in photos… I just want my car back as it’s been over one year.
  10. Rifledriver
    37,369
    If valves hit one piston from an over rev you need to contact the people at the Guinness Book of World Records.
    2NA, SAFE4NOW, QSA and 1 other person like this.
  11. Rifledriver
    37,369
    Crank being damaged from a valve strike is another Guinness Book event.
    2NA likes this.
  12. Rifledriver
    37,369
    Stripping teeth is standard failure mode. The belts very seldom "Break" but its the term used.
    2NA likes this.
  13. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Crank journals are what 1.75 in diameter or hardened steel supported every what 4 inches? The valve stems are 3/16 diameter with a taper down on top of that. They bend just a hair then are clear. Not sure how that could affect the crank, harder material always wins. Maybe but not seeing it really. Long road but glad its getting sorted regardless!
    Waiting on my heads from Olsen Engines, been 4 months, if they sent your heads out and they probably did as its not a machine shop that's where they likely went as well. If they did not send the heads out and just did a swap-aroo I would be concerned.
  14. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    That's good information thanks Brian.
  15. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    I for one would want the old engine.
    2NA, LARRYH, 26street and 1 other person like this.
  16. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,856
    Lake Villa IL
    One things for sure, we'll get documentation of both the pyramids and granite boxes at Saqqara being built before finding out what actually happened here.
    Rifledriver likes this.
  17. Rifledriver
    37,369
    #217 Rifledriver, Mar 11, 2022
    No question. The evidence is in a landfill.
    I get pictures from around the country from either shops or sometimes owners showing damaged, broken, whatever parts asking for an opinion on why it failed and I am blown away how poor most are at determining why it went kablooie. Sometimes it is no doubt a case of needing a narrative that absolves one party or the other from guilt and I get that but many are just a complete lack of knowing enough to come up with a cause and effect. I saw an old V12 from a shop who asked my opinion why it ate up its lower end. I offered a couple of scenarios, none very supportive of the shop who rebuilt it. They rejected that and insisted it was the owners not adequately warming it up prior to driving it. Of course that had the virtue of absolving them of guilt but I think they really believed it.
    Texas Forever and INTMD8 like this.
  18. KevZep
    KevZep Formula Junior
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    Can't over rev a 348, it has a rev limiter!! Its that simple, and a very conservative rev limit it is.....
  19. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    Down shift to wrong gear.....4th to 3rd for example. But you would sure as H know that you did that.
    INTMD8 and flash32 like this.
  20. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    Indeed that is very true, you would have to really force it in though and you can also hear the syncro spin the gear up massively if you were to actually force it into gear....
  21. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Shops look out for each other. I don't believe he over revved it, zero reason for him to lie. He was cruising on the highway and it happened. Last service forgot to tighten most of the cam caps from the rear forward, as in really loose, cam flexed from the rear and shims launched, how that for a theory.
    axarunner and Carmellini like this.
  22. Rifledriver
    37,369
    #222 Rifledriver, Mar 11, 2022
    Not in this business. Most are trying to make others look bad.
    Had a 328 factory left a cam loose, very loose. Only symptom was it kept breaking distributor rotors. I asked but factory would not let me remove cam cover to investigate. Owner got disgusted with factory not seriously wanting to fix car and sold it. Finally at 15k service I pulled the valve cover and found all 5 cam bearings loose.
    No I dont believe it. If it had bent valves on one cylinder it happened at the service. It is actually kind of common.
  23. Ricambi America
    Sponsor Owner
    Considering one time a guy ran over a subway token that flew up and sliced his timing belt, your theory isn't that far fetched!
    #waybackfchatmachine
  24. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    I remember that incident...
    2NA and bcar1 like this.
  25. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,473
    Los Angeles
    Nailed it.
