348 Engine Mounts | FerrariChat
348 Engine Mounts
Discussion in 'Technical Q&A' started by bitstream, Mar 26, 2008.
  1. bitstream
    bitstream Guest
    Can serious damage or problems result from not replacing worn engine mounts on a 348? I haven't noticed any significant vibrations, however my mechanic has recommended replacing them -- but the $2,000 price tag is a bit steep for something that may not be imperative.
  2. PAP 348
    PAP 348 Nine Time F1 World Champ
    Dec 10, 2005
    99,373
    Mount Isa, Australia
    Pap
    Worn mounts, not really man. :):)
    But get them replaced as soon as the budget allows. :):)
    If they were cracked or broken, then I would do is asap as that can cause some issues...............maybe. ;);)
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Since the 348 and 355 use the same engine sub-frame, try using the 355's motor mounts instead of the older 348 mounts. They're just $70: http://www.superformance.co.uk/355_a.htm
    Perhaps there's no need to spend $2,000.
  4. fatbillybob
    Aug 10, 2002
    26,425
    socal
    Geeze 2k! I'd mount the engine to a 2x4 before I spent 2k on something so easy to fabricate myself.
  5. PAP 348
    Dec 10, 2005
    99,373
    Pap
    Very good ND. :):)
    But.........they are probably charging him $200 for the mounts and $1800 labour!! :p:p
  6. Ricambi America
    Sponsor Owner
    Actually no. They are extremely hard to find at a reasonable price. Mondial t is the same issue. The 355 mount is not a simple plug-and-play swap, but I'm pretty sure it can be done with a chunk of labor, a small stick of dynamite, three shakes of a rattlesnake tail.
    I won't even inventory the 348/Mondial ones because they're such stoopid money.
  7. chrisx666
    chrisx666 Formula Junior
    Dec 6, 2004
    562
    YorkshireUK
    Chris B
    #7 chrisx666, Mar 27, 2008
    These list at GB£990 each including tax in the UK. It's this sort of thing that is making me seriously condiser the continued ownership of this car (some parts I can see value in, parts like this it's not so easy). There must be an alternative with a bit of thought and fabrication though.. marine engine mounts are available is various sizes/hardness.
  8. PAP 348
    Dec 10, 2005
    99,373
    Pap
    Thats what I would seriously consider doing!! :):)
    I didnt realise the 348 mounts were that expensive!! :):)
    I reckon you could send one to a company that makes engine mounts, get them to replicate the Ferrari mount and they would still charge you less for it than a genuine one!! :D:D
  9. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    West Marine should be able to match them up for you. It's not like Ferrari makes those motor mounts!
    Anyway, what was changed on the sub-frame to use the 4 bolt 355 motor mounts?
  10. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    I think ferrarioldman has been through this before...
  11. Ricambi America
    Sponsor Owner
    Hence my comment about the "rattlesnake tail". He keeps them in a small drawer beneath the espresso machine.
  12. fatbillybob
    Aug 10, 2002
    26,425
    socal
    Its just a motor mount the problem comes when owners demand originality. Anything made can be reverseengineered and made again. I'm sure you can find something close modifiy the perch which would be an easy weld/fab job but not OEM. I'm with ND on this one. 2k is too stupid.
  13. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Ferrari Spa lets its car owners know when factory originality needs improving/customizing by simply pricing any given OEM part obscenely.
    How much are OEM 355 exhaust headers, for instance?! You wouldn't pay it, you'd go custom...and that's Ferrari's intention.
    Same again with 348 tranny bearings.
    Ditto for 348 motor mounts.
    It's how Ferrari communicates.
  14. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Never occurred to me, but you may be completely right!! ;)
  15. ferrarioldman
    ferrarioldman Formula 3
    Jun 19, 2002
    1,029
    Summerfield, NC
    Tom Jones
    #15 ferrarioldman, Mar 27, 2008
    What I ran into was the early Mondial T mounts. Picture below shows the replacement on the left and the original (broken) mount on the right. Had to drill out the mounting arm on the block to make the new one work. No reference to this smaller mount could be found.
    I think that FOW changed the ones on Juan Fandango's Challenge 348 to the 355 mounts.
  16. fatbillybob
    Aug 10, 2002
    26,425
    socal
    I would not be surprised if some shifting problems and some oil leaks past triple seats are the result of failed engine and sagging geatbox mounts. The 355 has a gearbox mount and not sure if any other design change yet does not seem to leak oil as much as 348 seem to leak into the clutch pak.
