348 engine out major | Page 13 | FerrariChat
Discussion in 'Technical Q&A' started by ernie, Feb 22, 2014.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #301 ernie, Feb 26, 2014
    Then using a small sledge hammer I tapped it into the hole.
    I did NOT just smack it with the sledge. I tapped it all the way in, being careful not to let the bearing get cockeyed.
    The reason I used the sledge was because it had a much bigger face that a regular hammer. Also because it's heavier and I don't have to exert as much force, I let the weight of the sledge do the work.
  2. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #302 ernie, Feb 26, 2014
    Before reinstalling the top sprocket I slid the bottom one off to clean it up a little.
    The other reason is because you will need to feed the chain onto the top and bottom sprocket before the top pulley sprocket gets pressed back into the bearing.
    You will notice that the sprocket, at the front, for the oil pump is single row, and the sprockets for the cam belt pulley, and the rear, are double row.
  3. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #303 ernie, Feb 26, 2014
    I had to learn the hard way that it was better to have the top sprocket off, and to install the timing chain on BEFORE I pressed it into the bearing. There is not enough room to feed the double row chain over the teeth of both sprockets, if the top sprocket is already installed.
    So I had to pull it back out. Then I slid the bottom sprocket off the crack shaft a little bit. Fed the chain to the bottom and top sprockets. THEN I reinstalled the pulley sprocket into the block/bearing.
  4. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #304 ernie, Feb 26, 2014
  5. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #305 ernie, Feb 26, 2014
  6. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #306 ernie, Feb 26, 2014
  7. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #307 ernie, Feb 26, 2014
  8. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #308 ernie, Feb 26, 2014
    I put the little lock fitting on like so. With the keyway facing the barrel of the tensioner. That keyway is so that the dowel can run between it.
  9. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #309 ernie, Feb 26, 2014
  10. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    Ernie, this is a great thread. I can't say thanks enough for taking the time to post such detailed pics and info.
  11. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #311 ernie, Feb 26, 2014
    With the spring in place I slid the pad into the housing of the tensioner. Sorry I don't have any pics of this but, it's pretty self explanatory.
    What I do have is a pic of how the the shim should be facing when it gets installed.
  12. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #312 ernie, Feb 26, 2014
    Then insert the tensioner housing back into the hole in the block, feed the chain over it, and bolt it down.
    I don't have a pic of this but, when you slid the shaft of the pad, into the housing, the part of the pad that is offset goes on so it's closets to the block. If you look back at the pics I posted of the side-by-side you'll see what I'm talking about. Anyway that offset goes towards the block.
  13. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Ernie, this thread is money (as are all of your threads).
    This should be nominated thread of the month and thread of the year, and quite frankly one of FChat's all time greatest threads.
    The time that Ernie spends explaining in great detail is priceless, and he does it on his time without a penny of compensation.
  14. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Thanks fellas.
  15. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Unreal Ernie. What would this kind of "major" cost in a shop?
    How many hours?
    How much for parts/materials?
  16. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I was thinking this should be called "rebuild" and not "major".
    Once again, big thanks for taking the time to post this. Much appreciated!
  17. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Ernie slow down your making me dizzy.
  18. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Thanks again guys. I'll try to answer some of the questions.
    How long?
    I have WAY more hours into this than it would take me had I not been documenting everything, and then posting it. No joke like 3-4 times the amount of time had I just been wrenching on it nose to the grind stone.
    What did the parts cost?
    I haven't totaled it up but with everything I think its a good guess I'm over $2500.
    What would it cost and a shop, or dare I even say …………dealer?
    I don't even wanna think about it. Some insane price I'm sure. I am as deep into this thing as you can get short of a complete rebuild. Crazy, money I tell you, crazy money had it gone to a shop/dealer.
  19. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    I'm happy to post it up.
    Guess what is gonna be featured tomorrow?
  20. fatbillybob
    Aug 10, 2002
    29,272
    socal
    Did you get the new pads from SRI?
  21. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Degreeing the cams?
  22. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Mmmmm, dunno bout tomorrow, but eventually.
  23. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #323 ernie, Feb 27, 2014
    Now it's time to change the tensioner for the oil pump chain.
    Don't be fooled by this little screw on the tensioner, or on the other end for that matter. It will NOT help you remove tension from the pad. It is actually used AFTER the chain gets reinstalled. Even if you wanted to try and remove it, the shaft is in the way. More on that later.
  24. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #324 ernie, Feb 27, 2014
    I found it easiest to remove the tensioner from the back of the cover, and then disassemble it.
    First I'll removed the nut attaching the tensioner to the shaft on the bracket.
  25. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #325 ernie, Feb 27, 2014
    Be sure not to lose the lock washer under the nut. Also pay attention to how the arms of the tensioner are positioned on the shaft. The bracket for the pad is on top of the bracket for the tensioner.
