348 engine out major | Page 15 | FerrariChat
Discussion in 'Technical Q&A' started by ernie, Feb 22, 2014.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #351 ernie, Feb 27, 2014
  2. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #352 ernie, Feb 27, 2014
    With the pulley bearing out of the cover it exposed at o-ring inside that needs to be replaced. I carefully removed the o-ring using a pick.
  3. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #353 ernie, Feb 27, 2014
  4. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #354 ernie, Feb 27, 2014
  5. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #355 ernie, Feb 27, 2014
  6. Ricambi America
    Sponsor Owner
    STOP. Be very very very very careful with that bearing.
    ernie likes this.
  7. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #357 ernie, Feb 27, 2014
  8. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Oh?
    Go on.
  9. Ricambi America
    Sponsor Owner
    They are known to be overfilled with grease, and the seal fitment is very inconsistent. They can throw grease within 10 minutes, 10 days, or 10 weeks --- but I have yet to find one that is actually as good as the original SKF. Whoever is manufacturing them (it is not SKF, Timkin, NSK, etc from what we can determined) is doing so under contract from Ferrari and stamping a Ferrari part number onto it (170787), but ignoring all the other BICC conventions on product labeling, and presumably QC
    ernie likes this.
  10. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #360 ernie, Feb 27, 2014
    AH HA!
    Thanks for the heads up Daniel-San! And good looking out!
    But it's already too late. The bearing has already been installed. Guess I'll be the guinea pig and see what happens. Hopefully I'll get lucky. It's not that I'm ignoring Daniel's warning, it's that it really is already too late. All these posts are all after the fact. The belt is already on the engine and everything has been timed. SO it really is too late. I'd have to tear it all down again and I'm not gonna do that. If the bearing bites the dust, I have to tear it all down. If I head Daniel's warning, I have to tear it all down again. Either way it will have to get torn down, AGAIN. So SCREW IT, the Stooge in me will roll the dice and see what happens.
  11. Ricambi America
    Sponsor Owner
    I have struggled heroically with Hill Engineering on this one. Hill has a bespoke design, but it has been held up in a legal fight over T&C with the core manufacturer.
    Maybe somebody else has a quality replacement (in lieu of the Hill eventually getting released -- but we're going on over 1 year now :( ). But it ain't me. We pulled the 170787 from our shelf and literally threw them into the dumpster. Luckily, they're not very expensive.
  12. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Again Daniel, Thank you VERY MUCH for this info.
    Sadly, it comes to me too late. :(
  13. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Okay lets get back to putting this thing back together, after SOMEONE was a party pooper. :p Hahahahaha!!! I'm ONLY KIDDING Daniel-San! :D :D :D
  14. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Remove the inner seal and let oil do the lubricating.
    ernie likes this.
  15. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #365 ernie, Feb 27, 2014
    Now to install the new mystery bearing into the cam cover. "WARNING, WARNING, DANGER WILL ROBINSON!" :D
    I turned the cover over and set the bearing into the hole as even as I could.
  16. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    It's already back together Tim. I mean the bearings, the cover, the bottom sump pan, the water pump, cam belt bearing, cam belt, and the timing has been set. It's already finished.
    If I have to open it back up I WILL be keeping this bearing in mind!
  17. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #367 ernie, Feb 27, 2014
  18. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #368 ernie, Feb 27, 2014
    I stop just before the front of the bearing gets to the grove for the o-ring. I'm pointing to the groove with the tip of the pick.
  19. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #369 ernie, Feb 27, 2014
  20. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #370 ernie, Feb 27, 2014
    Then the mystery bearing gets finished being tapped into the cover.
    Now the shim gets centered over the outer race of the bearing.
  21. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #371 ernie, Feb 27, 2014
    I fitted the snap ring, but not all the way. I only inserted it on the inner rim of the cover.
    See the shim is not an exact fit and moved around while I was trying to get the snap ring installed.
    So the snap ring got installed on the inner diameter of the bearing hole in the cover, just about the shim.
  22. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #372 ernie, Feb 27, 2014
  23. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #373 ernie, Feb 27, 2014
    And here we have the new mystery bearing locked in place ready for work.
    Thanks again for the heads up Daniel, and the suggestion Tim. Guess we'll find out how well this bearing holds up.
  24. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    Do you heat the parts before fitting the bearings? Just curious.
    Art
  25. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #375 ernie, Feb 27, 2014
    Now to reinstall the timing chain cover.
    After making sure the surface of the cover is clean, and the mounting surface on the block is clean, and oil free, …….. I apply some Hondabond to the cover. The set the gasket on the cover and smear some more Hondabond to the seal.
