348 engine out major | Page 17 | FerrariChat
Discussion in 'Technical Q&A' started by ernie, Feb 22, 2014.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #401 ernie, Feb 28, 2014
  2. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #402 ernie, Feb 28, 2014
    The rear cam belt cover for the 5/8 bank of the engine gets slid behind the tensioner bearing.
    It's easier for me to do it this way because I don't risk bending up the cam belt fence on the drive pulley, trying to fit the cover after the pulley is installed.
  3. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #403 ernie, Feb 28, 2014
    Index the drive pulley so that the keyway in the pulley slides over the woodruff key, and push the pulley onto the shaft.
    Here you can better see what I was describing. The rear cover is just wide enough to create an issue if I were to try and install it after the drive pulley had been secured in place.
  4. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #404 ernie, Feb 28, 2014
  5. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #405 ernie, Feb 28, 2014
  6. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #406 ernie, Feb 28, 2014
    I gently tapped the bearing to get it started into the mounting hole. I only do this to get the bearing in the hole engine so I can thread the retaining bolt in.
  7. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #407 ernie, Feb 28, 2014
    Once I have the bearing shaft in the mounting hole enough for the bolt to grab some threads, I then tighten it down. I use the bolt to pull the bearing into the hole as it gets tightened.
  8. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #408 ernie, Feb 28, 2014
  9. Volair
    Volair Karting
    Apr 11, 2013
    241
    Carmel, Indiana
    Bart
    Would you care to elaborate?
  10. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,324
    Palos Verdes
    Vince V
    From experience with the BMW version, the plastic ones are less likely to damage the housing internals or cause problems in the case of failure. BMW just came up with a better nylon version. The suggested replacement interval is every other major or 7/10 years depending on your preference, or if it shows signs of weeping. Interestingly, mine did after 6 years so we changed it. We always error on the side of caution where water pumps are concerned, because its really bad when they fail and replacing them is an engine out event.
  11. Ricambi America
    Sponsor Owner
    ernie - did you do anything in particular with the lower gear pulley and its fences?
  12. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,550
    San Carlos, CA
    Mitchell Le
    Did not look like he spot welded it, did he?
  13. fatbillybob
    Aug 10, 2002
    28,989
    socal
    #413 fatbillybob, Feb 28, 2014
    We have a bizillion miles on the fleet of 348's and the waterpump impellers are not a problem. A questionable source or questionable quality on a timing cover bearing is a problem. Ferrari is known to not stand behind their stuff. That means "we" either have to engineer alternatives (in comes Hill Engineering and SRI) or change our maintenance schedules if using known weak parts in the supply chain. I don't think there is an alternative so sometimes you need to just go with it. But you take actions to mitigate risk.
  14. AceMaster
    Feb 6, 2009
    34,776
    Ontario, Canada
    Ernie, is there a torque rating for this ring nut, or do you just tighten it slightly better than snug? (I know it is not gorilla tight)
  15. jerhofer
    jerhofer Formula Junior
    Jul 10, 2013
    291
    Rockwell, NC
    Jerry Forthofer
    I just finished reading the entire thread. Great job!
    How many miles on those chain tensioner pads?
  16. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Naw.
    I know I should have gotten them spot welded, but I didn't.
  17. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    As far as I know those were the originals from the factory, as was the water pump and drive pulley bearing.
  18. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    When I pulled it off it was on pretty snug to a little bit tight. I'm sure there is a torque rating for it. I just put it back on by feel.
  19. jerhofer
    Jul 10, 2013
    291
    Rockwell, NC
    Jerry Forthofer
    So how many miles has your car traveled?
  20. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    82,000 miles/131,000 kilometers.
  21. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    #421 348Jeff, Mar 2, 2014
    ernie likes this.
  22. gaw111
    gaw111 Formula Junior
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    Another impressive thread Ernie! Now I feel even better about doing this myself! I know my belt was changed but that is all I know. So, the plan is to dig in deep like you did.
    Is your car up and running yet?
  23. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    AH!
    Good idea! Thanks for posting that.
  24. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    No not yet, still have some things to do.
  25. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #425 ernie, Mar 2, 2014
    Speaking of.
    Before I put the cams back on I found top dead center for the #1 piston. I used what I had laying around. Took a piece of wood and drilled holes in it so I could mount is on the bolts for the valve cover. From the bottom valve cover bolt to the center of the spark plug hole it was it was roughly 3" (76mm). I drilled a hole in the wood to hold the extension centered through the spark plug hole, and on the top of the piston.
    BONNEFOND likes this.
