348 engine out major | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by ernie, Feb 22, 2014.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #26 ernie, Feb 22, 2014
  2. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #27 ernie, Feb 22, 2014
  3. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #28 ernie, Feb 22, 2014
    With the clips removed now I could get my wrenches on the brake line union the get it to crack loose. Be careful with the little screw on the brake line because it is pretty soft and can strip easily.
    Now be sure to put something under the line because it will bleed like CRAZY! I haven't figured out how to get the bloody thing to stop bleeding, so I just let it bleed into a pan until it stops on it's own. I'm sure I should drain all the fluid out of the line first, but I'm a Stooge, and too lazy to do that.
  4. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #29 ernie, Feb 22, 2014
    Next the clutch line gets disconnected from the joint on the left hand shock tower.
    Again, this thing is gonna bleed like a stuck pig. So be sure to have a drain pan under it.
  5. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #30 ernie, Feb 22, 2014
  6. AceMaster
    Feb 6, 2009
    34,793
    Ontario, Canada
    Finally! I am really looking forward to this one....
  7. AceMaster
    Feb 6, 2009
    34,793
    Ontario, Canada
    Great idea. This saves an oil mess all over your floor.
  8. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #33 ernie, Feb 22, 2014
    While the brake/clutch lines were bleeding out I went back to the front of the engine to disconnect some more stuff.
    Here I loosen the clamps for the water pump hoses attached to the radiator feed tubes. I didn't remove the hoses, as it is easier to let them slide of on their own when you are dropping the engine. At least that's how I do it.
  9. AceMaster
    Feb 6, 2009
    34,793
    Ontario, Canada
    Ernie, is it necessary to remove the airbox when dropping the engine? I understand that the hoses need to be disconnected, but the airbox does not appear to be restricting the motor from being removed.
  10. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #35 ernie, Feb 22, 2014
  11. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #36 ernie, Feb 22, 2014
  12. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #37 ernie, Feb 22, 2014
    Then get back under the wheel well and disconnect the brake sensor cables. They are clipped right up under the rear fenders on both sides.
  13. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #38 ernie, Feb 22, 2014
  14. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #39 ernie, Feb 22, 2014
    Looking around I noticed that the vapor recovery tubes attached to the oil tank need to be removed. So I removed the both of them.
  15. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    You guy will notice I haven't mentioned anything about the air conditioning yet. Well that is because I have no air conditioning pump. I have had it removed from my car for years. So unfortunately I don't have any pics for disconnecting it.
    Having said that, those of you running a/c will need to go get the a/c evacuated BEFORE you start tearing into the engine.
  16. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
  17. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #42 ernie, Feb 22, 2014
    After you have the ecu's removed there is still a few other things your are going to need to disconnect.
    These connectors that run to the dash.
  18. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #43 ernie, Feb 22, 2014
  19. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #44 ernie, Feb 22, 2014
  20. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #45 ernie, Feb 22, 2014
  21. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #46 ernie, Feb 22, 2014
    Almost ready to drop this thing. But first I have to remove the bumper.
    Remove the four nuts in the fenders, two on either side of the bumper, holding it in place.
  22. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #47 ernie, Feb 22, 2014
  23. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #48 ernie, Feb 22, 2014
    For removing the dual can muffler I give you this link http://www.ferrarichat.com/forum/technical-q/296274-348-clutch-removal.html The muffler removal starts at post #13 of the link. You also see how to remove the bumper again.
    The reason I don't show how to remove the muffler, is because the exhaust system on my car is completely custom, so it wouldn't apply to the vast majority of the 348's out there. That and I have some show and tell for another thread. ;)
    So here is a pic of it already removed.
  24. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #49 ernie, Feb 22, 2014
  25. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #50 ernie, Feb 22, 2014
    I left this bit for last.
    I disconnected the lines from the fuel pressure regulators, and then fuel lines from the fuel filters. Place a bucket under the lines to catch any gas that leaks out, and have PLENTY of rags to catch fuel coming from the FPR's.
    I did this last because I don't like the smell of gas in my garage, and to reduce the risk of an accidental fire.
