348 engine out major | Page 20 | FerrariChat
Discussion in 'Technical Q&A' started by ernie, Feb 22, 2014.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #476 ernie, Mar 2, 2014
    A look at the timing specs for a 348 with catalytic converters says.
    Intake:
    Opens - 12º before tdc
    Closes - 56º after bdc
    Exhaust:
    Opens - 54º before bcd
    Closes - 10º after tdc
    Meaning, my cam marks are right on the money. Spot on for a 348 with cats. I also checked the intake cam marks, and the result was the same. Intake cam opened at 12º before tdc. Cam marks dead nuts on the money.
  2. fatbillybob
    Aug 10, 2002
    29,275
    socal
    #477 fatbillybob, Mar 2, 2014
    I love the wooden meat skewer on the dial gauge. For dinner tonight you can bar-be que kebob's with it. You have topped 348 gearbox "especial tool numero veintiseis." There is no one of higher stoogeness alive on this planet.
    ernie likes this.
  3. gaw111
    gaw111 Formula Junior
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    Makes perfect sense, thanks. On my Porsche, I always went with the TDC mark on the flywheel.
  4. gaw111
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    Hey Ernie, what size ring nut socket is that? Need to put it on my list of tools to get..
  5. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    I have no idea George, I borrowed it.
  6. gaw111
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    #482 gaw111, Mar 3, 2014
  7. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Ernie, it is a proper assumption to say that the cam timing adjustment is limited to the dowel holes within the cams and pulleys? That is, without machining your own pulley?
    I'm just wondering what happens when "between holes"? Or are the factory holes sufficient to allow a small degree change?
  8. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,674
    San Carlos, CA
    Mitchell Le
    If it is in between holes, you remove the pulley, turn it one belt notch, and now you have a bunch of new holes to play with. Essentially what Ernie did when he had to adjust that one cam just a hair.
  9. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #485 ernie, Mar 3, 2014
    The dowel holes on the cam are just fine for making small adjustments. If I'm remembering this correct, each dowel hole will adjust the timing about 1/2º.
    Here is the chart from the shop manual for the pulley, and the cam dowel holes.
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #486 2NA, Mar 3, 2014
  11. tbakowsky
    Sep 18, 2002
    20,044
    The Cold North
    Tom
    So much nicer to work with..
  12. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Also the dowel pins are internally threaded making adjustments a bit easier.
  13. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Tell me about it!
    Trying to pull out the dowel when there was tension against it was SOOO frustrating. you have BARELY anything to grab. It would have been so nice to just unscrew it.
  14. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    End cutting pliers like these are the best thing I've come across for removing the dowels. Without them it's an exercise in frustration.
    They usually have them at most tool stores.
    SK Hand Tool 18507 7" End Cutter Pliers
    ernie likes this.
  15. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    A dowel that is internally threaded is called a "pull dowel". The purpose is the ability to get it out of a blind hole.
    I assume when you say that it makes adjustments easier, you mean since you can remove it and place it in another hole?
  16. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Yes
  17. fatbillybob
    Aug 10, 2002
    29,275
    socal
    Makes no sense to me why you guys would have issues with the pins. You need to relieve pressure on them and they slide right out. No force or swearing is needed.
  18. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    Sometimes the pins are a little rusted on the older cars, and some cars were a very tight fit to start off with. The later cars have it much easier - 355s, 550s, etc. - than earlier cars like the 308.
  19. F430SA
    F430SA Rookie
    Nov 18, 2010
    4
    Faisal
    what an amazing thread wow
    good job
  20. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Not really a big problem. I was merely pointing out that with a Lamborghini it is quite easy to insert a small screw into the dowel giving you something to hold onto when extracting it. A much bigger issue is the holes in the camshaft. I can't imagine why they did not continue them full-circle. Frequently it seems like even one or two more holes would do it. It's a nuisance to remove the pulley and belt and reposition them.
  21. fatbillybob
    Aug 10, 2002
    29,275
    socal
    I never believed that one could lock and swap belts with any accuracy. I have always advocated cog removal as Ernie has shown. That frees up the pins. Requisite cleaning ensures access to all holes. You set up cam as Ernie has shown but I would add that you want the cam hole to be in the middle range of the cog holes so that you can adjust. That avoids Ernie's gotcha that mitchell reported the solution for. Then you cam time and see if you are on or off. If off you don't need to pry the pins off but grab the cam shaft and wiggle and the pin will free with little more than finger pressure. You have to grab the shaft anyway to adjust the off timing and test the timing in the needed hole. That's just the process.
  22. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    These are carpenter's pliers (i believe). Very handy for removing dowels
  23. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    Thanks for the explanation. I'll be sure to pass it on to the guys at the Ferrari dealership / restoration shop where I used to work (and time cams day in and day out). :rolleyes:
    I'm not sure why you're making a point of this. I merely posted a link to a tool that folks will find very useful.
  24. fatbillybob
    Aug 10, 2002
    29,275
    socal
    Sorry not trying to put down your experience or offend you. I've only done this for thirty or so years not as a pro. I see the problem from the perspective of a non-pro trying to help non-pros. I can see how this problem can be a pita to non-pros trying to up their game from cam setters using assembly marks to cam timers with degree wheel and dial gauge. You are trained, we are not. If you were a non-pro it would be easy to loose site of the goal and get caught up in minutiae. If one fails to understand the shaft needs to be moved to adjust the shaft position anyway (from years of lock and swap) one could be stuck on forcing the pin out instead of relaxing the pin by moving the shaft. You see, our perspectives are different.
