348 engine out major | Page 21 | FerrariChat
Discussion in 'Technical Q&A' started by ernie, Feb 22, 2014.
  1. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Wow Ernie, fantastic thread! Tons of detailed information and great photos. What a great resource for the rest of us. I'm surprised no one has mentioned what I found to be the stoogiest finding of the thread: Check out page 4, #77. Anyone appreciate the beautifully machined titanium spark plug wire separators on top of the cam covers? True ingenuity!
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Thanks Bret, I will be adding a pair of these to the tool chest.
  3. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    :D Adapt and improvise.
    Those are getting replaced with a set of proper separators I bought from Ricambi.
  4. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Hey, zip ties are one of the great inventions of modern man! I thought your devices were well engineered, and certainly more robust than the originals.
  5. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    Since the belts stretch a lite over time this results in the cams being retarded a degree or two. So when setting up the engine with new belts why not check how many degrees the cams were retarded before removing the old belts. Then divide that in half and when installing the new belts advance the cams that amount. I.e. if the cams were retarded 2 degrees, set them up with 1 degree of advance. Thus as the new belts wear (stretch) the cams will, over time, move from +1 degree to -1 degree, assuming the new belts stretch the same as the old. I'm just thinking that running +1 to -1 over the life of the belts would be better than +0 to -2.
  6. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    #506 pnicholasen, Mar 5, 2014
    One thing I did which may or may not work when I put it to the test is removing the studs along the bottom of the front cover casting. It's such a PITA to have to remove the oil sump first to remove that front cover, that I used a stud remover to pull the studs, and substituted bolts. Theoretically now when I want to check those tensioner blocks I can pop the front cover off much easier.
  7. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #507 ernie, Mar 5, 2014
    Here is a pic of the bottom of the engine before I installed the pan. Pictured are the two sump pick-ups, the pump itself, the windage tray.
  8. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #508 ernie, Mar 5, 2014
    A pic of the snap ring holding the oil pressure spring in place. It's on the back side of the pump. There is another one on the front of the pump as well.
    In the second you may be able to see the ball bearing through the hole.
    From what i've read the oil pressure is fixed from the factory via the spring pressure. Only way to adjust the oil pressure is to replace the springs.
  9. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #509 ernie, Mar 5, 2014
  10. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #510 ernie, Mar 5, 2014
    One thing I forgot to do while I had the engine on the subframe still was to remove the rear main seal cover. This needed to be removed so I could get the bottom pan on.
    So I removed the nuts holding it to the block, and tapped it off with a screwdriver handle. I couldn't really get it off all the way because the engine stand was in the way, but enough to the the pan back on the bottom of the block.
  11. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #511 ernie, Mar 5, 2014
    Then some Hondabond all around the rim on the pan. Of course this was after I made sure both the pan and the bottom of the block were dry, and clean of oil.
  12. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #512 ernie, Mar 5, 2014
    I then carefully put the pan back on, and tightened down the nuts, festooning the pan back on the block.
    I know, I know, I need to clean up the bottom of the block better.
    Oh one more thing. See the oil line fitting to the left of my socket. Then see the raised casing of the oil galley running to the front of the block, just past the copper nut. The little round area at the end of the casting is where the o-ring I replaced is, on the inside of the block. The o-ring is sandwiched between the pan and the oil pump.
  13. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #513 ernie, Mar 5, 2014
  14. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #514 ernie, Mar 5, 2014
  15. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #515 ernie, Mar 5, 2014
  16. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    That's a good idea, but.
    You still need the bottom pan off to release the oil chain tensioner once it's reinstalled.
  17. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Damn, you're correct.
  18. fatbillybob
    Aug 10, 2002
    29,272
    socal
    Additionally it is not a good idea to thread steel into aluminum many times. Studs cut down the potential damage to aluminum and changes the force profile places on the threads.
  19. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    Looking great Ernie!!
    It's time for my 355 major once again...unfortunately this time I simply don't have the time to do it, I know if I started it I'd have a pile of parts in the garage for months. So giving in, taking her to my trusted local ind shop Pocono Sportscar...
  20. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Helical inserts are the solution. Plus, I doubt the bolts would be removed often enough to make it an issue.
  21. fatbillybob
    Aug 10, 2002
    29,272
    socal
    A theoretical one yes a practical one no.
  22. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #522 ernie, Mar 6, 2014
  23. fatbillybob
    Aug 10, 2002
    29,272
    socal
    That PWC leaves a nice finish. It would have been cool to weld up and cut those cams for top secret horsepower generation. In the old days Web Cam in Riverside were the hot dogs. They were welding up the 308 cams and doing the P6 grind.
  24. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    I gave that some very serious thought while I had the cams out. I talked with a few cam shops, Web included, and it would have run me around $3000 for the welding and regrind. Then there was getting the cams profiled was about another $500 +/-. I even looked into having new cams made from blanks and that would have run around $6,000. So that is for a later date and time.
  25. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,920
    Atlanta
    John!
    Cat Cams in Belgium make a fabulous set of cams for the 355 for around $3500 or so. I have communicated with both brothers who own Cat a couple times now and they are willing to make any Ferrari cam and indeed have several they have made which aren't on their website. For future reference I guess
    ernie likes this.
