348 engine out major | Page 26 | FerrariChat
Discussion in 'Technical Q&A' started by ernie, Feb 22, 2014.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #626 ernie, Apr 16, 2014
    The new seal gets pressed on from the front of the housing. This is best done with a shop press, but I used what I had.
    I centered the seal as best I could, put my 2x4 over it, then tapped it into the housing. Once I got it it about half way, they I gave it a couple of hits with the sledge hammer, to seat it in place.
  2. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #627 ernie, Apr 16, 2014
  3. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #628 ernie, Apr 16, 2014
    The shaped rubber gasket is a bit of a pain to fit. So again I used Hondabond to hold it in place. The last time I did this I tried to put the rubber gasket on dry, but just ended up getting frustrated as it kept falling out of the groove. So I apply Hondabond, and then fit the gasket. Beside, it helps seal things up better.
  4. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #629 ernie, Apr 16, 2014
    Now come the tricky part.
    The new seals are a bit stiff, and can be difficult to install. You do not want to have the double lips fold backwards during the install. They bot get installed point towards the inside of the engine. I needed to open them up a little bit to get them to fit over the back of the crank.
    I started by bending them up with my fingers. Then tested it on the crank, and adjusted it a little bit more.
  5. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #630 ernie, Apr 16, 2014
    Once I had the lip starting to open up enough I then used a funnel to flare it open more. I placed the funnel face down with the spout point up. Then made sure I had the lips opening how I wanted, and gently pressed down to flare the seal ups a bit. I didn't do it too much, because I wanted a snug fit on the crank. So I flared it, tested it, flared it, tested it, until the first lip was on.
  6. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #631 ernie, Apr 16, 2014
    With the first lip over the back of the crank, I then used a plastic upholstery trim tool to gently get the second lip over the crank. Again, remember you want the double lips pointing INTO the engine, not folded backwards. They get installed facing the same way they are angled in the seal race.
    After I got the second seal fitted over the crank I pushed the seal/housing all the way on. The single seal get fitted facing OUT. But that pretty much does it by itself once the inner seals are on.
  7. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #632 ernie, Apr 16, 2014
  8. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #633 ernie, Apr 16, 2014
    Reinstall the nuts, and the bolts. Remember that the bolts go back in from up under the back.
    That how the rear main seal gets replaced Stooge style.
  9. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #634 ernie, Apr 16, 2014
    Now for something a little bit different.
    When I pulled the axles out i noticed that one off the CV joints had oil in it. The gear oil had gotten past the retaining bolt. So before I put the gearbox back on I decided to address that issue.
    First up I removed the retaining bolt with my impact wrench.
  10. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #635 ernie, Apr 16, 2014
  11. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #636 ernie, Apr 16, 2014
  12. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #637 ernie, Apr 16, 2014
    I cleaned up the flange and washer really well, making sure they were clean, dry, and oil/grease free. The it was HONDABOND TIME! Smeared a bunch of Hondabond on the back side of the washer and base of the bolt, and reinstalled it. Sorry fellas, but I didn't take pics of that bit. I'm sure you can imagine how to do it has it's not rocket science.
  13. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #638 ernie, Apr 16, 2014
    Time to get this thing put back on. I had already remounted the engine to the subframe. That was basically the reverse of removal. Simply lower it onto the motor mount retaining bolts, and tighten it down.
    With that done I set the gearbox on my floorjack and rolled it in place. You will have to juggle the gearbox to get it to slide over the bolts on the block. Once I got it wiggled on far enough, for the bolts to stick through the holes, I used the nuts to pull it the rest of the way on. Tightened them all little by little, going around, until the gearbox was attached to the block.
  14. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #639 ernie, Apr 16, 2014
    To align the bolt holes for the gearbox mount to the subframe I used some drift punches. Lined things up and installed the bolts.
  15. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #640 ernie, Apr 16, 2014
  16. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #641 ernie, Apr 16, 2014
    Here it sits ready for install, with most of the goodies in place. The headers still need to go back on, as do the axles, but for the most part it's all finished up.
    That's pretty much it kids. How I did the engine out MAJOR service on my 348.
    STOOGE STYLE!!!
    Happy wrenching.
  17. PAP 348
    Dec 10, 2005
    100,204
    Mount Isa, Australia
    Pap
    Again, awesome stuff man!! Thanks for sharing with the world! :D:D
    ernie likes this.
  18. AceMaster
    Feb 6, 2009
    34,765
    Ontario, Canada
    This has to be one of the all time greatest threads in the history of FerrariChat
    ernie likes this.
  19. flyingboa
    flyingboa Formula 3
    Nov 27, 2003
    1,564
    Italy/India
    Eugenio
    I do not know what I'd give to be a fraction of the mechanic you are. Thank you for the time you spent on this and for the knowledge you shared. I hope to be able to put this to good use in the future!
    Ciao from someone who owes you a lot! :)
  20. gaw111
    gaw111 Formula Junior
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    Awesome job Ernie! This is a thread I will remember and will review it before I start my major service. Thanks again!
  21. jetfuel79
    jetfuel79 Karting
    Apr 19, 2014
    158
    Valdosta, GA
    David
    Hello Ferrari nation! I recently purchased a 348 and would like to thank all the F-chatters for sharing their knowledge in this awesome community. Of course a special thanks to Ernie for his AMAZING thread. I'll be staring this engine out service next month and have him as well as "jerhofer" to thank for putting together an amazing series of step by step maintenance procedures--thank you!
    That being said I'll dive right in to a few questions that I can't seem to find the answers to:
    1- Is there a substitute (interchangeable) part for the Valve Shims at a substantially lower price?
    2- Is there a general consensus about what fluids people use in their car (Redline 75W90NS) for example? What about oil? Antifreeze? I realize that there are tons of opinions about these sorts of things, just wondering if there is some sort of consensus on the brand and specific type that people are using.
    3- Has anyone drilled out their engine frame mounting holes to make the re-mating of the engine easier? If so, what diameter did you drill them out to?
    As always a big thanks to everyone for all their help!!
  22. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    First of all, welcome to FerrariChat and to The 348 Brotherhood.
    Not that I know of.
    Redline is good for the gearbox.
    Oil is up to you.
    BMW blue coolant is good.
    NO!
    Do NOT drill out the bolts hole. The bolt holes in the subframe need to stay the same size so that there is no slop/play. However you can chase the threaded holes with a tap to make sure they are nice and clean.
  23. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Hey ernie. .. Any chance you can get the sizes of the fuel vapor lines we chatted about?
    Mobilized reply by Dahveedem
  24. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    Ooooo man! I totally forgot about that.
  25. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    You are gonna make me crawl on top of my engine aren't you?
