348 engine out major | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by ernie, Feb 22, 2014.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #51 ernie, Feb 22, 2014
    Now I crawled under the front of the engine bay and loosened 12 the bolts, 6 on each side, holding the subframe to the car. I only LOOSEN them, because I still need them holding things in place, and it will be a pain to try and get them off once the subframe is sitting on the engine dollies.
  2. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #52 ernie, Feb 22, 2014
    I used two 1000/lb moving dollies to support the engine. I bought them for $20 each at the hardware store.
    They got place so that the carpeted sides were right under the subframe rails. Then with a helper I slowly lowered both floor jacks until the engine was sitting on the dollies. I adjusted the position of the dollies as needed while we were lowering the car.
  3. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #53 ernie, Feb 22, 2014
    With the weight of the car now supported by the moving dollies I then removed the two big bolts on both sides of the subframe, next to the catalytic converters.
  4. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #54 ernie, Feb 22, 2014
  5. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #55 ernie, Feb 22, 2014
    Now the 6 nuts on the shock towers, 3 on each side (for the early 348's) get removed. Do not remove the one nut in the cut out, as that holds the shock to the subframe.
    After I did that, THEN I went back and finish removing the 12 bolts on the bottom front of the subframe, that I loosened earlier.
  6. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #56 ernie, Feb 22, 2014
    Now I double checked, my triples checks, to MAKE SURE I had EVERYTHING disconnected. Then with a helper we slowly jack the body off the subframe. When you do this do it little by LITTLE. The reason is, as you are lifting the body off you want to feed the engine looms through the fire wall. So you need to lift a little then feed a little, lift a little feed a little, until you have the wiring looms completely out and the body off the subframe. Go SLOWLY!!!
  7. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #57 ernie, Feb 22, 2014
  8. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #58 ernie, Feb 22, 2014
  9. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    That's it for now kids.
    I'll be back tomorrow to continue with the thread.
    Until then, happy wrenching.
  10. TheMayor
    107,623
    Vegas baby
    Awesome thread Ernie!!!!
  11. lbell101
    lbell101 Karting
    Mar 24, 2013
    230
    Temecula, CA
    Larry
    Thanks Ernie!
    This is likely the way I will be removing mine when the time comes.
    Larry
  12. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,700
    San Carlos, CA
    Mitchell Le
    Waiting for the tensioner bearings to squeal, wow. That is gutsy.
  13. peterkarvelas
    peterkarvelas Karting
    Jun 2, 2006
    78
    RSA-Johannesburg
    Epic thread purely for its improvisation.
    Thank you
  14. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    No it doesn't.
    I just like having plenty of room to work with. I have learned it saves me aggravation when I have an easier time accessing things. So I am willing to take the extra few minutes to remove the air box.
  15. AceMaster
    Feb 6, 2009
    34,793
    Ontario, Canada
    Thanks.
    How long did it take you to drop the engine?
  16. fatbillybob
    Aug 10, 2002
    29,427
    socal
    I have never tried to do a 348 major quickly and have not done one in 10 years. However, the new owner of the bushmobile and I pulled the motor last friday at 9am and had the car running by Monday noon. We still were in no hurry but were steady.
  17. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,554
    Jeff
    Nice work Ernie :)
    Just interested, how high do you need to jack the car up to get the engine out? Was there any issues catching the front spoiler/
  18. jhfields
    jhfields Karting
    Jun 2, 2010
    102
    paducah ky.
    John H Fields
    Very nice Ernie is this your second engine out?
  19. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    Subscribed...
    Kai
  20. PeterS
    PeterS Five Time F1 World Champ
    52,996
    Goodyear, AZ
    PeterS
    WOW! Your garage will me a mess for a while! Keep on with the pics, great thread!
  21. AceMaster
    Feb 6, 2009
    34,793
    Ontario, Canada
    This should be thread of the year. Definitely thread of the month, but I will go as far as best all year.
  22. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    In one day, but it was ALL day.
    The thing is it is taking me 4 times as long to do this major because I have been documenting just about everything. Trying to get the best angle so that the picture explains quite a bit. Then if it is out of focus, or if the battery in the camera needs recharging, etcetera, etcetera. If I wasn't documenting it I could do it much faster. But because I know how you guys love "picture books" :p :D it's taking me longer.
  23. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    Yup.
  24. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    "I'm just getting warmed up."
    [ame=http://www.youtube.com/watch?v=yhVxviUIKKQ&feature=youtube_gdata_player]I'm Just Gettin' Warmed Up - YouTube[/ame]
  25. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    Okay, back to the major.
    This going to be a MAJOR, major. So I will be pulling the engine off the subframe. Why? Because the bearing for lower cam belt pulley, that runs off the timing chain, needs to be changed. That and so does the chain tensioner pads for the timing, and oil pump chain.
    Remember I like having PLENTY of room to work, so I will be removing just about everything from the engine, then putting it on an engine stand.
