348 - 348 faux leather lining reattachment | FerrariChat
348 348 faux leather lining reattachment
Discussion in '348/355' started by spectre007, May 15, 2024 at 11:22 AM.
  1. spectre007
    spectre007 Karting
    Mar 31, 2015
    75
    London
    Hi all,
    I've got some flappy pillar / roof / rear shelf faux leather lining in my 348TS. Was wondering if someone could advise me on a process and products to reattach? Also does anyone have a service manual link to aid in dismantling the interior (if such a thing exists)?
    Any advice or links to threads I missed where this gets covered would be appreciated!
  2. whyte
    whyte Formula Junior
    Apr 25, 2006
    408
    Merritt Island, FL
    John C
    I did this many years ago. Most of the pieces are fairly obvious as to how they are removed, but there is a guide somewhere. For what it's worth, here is what I recall:
    At least some of the bolts for the rear deck trip are in the front of the engine compartment, and are removed through there. I think the cushioned trim under the window? Then, the top pieces I believe are removed by pulling the weather stripping off, and drilling the rivets that are exposed. You have to rivet it back when you are done.
    As for reattaching the vinyl, I generally use 3M spray adhesive for headliners (80 or 90). Spray, let it set a few minutes, then pull taut and attach.
  3. A348W
    A348W Formula 3
    Jun 28, 2017
    1,756
    North Wiltshire, UK
    did mine with evostick. not sure if you get that in the us.
    removing the pieces, I remember as per John’s post.
    all fairly easy, just used lots of cloth pegs to secure edges when glue applied.
  4. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    7,964
    Atlanta, GA
    Steve D.
  5. steved033
    Apr 12, 2017
    7,964
    Atlanta, GA
    Steve D.
