348 - Flywheel & Clutch Fastener Torque | FerrariChat
Discussion in 'Technical Q&A' started by Animate, Apr 1, 2005.
  1. Animate
    Animate Formula Junior
    May 21, 2004
    272
    BC,Canada
    #1 Animate, Apr 1, 2005
  2. vincent355
    vincent355 F1 Veteran
    6,321
    Wine Country
    Vincent
    James,
    the manual has the 6 flywheel case bolts @ 24.6 Nm
    Can't seem to find the other ones, but as I don't think they are into an aluminium casing they can be tightned more.
  3. Animate
    May 21, 2004
    272
    BC,Canada
    Thanks Vincent. BTW, I bought a Torx bit for the flywheel case bolts and the fit is quite poor. Good enough to tighten them but a bit loose for comfort. Are they a variant of the Torx head?
  4. vincent355
    6,321
    Wine Country
    Vincent
    I don't think so. I used standard tools from my set of torx bits and I don't recall a poor fit. Which size bit do you have? I could go in the garage tommorrow and check which sizes I have.
  5. Animate
    May 21, 2004
    272
    BC,Canada
    I used a T45...
  6. vincent355
    6,321
    Wine Country
    Vincent
    I think I used a t50.
