348 front bearing removal | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by ernie, Apr 27, 2009.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    I had no rubber dust ring on my bearing at all, so it wasn't a problem.
  2. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    #52 ernie, May 14, 2012
    Update.
    This past Friday I changed my right front wheel bearing. It was giving wheel vibrations while I was driving on the freeway. So it was time to put a new one on.
    I got the bearing off pretty much the same as I did the left side. But thanks to a VERY helpful tip from an f-chatter I was able to EASILY get the inner bearing race off the flange.
    Looking at this picture, I inserted 2 screw drivers into the holes on the front side of the flange. I did this with the flange off of the hub, and of course with the nut off too. I just forgot to take the pic when I had it off. Anyway. With the screw drivers in the holes I turned the flange upside down, so that the screw drivers where on the ground, then in banged the flange on the ground, forcing the inner bearing race off.
    I don't remember exactly who it was that told me about this, but THANK YOU very much for the tip. It really made the job sooooooo much easier the second time around.
  3. 350HPMondial
    350HPMondial F1 Veteran
    5,195
    Edwardo
    Thanks,
    Very much,,,
    I just popped my RH front bearing,, on my Mondial 8.
    The bearing is full of crap and dirt.
    ( It was missing a dust cap.)
    Edwardo
  4. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    Glad to be of help Edwardo.
  5. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    I think it was me. Also its much easier to undo and replace the hub nut as the first/last task by shoving a screwdriver in the brake disc so it limits against the caliper.
    ernie likes this.
  6. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    Ah HA!!!!!
    Thank you, thank you, THANK YOU!!! That tip was a HUGE help this time around.
    Thanks for that tip too. I didn't have to worry about that as I have a really good impact wrench. But if I was just using a breaker bar that would have been a definite must. I actually use that trick when I'm breaking loose the nuts on the cv joint.
    Thanks again.
  7. pl365322
    pl365322 Rookie
    Nov 24, 2015
    5
    Fauvillers - Belgium
    Philippe Leclercq
    I need to change the RF bearing on my 1991 348ts but I have read that NSR TGB10894S03 bearing wont fit to ABS car due to the dirt lip.That bearing is cheap here in Belgium but if it won't fit.........Any advice are welcome.
    Phil
  8. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #58 Wade, Jun 1, 2017
    Can you take some side by side photos of the two bearings?
    Here's the specs for the TGB10894S03 (Citroen), from page 38 of the linked pdf:
    http://www.vtl.rs/katalozi/SNR-opsti_katalog.pdf
  9. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    I don't know who told you that, or where you read it. From the experience on my car ('90) that is not true.
    I am running that exact bearing on both the front right, and front left of my car, AND as you can see in post #3 http://www.ferrarichat.com/forum/138607509-post3.html where I remove the ABS sensor, also in post #8 http://www.ferrarichat.com/forum/138607573-post8.html the ABS wheel is attached to the back of the bearing. So it did fit my on my 348 which has the ABS hardware.
    You may want to ask the bearing supply shop what their return policy is if the bearing doesn't fit. Out of curiosity how much is that bearing in Belgium?
  10. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    On my ABS 328 I had to grind off 1mm of the metal dust shield so it didnt contact the raised rubber oil seal on the bearing. Maybe its not the same on 348, and the problem is not insurmountable.
  11. pl365322
    pl365322 Rookie
    Nov 24, 2015
    5
    Philippe Leclercq
    Ernie,
    I had a 1st quotation about the SKF one at 261€ each but not available through their supplier chain.
    I received another quotation from the same company,here in Bruxelles (www.123roulement.com), for the SNR TGB10894S03 at 150€.
    (https://www.123roulement.com/roulement-TGB10894S03.php) They did gives me a discount.
    When you say you did not had any dust seal on yours,did you removed them ? May I remove the inner one if I have problems ?
    Thanks for your great help.
    Phil.
  12. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    It's up to you Phil. My car didn't have it so I never bothered with it.
  13. pl365322
    pl365322 Rookie
    Nov 24, 2015
    5
    Philippe Leclercq
    #63 pl365322, Jun 9, 2017
    Ernie,
    I received the bearing today.(see pics).I thought about leaving the inner dirt seal off,as it is already not on the bearing but wonder if the grease will go off the bearing balls. 82K Km for a bearing is pretty soon to be noisy.Perhaps the dust cover was not sealed properly ?
  14. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    You could try pressing the seal in and see if you can get it to work. If not you can always take the seal out. Again, it is up to you.
  15. porphy
    porphy Formula 3
    1,203
    LouisvilleKY/Switzld
    Randall Gatz
    Here are some cross-over numbers I found for the Citroen CX bearing on the Oscaro.fr site. As best I can tell Moog is not Chinese and is US origin however I cannot source their suppliers, so it is just a suggestion. Oscaro.fr has them at good prices; about Euros 112-116. Check their US web site?
    • AUTOMOTIVE BEARINGS: BRT657
    • DELPHI: BK532
    • ***: 713640160
    • FIRST LINE: FBK259
    • MOOG: CIWB11358
    • QUINTON HAZELL: QWB491
    • RUVILLE: 6608
    • SKF: VKBA871
    • SPIDAN: 26588
    • TIMKEN: K73452
    ernie likes this.
  16. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    Nice detective work, as usually, Randy.
  17. porphy
    porphy Formula 3
    1,203
    Randall Gatz
    Thanks baby! Back in Luavul on Thursday 12th Sept.
    ernie likes this.
  18. J1an
    J1an Rookie
    Jul 26, 2012
    29
    Estonia
    Jan Vend
    #68 J1an, Jul 31, 2022
    Little update regarding front wheel bearings.
    OPTIMAL part nr: 601434 and price is 39,78€
    Rupp3r, ernie and steved033 like this.
  19. J1an
    J1an Rookie
    Jul 26, 2012
    29
    Estonia
    Jan Vend
    wow, all sold out already? I understand that winter is coming and have to stock up on parts, but damn.
