348 Gear oil | FerrariChat
348 Gear oil
Discussion in 'Technical Q&A' started by Ksullender, Mar 29, 2005.
  1. Ksullender
    Ksullender Formula Junior
    Sep 3, 2003
    887
    I have searched the threads, but wanted to see what the most recommended gear oil is for a 348? - Thanks
  2. Dr Tommy Cosgrove
    35,342
    Birmingham, AL
    Tommy
    I think there has been general agreement for Redline 75/90 NS with a splash of NS additive as needed, at least for the 308's here.
  3. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,264
    MA
    Hello, I currently use Redline 75~90 NS GL5 gear oil. I also add Redline friction modifier at approximately 50% of the Redline ratio used in their standard 75~90 gear oil. Improved shift function with minimal differential chatter. Works in my 348 spider.
  4. dapper
    dapper Formula Junior
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    Another recommendation that occassionally pops up is Castrol syntrax 75-90, not sure how available that is though.
  5. zan
    zan Formula Junior
    Nov 15, 2002
    537
    Boston
    Mark M
    I'm also deciding which oil to run in my diablos trans & diffs.
    Read this about GL5 oils, from the Redline website:
    GL-5 gears oils which are required in hypoid differentials
    are not used in most synchromesh transmissions
    because the chemicals used to provide the extreme
    pressure protection can be corrosive to synchronizers,
    which are commonly made of brass or bronze. Typically,
    the use of a GL-5 lubricant in a synchromesh
    transmission will shorten the synchronizer life by one
    half.
    http://www.redlineoil.com/whitePaper/13.pdf
  6. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,264
    MA
    Zan,
    This issue has been discussed before. My understanding is very early transmissions/ transaxles used softer materials for the synchro assembly. My underdstanding is Ferrari does not use brass or bronze. Rebuilt my 348 gearbox. Synchros were not brass or bronze. Note, the paper details all GL-5 type gear oil, not just the Redline product. My Ferrari specs GL-5 gear oil. Just my opinion, John.
    From the Redline site:
    75W90 NS
    This GL-5-type geal oil doesn't contain the friction modifiers for limited-slip hypoid differentials. This makes the transmission synchronizers come to equal speeds more quickly, allowing faster shifting and much easier low-temperature shifting. Can also be used in racing limited-slip differentials where weak spring design causes too much wheel spin.
  7. kenyon
    kenyon F1 Rookie
    Oct 7, 2002
    2,837
    East Yorkshire
    Justin Kenyon
    This is what I use and my box is slick at cold start ups. I will never use anything else.
  8. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    I'm running Mobile 1, 75-90 in mine.
  9. KoreanStallion
    Dec 1, 2021
    47
    New York. N.Y.
    Korean Stallion
    anyone with advice on preventative measures to mitigate the oil bearing/gear box issues?
  10. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,223
    Santa Clarita, CA
    Look at the Swepco gear oils. The off-road racers use it in their gearboxes. Nothing beats up a gearbox like an off-road race car.
