348 gearbox noise | Page 3 | FerrariChat
348 gearbox noise
Discussion in '348/355' started by wda24729, Jun 19, 2015.
  1. fatbillybob
    Aug 10, 2002
    29,488
    socal
    That's OK! Under-thinking is what really gets you in trouble. I think you will be just fine. You look to be taking a methodical approach and thinking before acting...bravo!
    For example you over think the welding and cutback of the lock ring. But that's OK because cutting it back like you did while not necessary makes it all clean and tidy. I like it.
  2. Jh348
    Jh348 Karting
    Sep 5, 2015
    187
    Finland
    Jesse Heinola
    #52 Jh348, Nov 21, 2016
    Okey, i think this is pretty much it. What i have to do is measure backlash, check contact with prussian blue, attach intermediate plate and clutch shaft. Just need to hope that loctite 660 in those splines+welds keep things together. First testdrive is months away, but i will get back to this thread to report how it holds up.
    So, why i took it apart was that i had whining noise in driving low gears and i found pieces of metal in sump magnet(part of failed staking lip of ringnut and general iron particles). when i removed clutch it was obvious that i had some serious problems in there, as clutchshaft had massive play on it. Clutchshaft nut was fully loosened and bearing inner races wasnt held in place anymore. That type of gear has thrust so it rubbed in casing too. Im not sure where that whine originated, becouse theres no wear or pitting on any gear. Shaft bearings rolled quietly and smoothly. So i hope whine came from that gear leaning partly on that collar where bevel gears bearing sits. It was annoying, but what surprises me most the thing operated pretty much flawlesly. We will see.
  3. Jh348
    Jh348 Karting
    Sep 5, 2015
    187
    Finland
    Jesse Heinola
    #53 Jh348, Apr 7, 2017
  4. Tommy J.
    Tommy J. Karting
    Apr 7, 2016
    67
    Norway
    Tommy Songkran Johns
    Thanks for sharing. I'm going to open up mine soon. Hope it's not too bad...
  5. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    I'm interested to know what did you use and how you set the preload.
    Congratulations on a great finished project too!
  6. Jh348
    Jh348 Karting
    Sep 5, 2015
    187
    Finland
    Jesse Heinola
    Bearing preload is altered by changing shim sizes under those bearing caps, or you want to see the tool what used to measure it?
  7. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #57 Wade, Apr 24, 2017
    Tools, yes. Other than the unobtainable and/or outrageously expensive Ferrari tools.
  8. Jh348
    Jh348 Karting
    Sep 5, 2015
    187
    Finland
    Jesse Heinola
    #58 Jh348, Apr 25, 2017
    I use an old snap-on wrench to check preloads, ferrari manual doesnt give a trustworthy values of preload so you just have to guestimate and go by feel of it. My bearings looked like new so i didnt change them and prettymuch just checked that theres some preload
  9. Tommy J.
    Tommy J. Karting
    Apr 7, 2016
    67
    Norway
    Is your repair still holding up? What kind of welding material did you use for the clutch shaft and gear?
    I need to do the same as you...
  10. fatbillybob
    Aug 10, 2002
    29,488
    socal
    Tommy,
    I'm the 1st person I believe to weld the lock ring to the shaft when there was shaft/gear damage. Often you see broken teeth means dead gear or not so great pitted gear and splines on clutch shaft pulled. People think the 355 box with the more spline shaft an upgrade but all it does is make up for not staking the ringnut properly. Use mig or fluxcore not tig. You also have to build the circumferential weld up in short bursts 180 degrees apart. This prevents warping. Tig just has a larger heat effected zone. Mig or flux you can get in and get out with minimal heat that can warp the shaft. A couple guys this failed on because they were tig welded. I suspect the tig welder did typicial tig process starting in 1 spot going 360 until he got back to that spot. That puts huge heat into the part and imo explains the warp. A warped shaft is a failure and does not work except to destroy more parts.
  11. Jh348
    Jh348 Karting
    Sep 5, 2015
    187
    Finland
    Jesse Heinola
    Yes, its still holding (currently 500 miles on it). I did tig weld it by 309 rod, altho as fbb said tig might not be the way to go. I did not weld it fully around, but almost. Also materials are not that nice to weld and loctite doesnt help the process when its drawn in to the puddle. Only time will tell how long it goes
  12. Tommy J.
    Tommy J. Karting
    Apr 7, 2016
    67
    Norway
    Thanks! I think I'll try to Mig weld it as FBB suggests. But I would like to fill up the splines with the loctite 660 as you did. I have ordered a used gear with (hopefully) 26 teeth and waiting for delivery.
  13. Jh348
    Jh348 Karting
    Sep 5, 2015
    187
    Finland
    Jesse Heinola
    Yes, you have just one problem doing it so, that those gears are grinded to matching pairs to ensure correct fit. Atleast in theory.
  14. Tommy J.
    Tommy J. Karting
    Apr 7, 2016
    67
    Norway
    Sh*t!!! I got the gear today and it has 27 teeth. Ordered from Eurospares... The guy said he had checked it himself that it was 26... And I suspect it's the gear for Pinion.. The inner diameter is a lot smaller too...
    Soon my only option is to find a way to repair my gear teeth ( don't know if someone even been that desperate before) or I'll have to made new shaft and gear... $$$$
