348 getting hot - again!!! | Page 2 | FerrariChat
Discussion in '348/355' started by angelis, Jul 2, 2006.
  1. PAP 348
    Dec 10, 2005
    100,244
    Mount Isa, Australia
    Pap
    So is the speedo needle!! :eek: Slow down there crazy fella!! :D
  2. VTChris
    VTChris F1 World Champ
    Aug 21, 2005
    13,259
    #27 VTChris, Jul 4, 2006
  3. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    Just had a chat with a friend who had the same problem in his 355.
    After having the rads re-cored, problem solved.
    Something about the fins.... can't remember exactly what he said though.
  4. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    It's possible your radiator fins are blocked with debris and the cores may be partially clogged.
    Get those radiators redone and then check your water pump!
  5. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    Hmmmmmmmmmm, that's a wierd one. The reason I say that is because the coolant flows away from the water pump. So I don't see how that could get stuck on top of the thermostat when the water flows away from it? The only thing I can guess that it is would be, an old clip from the top of a thermostat that was in the car from before. Some how it stayed in the sytem, and found its way back the the termostat. Either that or, something off of one of the coolant temp sensors, attached to the cross over pipe under the intake plenum?
