348 GTC Battery
Discussion in 'United Kingdom' started by anthony, Jan 11, 2004.
  1. anthony
    anthony Rookie
    Jan 11, 2004
    49
    Manchester UK
    Hi everybody, just found this forum today, marvellous.
    Question 1: Have owned 348 GTC since march last year, only use it about once a week, I have bought a solar powered trickle charger to try and keep the juice running in the battery, but I am still having to jump start if not used for more than 3 days. Does anybody else out there use any form of trickle charging on their car?
    Question 2: I think the battery needs replacing really, seeing as it is mounted under the N/S/Front headlight (right hand drive) what is the easiest way to get to battery and replace it?
    many thanks
    ps thread posted to technical questions also.
  3. 456mgt
    456mgt Formula Junior
    Mar 24, 2002
    628
    Cambridge UK
    Kevin
    It does sound like your battery is stuffed Anthony; either that or there is a drain somewhere. I've used trickle charging ever since one of the main dealers told me that >60% of their callouts are for flat batteries. The one I use is a CSI Airlow Model 5016-01 which plugs into the cigar lighter. It doesn't over-charge (the temptation to add something here is fierce) and is available from many places at £40-50.
    Have to admit I thought the 'solar powered trickle charger' priceless! So, in deepest winter, just when you need it most.... My brother and I have a competition to who can choose the most useless present, the current title held by a tie press. He lives in N. Wales so I reckon a solar powered anything would just about do it. Thank you.
    No idea sorry, though it does ring a bell. Wasn't there an article in the FOC magazine a few months back about replacing the battery in a 348 or a 355?
    Kevin
  4. tonyh
    tonyh F1 World Champ
    Dec 23, 2002
    14,372
    S W London
    Tony H
  5. gts328uk
    gts328uk Karting
    Nov 26, 2003
    122
    Yorkshire, UK
    Mark
    Anthony
    Yep sorry mate sounds as though the battery is shot.
    I use the airflow battery management charger its fantastic, battery is allways in top form. Try them on www.racecar.co.uk/airflow or call them on 01635 569569
    Mark
  6. anthony
    anthony Rookie
    Jan 11, 2004
    49
    Manchester UK
    "My brother and I have a competition to who can choose the most useless present, the current title held by a tie press. He lives in N. Wales so I reckon a solar powered anything would just about do it. "
    'fancy buying a solar powered trickle charger kevin?', make a lovely present for your brother!
    Thanks for your advice chaps, typical my car has to have the battery in the front and not in the engine compartment...........just to make it slightly more difficult!
    Regards Anthony
  8. Steve275
    Steve275 Formula Junior
    364
    Steve
    Hi Anthony,
    Not sure what battery you have fitted, But I suggest buying a Bosch Silver or Gold Standard battery, After many years of trial & failure these are the best I've found, I also use Oxford Battery Optimisers on my cars, bought for about £30 from Halfords.
    They come with a pair of crocodile clamps and permanent terminal clamps which connects to a push/pull connector you can leave in the front luggage space.
    PS - Welcome to the forum,
    Steve
