348 HAVAC problem. | Page 6 | FerrariChat
348 HAVAC problem.
Discussion in '348/355' started by Reddesire, Aug 28, 2016.
  1. cavalinojf
    cavalinojf Rookie
    Dec 14, 2008
    3
    Great, just sent you a PM. Thank you.
  2. solana_sc
    solana_sc Rookie
    29
    SC, USA
    Walt Oliver
    Just sent you a PM, Miro. Thank you!
  3. FloridaIsland348
    Aug 5, 2022
    118
    Pensacola Beach
    Scott Wheatley
    You are amazing! Thanks for the tips.
    The 348 AC ECU voltage is changing the speed indicator. Looks like the ECU is fine. I stabbed the wire from the far side and got an easy read.
    I must have fried my Fan Speed Controller. Any tips on repairing that piece? Otherwise I'll be digging.
  4. FloridaIsland348
    Aug 5, 2022
    118
    Pensacola Beach
    Scott Wheatley
    I got the speed controller apart thanks to you. I ordered the TIP142, and should try for the solder job this week. This thread was solid gold.
    If you are ever in the Pensacola area; I have a beach house rental you can stay at. I'm pretty sure I didn't fry a 8,400 AC ECU, so I'm feeling good.
    steved033 likes this.
  5. m.stojanovic
    m.stojanovic F1 Rookie
    3,331
    Serbia - Niš
    Miroljub Stojanovic
    Hopefully, replacing the two power transistors will fix it. However, the fact that your blower was running at full speed (presumably irrespective of the speed selection at the AC ECU) may mean that there is some damage on the small circuit board inside the controller. Based on the input voltage coming from the AC ECU, the small board will first vary the blower speed via the two power transistors in the range of zero to about 95%. When full blower speed is requested (~ 4.8 volts from the AC ECU), the small board will activate the relay inside the controller which will bridge (bypass) the power transistors and run the blower motor at full speed. If the small board is damaged (has developed some short), it may be switching the relay as soon as the AC/ignition is switched "on". I am not saying this is the case with your controller, just a possibility. Let us know the results after you have replaced the big transistors.
    FloridaIsland348 likes this.
  6. FloridaIsland348
    Aug 5, 2022
    118
    Pensacola Beach
    Scott Wheatley
    The blower will come on regardless of if the smaller 456 plug is in or out. When the plug is out, I also receive an error code 7. When the plug is in, the ECU lights up normally as if it has control over the speed of the fans. Yet the fans run constant. When I stabbed the violet number six wire I was able to get faring voltage from Low ones to about 5 V on full blast.
    I really appreciate you responding.
  7. m.stojanovic
    3,331
    Serbia - Niš
    Miroljub Stojanovic
    That shows the AC ECU provides correct speed signal. That is very good news. As for the blower speed controller, see if you can fix it. If not, you can always get one from me (converted controller from another car) if you cannot find a good replacement.
  8. FloridaIsland348
    Aug 5, 2022
    118
    Pensacola Beach
    Scott Wheatley
    I think you gave me the info I need to get it up and running, but I wouldn't mind have a back up. By now I think you are confident that your mods are better than the original designs. How can I get my hands on one?
  9. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,564
    Atlanta, GA
    Steve D.
    I've got one of Miro's controllers...it's been faultless for several years now.
    Qavion and FloridaIsland348 like this.
  10. m.stojanovic
    3,331
    Serbia - Niš
    Miroljub Stojanovic
    Sent you a PM.
  11. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    496
    Victoria, B.C, Can.
    John Glen Wesanko
    Where is the major grounding point for all this blower current ? Are these the same grounding cluster behind the drivers dash vent ? Thanks to all.
  12. Qavion
    Qavion F1 World Champ
    14,675
    Ian Riddell
    I believe it's in the cabin. It's component "100" in the wiring diagrams and there are a lot of things attached to it, including the doorlock module and components on the passenger footwell relay panel, so perhaps one of the spade connectors on the main earthing point behind the relay panel.
    The earth wire for the controller is spliced into an earth wire for the coil of the blower fan relay (pin 85, I believe)
    Check continuity to ground from pin 85. If none, check earth 100.
    There is also an inline 2-pin plug for the earth somewhere (maybe near the firewall... or should I say cabin bulkhead?), but this also carries live battery power from the battery to the 30 amp fuse, so the plug should be connected).
  13. John Glen
    Dec 30, 2009
    496
    Victoria, B.C, Can.
    John Glen Wesanko
    What would be the solution if the HVAC control puts out a steady 6.1 vdc at the violet wire to the fan control module ? This is my situation, as the bar graph digital display works with the buttons but the output of the control voltage does not vary up and down. I assume this causes the relay in the fan control module to close keeping the fan on full speed. Is there a component in the HVAC control that can be replaced ? Thanks, J Glen Wesanko
  14. Qavion
    14,675
    Ian Riddell
    Most likely the fan (speed) control module itself. The module sends a temperature signal to the HVAC ECU on the violet/white wire and the HVAC ECU responds with a fan speed signal (voltage) on the violet wire.
  15. John Glen
    Dec 30, 2009
    496
    Victoria, B.C, Can.
    John Glen Wesanko
    Thanks for your response Ian. Thing is I have already replaced the module with a New one from Miroljub. I'm thinking there is a component in the hvac ecu that is not adjusting the 0- 5 vdc signal even though the green bar graph display is indicating properly ?
    Qavion likes this.
  16. Qavion
    14,675
    Ian Riddell
    Ah.. that was quick.
    I can't say I've seen any photos of the internals of the ECU on a 348. Have you rechecked the fault codes?
  17. John Glen
    Dec 30, 2009
    496
    Victoria, B.C, Can.
    John Glen Wesanko
    I often get a an E7 code. Just a note: sometimes the fan control would start working temporarily with a slap to the side of the console. This is why I think there is a problem on one of the "boards" in the hvac ecu. Is there a pwr transistor that operates this 0-5 vdc inthe ecu that can be replaced ?
  18. Qavion
    14,675
    Ian Riddell
    HVAC plug issues are well known. The looms are sometimes tight and pull on the connector. Perhaps resoldering the connector pins where they go into the circuit board would help. These cars are starting to develop microscopic cracks in the solder at vibration points.
  19. m.stojanovic
    3,331
    Serbia - Niš
    Miroljub Stojanovic
    #144 m.stojanovic, Apr 29, 2024
    The 0-5V signal comes from a digital potentiometer inside the AC ECU based on the presses of the push-buttons. A digital potentiometer looks like a small micro-chip (picture below) but, in the case of the 348 AC ECU, it is integrated within one of the larger chips so it is not separately replaceable. Perhaps you can try cleaning the multi-pin connectors inside the AC ECU. Info on this I found on the internet is attached.
    Otherwise, my fan speed controller will default to 50% fan speed if the 0-5V signal coming from the AC ECU is lost/disconnected.
  20. John Glen
    Dec 30, 2009
    496
    Victoria, B.C, Can.
    John Glen Wesanko
    Thanks Miroljub, I think this is my problem. I have had the ecu apart a few times and inspected and cleaned all pins etc. Is there somewhere I could send the ecu to have the component specific replaced ? Could it maybe be a cold solder joint where this digital potentiometer is attached to the board ? Any advice would be appreciated as i've been chasing this issue for years.........
  21. FloridaIsland348
    Aug 5, 2022
    118
    Pensacola Beach
    Scott Wheatley
    The fan speed controller you built works great!
    Thank you so much for making one for me.
    My Ferrari is back from the dead and now fully operational again.
    solana_sc, carnutdallas and Qavion like this.
  22. solana_sc
    solana_sc Rookie
    29
    SC, USA
    Walt Oliver
    Miroljub, thanks very much for the fan-speed controller you made and sent!
    In the US Deep South, it's wonderful to have working A/C again!
