News
348 Headight Motor
Discussion in 'Technical Q&A' started by kenyon, Apr 2, 2005.
  1. kenyon
    kenyon F1 Rookie
    Oct 7, 2002
    2,836
    East Yorkshire
    Justin Kenyon
    Guys,
    My headlight pod raises as normal when you switch the lights on. When I switch them off LHD side lheadight pod does not drop close. I have to close the headlight pod by turning the screw on top of the motor. Seem to have motor malfunction. It all starting after jet washing the front of the car.
    Any ideas to how to access the motor of the headlight pod. Can just get my hand in between the fender and pod ..... I think I might have some water in the electrics.....
  2. ernie
    ernie Two Time F1 World Champ
    Owner Lifetime Rossa
    Nov 19, 2001
    22,015
    The Brickyard
    The Bad Guy
    You have to get the front of the car off the ground. Then remove the cover the goes from the bottom of the bumper to the wheel well splash guard. After you have that off you will be able to see the connections going the the lights and head light motor. I sounds like something just got wet in the connections.
