348 Help Needed | Page 2 | FerrariChat
348 Help Needed
Discussion in '348/355' started by Majin_JT, Feb 22, 2011.
  1. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Yikes...
  2. Majin_JT
    Majin_JT Formula Junior
    Mar 15, 2008
    395
    JT
    #27 Majin_JT, Mar 20, 2011
    hello everyone update first of all id like to thank MADDOG for sorting my beautiful radiator out please find pic attached :) also i have flushed all my system added the correct coolant etc but i noticed this morning i had a very small im talkin small patch of water or coolant now could this have come from my over flow pipe or do you maybe think i have a tiny leak on the pipes i put back onto the radiator ? eg the clips arnt on tight enough ? its not the tank cap as i have replaced this with a new 1 any ideas would be great car is running beautiful temp etc
    john
  3. PAP 348
    Dec 10, 2005
    100,245
    Mount Isa, Australia
    Pap
    If its from the header tank/cap, it will be more towards to the rear of the car. :D:D
    If its from the radiator you just fitted, well..................you know where that is. :D:D
    If its from the radiator area, then I would recheck those hose clamps dude. :):)
    Where is the leak abouts mate? :):)
  4. Majin_JT
    Mar 15, 2008
    395
    JT
    the leak is right at the back dude ya reckon it cud just be loose pipe etc
  5. PAP 348
    Dec 10, 2005
    100,245
    Pap
    Right at the back???
    You mean towards the rear of the car?? There is not much there my friend.
    But, coolant (like oil) has a habit of leaking elsewhere, running down something else and dripping on the ground nowhere near where the leak is. :D:D
    Sounds like you need to keep investigating. Perhaps borrow/buy a coolant pressure tester. Pressurize the cooling system and look for a leak. :D:D
