348 Hot Start Issue: I Have Tried Everything! | Page 3 | FerrariChat
Discussion in '348/355' started by POLO35, Feb 2, 2025.
  1. Qavion
    Qavion F1 World Champ
    14,663
    Ian Riddell
    I used to have issues on one of my cars (not Ferrari) with old vacuum hoses in the engine V getting soft when the engine was hot. They collapsed. How close are 348 fuel regulator vacuum hoses to heat sources?
  2. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    794
    Treasure Coast Florida
    MATT
    Yes sir I hear what you're saying I had an old mg that had that problem. The pressure regulator hoses are very far from Heat and in perfect condition. Unfortunately my problem has gone from bad to worse it's it's gone from a hot start problem to a 95% of the time NO start! Just backfiring and popping. It is crazy. I'm really scratching my head but I'm going to keep trying different things. Im going to start completely over and go through everything....compression test spark test fuel flow and pressure test check all electrical connections etc.....I've got to be overlooking something
  3. m.stojanovic
    m.stojanovic F1 Rookie
    3,326
    Serbia - Niš
    Miroljub Stojanovic
    After switch off, the fuel pressure is held by the pump check valve at one end and by the FPR at the other so fault in any of the two can cause rapid fuel pressure drop. I remember you earlier mentioned that one of your new (PR298) FPRs was leaking fuel into the vacuum line. You did not comment further but I believe you replaced it with a good one. This issue, coming with a new FPR, suggests that the Standard FPRs are not really great quality.
  4. POLO35
    Feb 21, 2005
    794
    MATT
    Very astute of you to recognize that. Yes one of my original fprs was Dripping fuel out of the vacuum line the new ones are working perfectly. The problem by process of elimination must be the check valve on the fuel pump end because it loses pressure immediately after turning the engine off but as soon as you start the car it immediately shoots back up to 55 and I mean immediately and holds teady while it's running. Not sure if this is of any consequence or related to my problem
  5. Acguy
    Acguy Karting
    Sep 21, 2024
    63
    Eric Christian
    I got a 94 spider , with hot start problem. I got fuel pressure regulators coming Tuesday.
  6. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    970
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
  7. POLO35
    Feb 21, 2005
    794
    MATT
    #57 POLO35, Feb 10, 2025
    Those are sweet looking regulators! I might look into some of those next time around. First off thanks to everyone who has stuck with me on this lame thread it has been an odyssey and I have finally absolutely positively narrowed the "problem" down. Basically the passenger side timing is off and I can't quite wrap my head around what's going on. If I unplug the passenger side crankshaft position sensor while running there's just the car continues running as before but if I unplug the driver side crankshaft position sensor the car immediately dies. This tells me that it is absolutely, positively, a timing issue. My heart sank because I can't at this point rule out the possibility that maybe the timing belt skipped a tooth or two at some point while backfiring anything is possible. I have tried swapping stock crankshaft position sensors. I've also meticulously adjusted the tolerance and I've also tried the brand new aftermarket Kia sensors it does the same thing every time...perfect on the driver side timing off on the passenger side. And again just to reiterate fuel pressure is great on both sides I removed both injector rails and tested with clear water bottles and they all have nice spray pattern with no leakage at all whatsoever. Also I have verified there is solid spark on all four cylinders. Again it is positively a timing issue. And just on principle I swapped ecu's from driver to passenger with no change that hopefully tells me there's nothing wrong with the ECU. The only thing I can think of is I did put my OEM crankshaft position sensor back on. I had the aftermarket Volvo one on and as a matter of fact I could tell the rotor was actually ever so slightly rubbing the plastic! So I can't rule out that both my oem and the kia sensor could be bad as well. Is there a way to test/ohm them? I may bite the bullet and just go ahead and buy a new OEM cam sensor on principal it is about the only thing left to do. Any suggestions would be greatly appreciated
  8. Portofino
    Sep 17, 2011
    970
    Portofino
    From an earlier post -
    “bought an infrared gun and my driver side cat flange is running around 270 deg and the passenger side cats are only 170 deg! I believe this is evidence that there is an ignition problem on the passenger side”
    From post #57 above
    “If I unplug the passenger side crankshaft position sensor while running there's just the car continues running as before but if I unplug the driver side crankshaft position sensor the car immediately dies.”
    Me - these contradict , but happy to stand corrected . ???
    Cooler should be the faulty side ?
  9. POLO35
    Feb 21, 2005
    794
    MATT
    I could see where it would be confusing but what I mean is, while running, If I unplug the passenger side CPS there's no change to the engine running meaning it's NOTVfiring on those four cylinders but when I unplug the driver side it completely dies...meaning those four cylinders ARE actually running? And you are correct the cooler should be the faulty side it's not firing on all four
  10. m.stojanovic
    3,326
    Serbia - Niš
    Miroljub Stojanovic
    Did you try swapping the ignition coils left-right?
  11. m.stojanovic
    3,326
    Serbia - Niš
    Miroljub Stojanovic
    I believe you mean "camshaft position sensor" here.
    It doesn't really seem that you have any issue with ignition timing. The ignition timing is controlled by the: 1. Engine ECUs (no problem there, you swapped them); 2. Crankshaft Sensors (no problem there, you swapped/renewed them); 3. Camshaft Sensor (would cause problem on both banks, not only one); 4. TPS (did you try swapping them?).
    Timing belt skipping is theoretically a possibility but it would affect both, cold and hot starting. And to affect the combustion so much it would have to be a skip of a few teeth which would cause bent valves before the kind of misfire you are having.
    You mentioned that you have a solid spark on all four cylinders (of the offending side, I presume). When an ignition coil is on the way out, it will usually still produce a visible spark but you may not be able to tell how strong that spark is. Partially faulty ignition coil will produce sparks of reduced intensity which may not be able to ignite the mixture efficiently so there will be many "misses". And it usually gets worse as the coil heats up. The problem diagnosing this is because it is difficult to distinguish between bad fuelling and bad (poor) spark.
    I once spent months chasing a reason for engine misfiring and dying when it heats up (after a few kilometres of driving) and be impossible to re-start until it cooled down. All the time, I was blaming the carburettor, cleaning and readjusting it many times, to finally find out it was the ignition coil.
  12. POLO35
    Feb 21, 2005
    794
    MATT
    Thank you for the replies! First off yes you are correct I meant to say that I put the OEM camshaft position sensor back on because the aftermarket Volvo one made no difference with the problem and upon inspection I could see where it was slightly rubbing the plastic on the inside! Yes sir I swapped the ignition coils and it made no difference then I swapped them back and then I actually replaced Pass. side with a brand new Bosch coil. No difference at all whatsoever. Right now have a new camshaft sensor on order as well as a new three prong plug which I will fit once I receive.
  13. Robbe
    Robbe Formula Junior
    622
    The Netherlands
    The fact that the situation is slowly getting worse, is indicating a problem that is intensifying. As you replaced a lot of sensors already, with no effect, would indicate that the main problem is not in sensors or coils. It most likely is in a part/situation that is deteriorating. Hopefuly increasing resistance in a wire or connection. Unfortunately, if it is in the timing belt, it would mean that from 1 tooth it now has skipped another one. If that is the case, chances are that with the violent backfires it can skip another one , and then you are in the danger zone. 3 strikes/teeth and you're out...
    I would not try to start it again, but do a new compression test first. All plugs out , should be less stress on the engine turning.
    if there is a noticable difference in the pressure on both sides (or compared with earlier tests), you have an indication. Do not use 10 rounds or so, but just 4 and see if there is a difference.
    As with 10 rounds of starting, the pressure gauge will in the end show a rather normal pressure even with 2 teeth skipped. What indicates is the speed in which it gets to a max pressure. With 4 a normal timed engine should already be near max.
    That said, I am also just an amateur, if professionals see this differently, please react.
    Other indication is the voltage of the O2 sensors (or short term fuel trims), but for that the engine needs to be running, which I would not dare anymore at this point.
    Qavion likes this.
  14. m.stojanovic
    3,326
    Serbia - Niš
    Miroljub Stojanovic
    Just one tooth out can show significant difference between the banks. My engine was running well and had quite smooth idle but, when I decided to just check the compression, I was surprised to get the following readings (13,000 miles engine at the time, I did about 10 rounds on each cylinder or until the gauge needle stopped jumping any further):
    Left bank: .......200 psi (all cylinders exactly the same)
    Right Bank:.....240 psi (just one cylinder read 239 psi)
    I then checked the cam timing and found out that the left intake cam was 1 tooth out (late). The belt was still in excellent condition and tension so I concluded that the left intake cam sprocket was, most likely, engaged incorrectly during the previous belt service. Anyhow, after I timed everything correctly with a new belt, I had the compression readings 240 psi (+/- 1 psi) on all cylinders.
    Perhaps I had such a significant compression difference for just 1 tooth out because it was on the intake cam. In the case of one exhaust cam being out by 1 tooth, perhaps the compression difference would not be so grate.
    In any case, doing a compression test is a good (and quick) method to check for any compression difference left to right which would point out to incorrect cam timing but only if the readings show similar values across the 4 cylinders of each bank but a consistent difference left to right.
  15. POLO35
    Feb 21, 2005
    794
    MATT
    I appreciate the information and advice and I completely agree with you! As a matter of fact I am waiting on a new cam sensor and in the interim I'm going to do a visual inspection of the timing belts and check the timing visually from up top by removing the belt covers and using that method of looking through the inspection slits of those covers for the timing marks. just to get the assurance that nothing has skipped. I will definitely report back I hopefully will do that today.
  16. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,955
    Richmond
    Pete
    Really sounds like a bad wire somewhere that's getting worse as things get plugged in/unplugged.
  17. POLO35
    Feb 21, 2005
    794
    MATT
    Well I have unbelievable news but good news. The timing is perfect absolutely perfect spot on! I used Stojanovic's method although I could not see the timing marks through the slits on the top covers I wound up removing the covers rotating the crankshaft around by hand until TDC and like magic all four cams matched absolutely perfectly thank goodness. Side note: I really struggled on how to rotate this engine I didn't want to just keep bumping the starter.... I did try to go from underneath the clutch pumpkin access cover using the flywheel with no luck. I finally wound up taking a large crescent wrench heating it up Cherry Bomb red and bending just the head about 25° and I was able to put it right on the crankshaft pully nut and turn it. It worked perfectly. Now I'm going to reassemble everything and wait for my new camshaft position sensor which hopefully will be tomorrow or Friday and I will report back. I am consistently getting the code 4112 "stroke sensor" pretty much every time I run it and then clear the codes and rerun it so I'm very hopeful that that is going to be the problem. The odd thing is the stroke sensor code sometimes is on bank 1-4 which is definitely the offending flooding side and sometimes it's on the bank 5-8 which is strange but I'm still hopeful that this will be the problem.
    Robbe and Qavion like this.
  18. GeorgW
    GeorgW Karting
    Jan 31, 2004
    103
    Germany
    Georg
    Have you already ruled-out or disconnected the Cat-ECUs ?
  19. Qavion
    14,663
    Ian Riddell
    Do you have two cam sensors or one?
  20. POLO35
    Feb 21, 2005
    794
    MATT
    I haven't had any cat ECU issues yet. But I suppose it certainly couldn't hurt to just unplug them to rule those out. As far as the cam sensor only the one side passenger side Bank 1-4. So stoked to get the sensor and get it installed and test...will definitely report back.
  21. Qavion
    14,663
    Ian Riddell
    If it were to only affect one bank, the pink wire pigtails on the car side of the connector would have to be faulty.
  22. m.stojanovic
    3,326
    Serbia - Niš
    Miroljub Stojanovic
    I think this is normal because the Cam Sensor signal goes to both engine ECUs and they probably talk: "I displayed 4112 last time, now is your turn". If, however, the code was consistently displayed by only one ECU, that would point to a possibility of a wiring fault as mentioned by Ian above.
    In any case, it is a good idea to have a good look at the loom side of the Cam Sensor connector, especially the crimping of the pink wires to their pin and the condition of the pin itself. Here's what this connector looked like on my 348 when I bought it:
    Qavion likes this.
  23. Robbe
    622
    The Netherlands
    Good to hear the timing is still ok! No direct risk in harming the engine by testing it further I think.
    If you have some spare time, a compression test is still a good idea to see if there is a problem with the valves.
    Possible overheating of the combustion chambers could have affected the valves. Very, very small chance, but with all things done so far, it must be something that is considered a small chance. Even though I hope it is that cam sensor plug. (tried wiggling it with the engine running/starting?)
  24. POLO35
    Feb 21, 2005
    794
    MATT
    Good to know regarding the cam sensor fault code. Really crossing my fingers that this is been my problem all along. I should have known better than to try to fit that cheap Volvo sensor I had to put it in using tiny tiny nuts and it ever so slightly rubbed while the engine was running and really screwed up the sensor as well. Metal filings sticking to the sensor. I can't imagine how others have fitted it without a problem. I will definitely check my plug harness. When this whole nightmare started while the engine was running I would unplug the cam sensor and then plug it back in while the engine was running and there was never any change at all. Even with the OEM sensor. And yes absolutely I'm going to do a compression test today on all 8. Well report back.
  25. m.stojanovic
    3,326
    Serbia - Niš
    Miroljub Stojanovic
    I presume that there was no such rubbing on the original Cam Sensor but, if there was, maybe you should check whether you have both locating dowels for the sensor housing. The picture below shows the locations of these dowels on the cylinder head (the pic below shows only one but there should be two where the red lines are pointing). Note: If you decide to remove the sensor housing for inspection (if you see rubbing marks on the original sensor), be very careful when re-attaching it in order not to fold back the seal lip (second pic).
