348 idle issue and questions | FerrariChat
Discussion in '348/355' started by Dino L, Nov 10, 2018.
Tags:
  1. Dino L
    Dino L Rookie
    Oct 29, 2018
    35
    sacramento, ca
    William D Lozano
    Recently my 89TS has been staying at a high idle.1200 +/- and occasionally it seems to be searching for idle once it is warmed up. It jumps back and forth 800/1200 rpm then will eventually settle back at 1200 which I know is too high. I suspect there must be a sensor to know it has come to temp and should drop the idle and I am suspecting this is also the cause of the idle searching ? Temp is about 195 and fans do come on. Thanks in advance.
  2. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Any recent work in the engine bay?
    Dino L likes this.
  3. Dino L
    Dino L Rookie
    Oct 29, 2018
    35
    sacramento, ca
    William D Lozano
    Most recently a coolant flush and coolant hoses replaced. Before that, and possibly when idle issue was first noticed, a coil pack and cat temp sensor.
  4. Cauf61
    Cauf61 Formula Junior
    Jul 12, 2016
    557
    Belgium
    Patrick
    Did you perform a search for air intake leaks. Easy with brake cleaner. Just spray a bit on all tubes/lines and engine will react very fast when a leak is found.
    Attention for fire with brake cleaner on hot parts ( exhaust ) !!
    Keep extinguisher at hand.
    Dino L and Pangea like this.
  5. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    1) Your throttle bodies need cleaning.
    Dirty build up inside the throttle can cause the plate to get stuck against the inner wall. So make sure your throttle bodies are cleaned out properly.
    2) Your throttle stops are not adjusted properly.
    If one of your throttle bodies hits the stop before the other it can cause one of the throttles to say open just enough for it to idle higher than normal. Check to make sure that both throttle bodies are
    3) The throttle linkage is not even
    Same as above. If the linkage is not opening and closing the throttles in sync you can have one throttle saying open more than the other. So make sure that the throttle are opening and closing as synchronous as possible.
    4) You throttles are not balanced.
    To balance the throttles it is best to use a manometer. Look up on YouTube how to make one for a few bucks.
    5) Dirty idle air control valves.
    If you idle air control valves are dirty they can get stuck and not fully close. So clean them out. Look in the 348 DIY sticky on how to clean the IACV.
    6) The "secret cruise control".
    Basically make sure that your floor mat is not bunched up against the gas peddle. It has been know to happen. Also make sure that there isn't any debris under the gas peddle stop causing it to stay open a hair.
    7) Motronic ecu reset.
    Every once in a while it's a good idea to disconnect the battery and let the ECUs relearn the warm up parameters. What happens is the Moronic ECUs use the resistance of the throttle position sensors to determine where the throttles are (but in your case the throttle as the '89s 2.5 Motronic only has 1 tps), and then it uses that info to adjust the fuel mixture and the idle parameters. To reset them, disconnect the battery for 30 seconds, reconnect the battery, make sure ALL accessories are turned OFF, start the car, let it idle for 15-20 minutes or until the radiator fans kick on, then take it for a 30 minute drive.
    Try those and get back to use. We like updates. ;)
  6. Qavion
    Qavion F1 World Champ
    11,563
    Ian Riddell
    That's a bit harsh calling them moronic, isn't it, Ernie? :p
    Dino L and ernie like this.
  7. Dino L
    Dino L Rookie
    Oct 29, 2018
    35
    sacramento, ca
    William D Lozano
    Thank you I will give this a look on the weekend
    ernie likes this.
  8. Dino L
    Dino L Rookie
    Oct 29, 2018
    35
    sacramento, ca
    William D Lozano
    Thank you for all this very good information.Some of this I can handle myself and if those don't resolve I will take it in to the expert.
  9. Dino L
    Dino L Rookie
    Oct 29, 2018
    35
    sacramento, ca
    William D Lozano
  10. Dino L
    Dino L Rookie
    Oct 29, 2018
    35
    sacramento, ca
    William D Lozano
    Thank you I will give this a try on the weekend.
  11. Dino L
    Dino L Rookie
    Oct 29, 2018
    35
    sacramento, ca
    William D Lozano
  12. Dino L
    Dino L Rookie
    Oct 29, 2018
    35
    sacramento, ca
    William D Lozano
    Thank you I for all the great info. I will be spending some time on this over the weekend and hopefully be able to post a resolution.
    ernie likes this.
  13. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    LOL!
    Gotta love auto spell check.
    Well they are a bit "moronic". The Motronic ecu may have gotten the job done in the late '80s early '90s but they are not up to snuff for modern day requirements. Trying to run the Motronic today for performance modifications would be like trying to still use a Commodore64 to run Windows 10 = moronic. :p :D
    Wade likes this.
  14. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    Be sure to look in the 348 DIY sticky for how-to's, and search the archives. Practically everything I posted has already been discussed.
    Dino L likes this.
  15. Koenig1
    Koenig1 Formula Junior
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
    I'll add one more possibility. I purchased mine with a high idle, spent a couple of months looking for a leaky hose, throttle adjustments, pedal, etc. Finally I left it as I knew I needed to do an engine out, and would be much easier to diagnose. The killer was the left intake cam had jumped a tooth! Anyway, when the engine went back in, it idled at 1k rpm. The PO probably knew this but..., welcome to private sales! Hope this is not the case for you. My car's PO was not very honest regarding a number of issues... but probably typical of his demeanor. My gut said no, my heart won out!
    Dino L likes this.
  16. Dino L
    Dino L Rookie
    Oct 29, 2018
    35
    sacramento, ca
    William D Lozano
  17. Dino L
    Dino L Rookie
    Oct 29, 2018
    35
    sacramento, ca
    William D Lozano
    Thanks... I am hoping it is not that serious, but always a possibility. I had the engine out major completed about 4 years ago, and I am planning for it again this spring. Like you, my first engine out came with a few surprises, but I feel good that they were found and resolved.
  18. Dino L
    Dino L Rookie
    Oct 29, 2018
    35
    sacramento, ca
    William D Lozano
    Idle issue appears to be finally resolved after several items addressed. Connections at MAS were carefully cleaned and inspected. New (used) CAT's installed. Ran a tank of Hi octane race fuel thru it. I have now been thru 4 tanks of fuel and numerous outings with the car and not a sputter. Idle goes right to about 1100 each and every time off the gas.
    ernie and Qavion like this.
  19. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    Your idle is still a hair high, it should settle down to around 950. You may need to adjust the throttle stops and/or adjust the idle bypass screws.
    Dino L likes this.
