348 Judder under load | Page 2 | FerrariChat
Discussion in '348/355' started by Haydar, Sep 12, 2018.
  1. Koenig1
    Koenig1 Formula Junior
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
    I believe from reading on here, that if you need to replace crank sensors, they can be had from KIA, at under $20. Do a search for the part number.
  2. A348W
    A348W Formula 3
    Jun 28, 2017
    1,843
    North Wiltshire, UK
    Yes they can. £40 in the Uk from Kia. Did mine earlier this year. Just remember to measure the gaps are in tolerance.
    Part number is on here in the sticky for replacement parts. Also Volvo and a few others.
  3. Pangea
    Pangea Formula Junior
    Mar 27, 2011
    442
    Nick
    Any further forward with your problem?
  4. Haydar
    Haydar Rookie
    May 26, 2016
    29
    Pakistan
    No real progress with my problem. Have balanced both throttle bodies and clean up the crank sensor but still have the problem. As a side note I put a 5 gas analyzer on both banks and got very different results. I'll start a new thread as this may be a completely different issue.
  5. Surfari
    Surfari Karting
    Nov 4, 2016
    149
    Redondo Beach
    Luke
    How did you clean up the crank sensors? This really does sound like what my car was doing before I swapped the sensors. When I tried to pull them, the plugs just crumbled in my hands.
    Did you ever look into the coil packs? I would still suspect this is a weird intermittent ignition issue. If the clutch or other drive-line component was fubarred, I would assume it would be slipping under high load conditions, which it seems not to be.
  6. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    omg i have the same problem with my 89 348 but know its ignition im thinking injectors or wires im ordering new referb ones and will report back
