Has anyone tried the Jaguar 10.0511-9023.1 ABS pump? It seems very similar to Ferrari's 10.0511-9020.1. Top pic is 90-94 XJ6 Jag bottom is 348. Image Unavailable, Please Login Image Unavailable, Please Login
It will certainly work. The only difference could be in the pressure switches, i.e. their low (on) and high (off) points but you can always swap them. Then again, even the pressure switch settings could be the same. Here is the info from the 348 and Jag manuals on the switch on-off settings: 348 On: 140 bar (2031 psi) ; Off: 180 bar (2611 psi) Jag On: 128.5 149 bar (1863 2161 psi) ; Off: 171 195 bar (2480 2828 psi)
Following up on an old thread. I saw this listed on ebay. Can anyone confirm that these are the correct seals to rebuild the 348 Brake MC?
If you look at the 348 parts diagrams, you will see that it is actually not the 70000510 "Ferrari O-Ring Kit". The seller states that the kit is also for "F355 ABS BOSCH" (and the 348 uses Teves MC/ABS). Ask the seller to clarify what exactly they are selling.
Ah yes, I see what you are saying. These are the o-rings/rubber bits to link the components together. I'm looking for a kit to rebuild the MC. I've asked the seller to clarify but I highly doubt that this is what I need.
The seller responded claiming that this kit does NOT appear on any parts diagrams. They did not answer my question if this is the kit is for the internals of the MC. They offered to take it back if it's not correct to my needs (seriously?). The ebay listing shows 9 components. I'm speculating that it aligns with the "M" components that I highlighted (although I only found 8). The two larger items look very much like the grommets that connect the reservoir to the MC... Do the experts agree or am I missing something? Image Unavailable, Please Login
I think you are quite right. Earlier, I did not see (looking at the Eurospares diagrams) that the 70000510 Ferrari O-Ring Kit, in addition to items under #5, also covers all "M" items. So, the kit 70000510 provides all external seals and o-rings and nothing that is inside the MC/ABS unit. Currently, no internal seals/o-rings kit is available. Perhaps somebody will make one in the future.
If you're curious. This is how it looks on the inside. Image Unavailable, Please Login Image Unavailable, Please Login
I am curious, thanks. By the way, I am now selling all the MC parts that I showed in this thread (and some clutch MC parts) - Ferrari 348 355 Brake Master Cylinder Parts Teves | eBay.
