Buy
348 Motronic 2.7 connector/harness repin
Discussion in 'Technical Q&A' started by ernie, Apr 14, 2014.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,084
    The Brickyard
    The Bad Guy
    That is not necessary at all, and I don't recommend doing it.
  3. ernie
    Nov 19, 2001
    22,084
    The Brickyard
    The Bad Guy
    For the t55 connector, or the connector for one of the sensors?
    The green tool I used (pictured in my first post) is for the connectors for the sensors. The red tool is for the T55 connector.
    You may even wanna try talking dirty to it. :p hehehe
  4. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Being involved with this kind of thing...
    The reason would be simply that Bosch specified those pins.
    Your discovery that the power pins fit this connector is great. Usually the power pins are designed for heavier gauge wire though, but you dont appear to have had any issue with the wires being too thin.
    Great job!
  5. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Crimp-and-solder is used on high-end harnesses such as aerospace and F1 cars etc. But its overkill here assuming the crimps are properly done.
  6. ernie
    Nov 19, 2001
    22,084
    The Brickyard
    The Bad Guy
    If I'm remembering correct the jpt pins I bought from EFI were good for 20awg-16awg wire. A good percentage of the wires are 20awg, easily over half of them. Anyway, the pins worked just fine.
    The trickiest of all of them were the pins that had the wires doubled up. Thankfully I only had to mess with a couple of those. The key was to hold both wires in the crimper, so that one wire got crimped under each of the clamps. Those were the wires that took me about 15 minutes to do. It is a SUPER TEDIOUS and time consuming job, doing all the pins one by one.
  8. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,249
    SoCal LA/OC
    Tim Dee
    I ordered some of the new pins, huge difference in clamping force. Going to install them during my service. Thank you
    BTW Ernie. I am now oldest belt driving LOL
    ernie likes this.
  9. ernie
    Nov 19, 2001
    22,084
    The Brickyard
    The Bad Guy
    #57 ernie, Apr 20, 2014
    Is yours the 2.7 or 5.2?
    Mitchell was telling me that the 5.2 has the double tab pins, and they ARE a pain to get out, even with the locking clip unlocked on the T88 connector. Just a heads up.
  10. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,249
    SoCal LA/OC
    Tim Dee
    5.2. I'll tread lightly, I use homemade tools to get them out hate those little ring pushers :)
    If not I have 100 for somebody else who may need them
  11. ernie
    Nov 19, 2001
    22,084
    The Brickyard
    The Bad Guy
    A good trick I used to get the JPT double tabbed pins out is to, push the extraction tool all the way in, you want to make sure the tips of the extraction tool are butted up against the back of the clip. Then push the pin FURTHER into the receptacle. That way the locking tabs in the pin are sure to be compressed by the tool. Wiggle/jiggle the wire as you pull it out. I really didn't need to pull on the wire hard to get the JPT pins out of the regular connectors. Hopefully you don't run into the trouble Mitchell had getting the pins out of the T88.
  13. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    10,797
    San Carlos, CA
    Mitchell Le
    I was able to practice on an old connector and became much better getting the newish pins out. Still not easy, but I got them out using an unofficial tool. In the process, I even learned how to disassemble the connector into its 3 pieces.
  14. ernie
    Nov 19, 2001
    22,084
    The Brickyard
    The Bad Guy
    WELL SPILL THE BEANS MAN!!!
    Where the pics??????
  15. yelcab
    Nov 29, 2001
    10,797
    San Carlos, CA
    Mitchell Le
    #62 yelcab, Apr 22, 2014
    So you start with a small pick at one corner of the connector, and pry the ear of the top piece up, move it slightly back to create a gap along the connector.
  16. yelcab
    Nov 29, 2001
    10,797
    San Carlos, CA
    Mitchell Le
    #63 yelcab, Apr 22, 2014
    Then use a bigger screw driver, insert into the gap to keep it from collapsing, use the small pick on the other corner of the connector.
  17. yelcab
    Nov 29, 2001
    10,797
    San Carlos, CA
    Mitchell Le
    #64 yelcab, Apr 22, 2014
    ernie likes this.
  18. yelcab
    Nov 29, 2001
    10,797
    San Carlos, CA
    Mitchell Le
    It would be hard to separate the connector housing into 3 pieces with all the wires in place, and it probably does not make removing the pins any easier. But, it does help to understand how the pins are retained in the housing and not be so much of a mystery.
  19. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,249
    SoCal LA/OC
    Tim Dee
    Its all here
  20. ernie
    Nov 19, 2001
    22,084
    The Brickyard
    The Bad Guy
    Right on Mitch!
  21. flyingboa
    flyingboa Formula 3
    Nov 27, 2003
    1,555
    Italy/India
    Eugenio
    Ernie,
    Thank you for the lesson! Great as usual.
    Due to my usual inexperience, a silly question.
    Did you have any malfunction that led you to perform this activity? If yes, was it sorted?
    Ciao
    Eugenio
  22. ernie
    Nov 19, 2001
    22,084
    The Brickyard
    The Bad Guy
    #69 ernie, Apr 23, 2014
    No major malfunction per say. Just that the car would have little intermittent glitches. For example, at initial start up the car would exhibit small misfires. You could hear the exhaust popping, but then later it wouldn't do it. Or I would get a lambda regulation check engine code, yet the coolant temperature sensors, mass air flow sensors, and O2 sensors were all fine. Even the crank sensors where new. It wouldn't be all the time but every so often, it would act weird. Like you knew something just wasn't right, but you couldn't quite put your finger on it.
    After having seen how worn out the old pins were the strange behavior made sense. The ecu can't run the engine properly if is isn't getting a full signal, nor if it isn't sending a full signal. The bad pins in the T55 were for sure a root cause if intermittent, and erratic problems.
  23. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,249
    SoCal LA/OC
    Tim Dee
    #70 SoCal1, Apr 24, 2014
  24. yelcab
    Nov 29, 2001
    10,797
    San Carlos, CA
    Mitchell Le
    Tim
    start with this part number 928939-1
    ernie likes this.
  25. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,249
    SoCal LA/OC
    Tim Dee
    Thank you :)
  26. Triple Black
    Triple Black Karting
    Feb 8, 2014
    217
    Millington TN
    David S
    Is this a problem with all 348's or only early ones? Were you having electrical issues, or is this a problem due to engine out service wear and tear from disconnecting the controllers?
    Thanks for the great explanation and detail.
  27. ernie
    Nov 19, 2001
    22,084
    The Brickyard
    The Bad Guy
    In my opinion it's a problem will all 348s. The issue is the type of pins used from the factory, junior timer pins in the T55 Motronic connector. Yes I was having erroneous engine problems. The car ran okay, but I could tell it wasn't running perfect. The wear and tear comes from disconnecting/reconnecting x amount of times. Plus the tin oxidation that builds up over time = more resistance = poor connection. That and, as illustrated in the pictures via the gaps in the original pins, they lose their ability to maintain proper clamping force over time.
  28. ernie
    Nov 19, 2001
    22,084
    The Brickyard
    The Bad Guy
    Micro Timer pins.
